1990 Honda Accord EX - Where is transmission fluid located? - Honda-Tech
Old 02-06-2009, 09:53 PM   #1
chiaxi2002's Avatar
Default 1990 Honda Accord EX - Where is transmission fluid located?
Where is transmission fluid located on the engine block?
chiaxi2002 is offline   Reply With Quote
Old 02-06-2009, 10:19 PM   #2
Default Re: 1990 Honda Accord EX - Where is transmission fluid located?
It should be on the passenger side in front near engine block on transmission. Just look down about 10 inches from the top, to the right of your air cleaner housing and you should see a yellow handle dipstick. It is a tight fit but you can reach your hand down there to pull it it to check. Watch out for your cooling fan blades.
To change the fluid the drain plug is just under the dipstick on the outside trans block, facing your front passenger tire area. You have to get underneath and in that area you should see a 3/8 end square bolt head. That is your drain bolt that you use a 3/8
ratchet or straight bar to release and change with Honda ATF oil.
That is how it is on my 96 Accord EX, 2.2 VTEC.
Hope that helps.......Anthony
FIREBIRD71 is offline   Reply With Quote
Old 02-06-2009, 10:55 PM   #3
P_Adams's Avatar
Quote:
Lets get several things straight:
1) You won't find transmission fluid on (or in) the engine block.
2) What kind of transmission is it?
IF it's an automatic:
The dipstick for the automatic transmission is on the passanger side of the exhaust manifold, below the distributor. It helps to use a flashlight to locate the dipstick as it is really low in the engine compartment. It is about the same height in the engine as the lower radiator hose's exit from the radiator is. The dipstick itself is only about 4 or 5 inches long. Hope this helps. Here's an illustration:
P
P_Adams is offline   Reply With Quote
Old 02-07-2009, 01:20 PM   #4
chiaxi2002's Avatar
Where do we look if we plan to add more fluid?
Old 02-07-2009, 01:22 PM   #5
GhostAccord's Avatar
lol...... It's located in the transmission.......
You still haven't said what trans you have........ Is it Automatic or manual?
If it's automatic you can add it down the dip stick tube. If it's manual your going to have to get down and dirty and add it to the passenger side of the trans.
GhostAccord is offline   Reply With Quote
Old 02-07-2009, 01:52 PM   #6
waciii is offline   Reply With Quote
Old 02-07-2009, 02:03 PM   #7
chiaxi2002's Avatar
Thanks guys, I'll get right to it. By the way, how much fluid should it have?
Old 02-07-2009, 03:33 PM   #8
The dip stick will show you when it's full. If your doing a flush and fill it's 2.4qt and a transmission overhaul is 6qt
Old 04-06-2009, 09:46 AM   #9
Where's the drain plug for it? Is it right under the transmission or on the side where you can see when removing the passenger's wheel?
I have an automatic 4 speed 1990 Accord LX?
Thanks,
Bad_dude is offline   Reply With Quote
Old 10-06-2009, 09:01 AM   #10
Icon2 Re: 1990 Honda Accord EX - Where is transmission fluid located?
Thanks,
Could anyone confirm where the drain plug is?
Thanks,
Old 10-06-2009, 11:16 AM   #11
Thanks,
Should be at the bottom of the transmission housing. Look for the bolt with a 3/8 inch square hole in the bolt head. You should be able to see the drain plug from the passenger side. If you have a manual transmission, it is a good practice to loosen the fill plug first before the drain plug.
slamstrom is offline   Reply With Quote
Old 10-06-2009, 07:40 PM   #12
Quote:
Thanks for the answer. I have an automatic. So the bolt is directly beneath? When I look on the side from the passenger's side, I see a large hex bolt and wonder if that is it? As you described, I think it would be directly beneath and would fit a 3/8 ratchet right?
Thanks,
Old 10-07-2009, 04:28 PM   #13
I took a closer look at the drain plug and it was indeed on the side. You can see it just looking right behind the front passenger's side tire.
Now I need to get a washer before changing the fluid. I wonder what size washer is it? Is it metal or rubber? I wonder if the same washer I use on the oil drain plug can be use here? The oil drain plug I have is 19mm.
Thanks,
Old 10-08-2009, 10:25 AM   #14
Thanks,
If the 3/8" ratchet fits, then you found it.
Where do you put the transmission fluid? DrewBrews Transmission & Drivetrain 4 01-21-2010 08:56 PM
Wheres my honda transmission filter. bluefuse Honda CRX / EF Civic (1988 - 1991) 6 06-29-2006 10:52 AM
where is the dipstick for transmission fluid on the honda prelude 1990? henry101166 Honda Prelude 5 07-07-2004 08:02 AM
WHERE IS THE TRANSMISSION FLUID PLUG? RACERX72 Honda Prelude 19 05-12-2004 02:15 PM
Transmission Fluid GeeSeeR Acura Integra 1 08-06-2001 05:07 PM
Tags
1990, 1992, 2000, 2002, accord, automatic, check, civic, drain, fluid, honda, lx, plug, plugfluid, racing, removing, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
