1990 Honda Accord Electrical Issues
Old 03-13-2006, 11:38 PM
g1teglover's Avatar
Default 1990 Honda Accord Electrical Issues
I've been working on a buddy's 1990 Honda accord. right now the car's power windows will not go up or down from any switch, and the window relay has been replaced, the door locks will not operate (control unit was ripped out anyone have one that works pm me), and finally the brake lights do not light up when the headlights/parking lights are turned on, only when the brakes are pressed (we have replaced the two black boxes on the brake lights and still get the same issue.
g1teglover is offline
Old 03-18-2006, 09:29 PM
g1teglover's Avatar
Default Re: 1990 Honda Accord Electrical Issues (g1teglover)
Some one here has to be able to help me.
Old 03-18-2006, 10:14 PM
P_Adams's Avatar
fuses, chk the fuses
in-compartment
10amp Pwr Window Relay/Moonroof
under-hood
20amp Pwr Window r/s
20amp Pwr Window l/s
Brake lights or Tail lights?
P
P_Adams is offline
Old 03-19-2006, 10:36 AM
g1teglover's Avatar
all fuses are good, so are the brake lights
Old 04-14-2016, 05:14 PM
Thc8ndyM8n's Avatar
Have you checked for any signal (+) or (-) at the wires going to the bulbs. Could be a ground issue is there signal at the relay for windows and if so does it also reach the door panels. It's a long process but you have to follow the power source to the fault and complete the circuit. Do you have wiring diagrams?
Thc8ndyM8n is offline
Old 04-14-2016, 05:50 PM
Global Moderator
tech8's Avatar
Thread is over 10 years old...
Closed.
tech8 is offline
mdsluka
11-18-2015 03:02 PM
papirod3
08-05-2014 04:27 PM
amanda.hydar
03-10-2013 12:02 PM
Najee Watt
09-09-2012 08:41 AM
Quick Reply: 1990 Honda Accord Electrical Issues
