1990 Accord crank no start - Honda-Tech
Old 09-18-2009, 03:42 PM   #1
peter_x's Avatar
Default 1990 Accord crank no start
I have a '90 accord F22a4 that cranks but doesn't start after I replaced the head gasket.
I checked the timing belt... I had lost the timing marks, but as I understand it as long as both the arrow on the camshaft and crank sprocket are pointing up, it is ok (and I double checked TDC with a screwdriver in the #1 spark plug hole).
I checked for spark by taking out a plug and grounding it while cranking. It was sparking.
I checked for fuel pressure at the rail by disconnecting the return line and cranking. Fuel was there.
The distributor had gotten wet while it was off the engine, so I was worried about the CRANK/TDC and CYL sensors. I checked the resistances on the connector in accordance with my Haynes and that checked out ok.
Next I checked the voltage to the coolant sensor. My Haynes says that it should be getting a supply of 5V KOEO. It was only getting .53V. Not sure if that matters. The resistance across the sensor itself is OK.
I checked the voltage at the injector connectors with KOEO. I was actually getting about 10V to both sides. Not sure that that means. The resistances in the resistor pack were OK.
Next I tried to test the MAP sensor. The Haynes says that should also have a supply voltage of 5V. I was getting almost 10V here too.
I am wondering if the PCM is fried. I accidentally grounded both the battery and alternator while removing the head (I grounded the alternator when the wire I unclipped from it hit the engine). I replaced the blown battery fuse.
peter_x is offline   Reply With Quote
Old 09-18-2009, 04:27 PM   #2
deserthonda's Avatar
Default Re: 1990 Accord crank no start
i would chk all the fuses ,, ( ecu fuse ) ,, also chk to make sure that you connected the ECU ground wire at the t-stat
deserthonda is offline   Reply With Quote
Old 09-18-2009, 05:45 PM   #3
peter_x's Avatar
All the fuses are good with the exception of the condenser fan. I did reconnect that ground, but I haven't checked it. Thanks for reminding me of that.
Is there any way to tell if the injectors are actually working? I had another car where I could take off a spark plug and watch the mixture shooting up while cranking. I tried that here but I don't think I could really see anything. I'm not sure how safe it would be to remove the injectors and rail together and crank the engine.
Old 09-19-2009, 09:26 AM   #4
peter_x's Avatar
The t-stat ground has continuity. I can't think of what else to do.
Edit: I found another ECU fuse in the under dash fuse box, that was good too.
Old 09-19-2009, 08:21 PM   #5
gianinline's Avatar
Ok, you checked electrical things, and you also checked for fuel and spark, but we're missing the third item on this love triangle. You need spark, fuel and compression for the engine to start and continue to run.
Use a compression gauge, remove one spark plug and disconnect the distributor plug to the harness, then... install the gauge and turn the key on and crank it for a few seconds (never more than 10 seconds).
gianinline is offline   Reply With Quote
Old 09-20-2009, 11:42 AM   #6
dont forget to check your main relay.....
mclovinF22 is offline   Reply With Quote
Old 09-22-2009, 10:40 AM   #7
peter_x's Avatar
I checked for compression, it seems ok.
I took out the main relay to test in accordance with these instructions:
http://autorepair.about.com/od/engin...nrelay_tst.htm
But my relay doesn't have a #4 terminal. It has everything except that. Does anyone know the correct procedure for mine?
Thanks.
Old 09-25-2009, 04:05 PM   #8
peter_x's Avatar
Ok, I started the car. After realizing I no longer had spark, I got a new distributor and the car started.
But I think the timing belt if off a tooth. I can hear what I think are the valves hitting the pistons. Like I mentioned in the first post, I set cam sprocket so the "up" was facing up as close as I could get it. I set the bottom end to TDC on #1 with a screwdriver. Also, when you give it gas, it takes a long time for the revs to come down. Is there something I did wrong?
Thanks.
How to troubleshoot no start/no fuel/no spark problems gsxboost Honda CRX / EF Civic (1988 - 1991) 10 07-04-2016 10:41 AM
Replaced fuel lines, now injectors won't pulse? LXi Honda Accord (1990 - 2002) 4 11-19-2015 03:46 PM
Couple questions about diagnosing my b18b1 swapped 95 civic hatch thebeard Hybrid / Engine Swaps 5 04-22-2015 10:33 AM
[FAQ] ECU Codes for everyone JDMlyfestyle Honda Civic / Del Sol (1992 - 2000) 581 03-30-2015 11:07 AM
2001 civic will crank but won't start sheeliboy Honda Civic (2001 - 2005) 6 03-22-2015 02:28 PM
Tags
1990, 2009, 90, accord, crank, cranking, cranks, distributor, f22a4, honda, mark, move, start, tach, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
