► 1990-2002 Accord FAQ
Old 06-19-2006, 10:31 AM
Working
-RedneckDave-'s Avatar
Default ► 1990-2002 Accord FAQ
If you have a link you want added then PM me or TouringAccord with the link and one of us will add it in.
Honda-Tech Terms of Service
Accord Forum Rules
Learn How To Use The Search Feature Here!
Learn How To Use the IM (aka PM) Feature Here
Engine
How-To: Replace Timing Belt, Timing Balancer Belt and Water Pump on a F22B1
Setting Rear Balance Shaft Position
How-To: Replace Head Gasket on a F22B2
F22 Spark Plug Tube Seal Replacement
HOW TO: H22 Auto Tensioner to H23 Manual Tensioner Conversion
H23A1 Intake Manifold onto a F22B1 Head
**How To** Install H23 Intake Manifold onto F22B1 (*In Process*)
F22B1 ITB Setup (*In Process*)
F22B2 ITB Setup (*In Process*)
F22B2 & F23 Intake Manifold Comparison
Valve Adjustments for F22Ax
Valve Adjustments for F23Ax
Cheap!! DIY Catch Can
6th Gen AEM TRU-Power Pulleys Install
Short Ram Intake Heatshield
DIY Cold Air Intake
EGR Port Cleaning: 90 – 97 Accords
94 – 97 Accords EGR Port Cleaning
Fix for CEL Code P0401 (EGR Port Cleaning)
EGR Port Cleaning for 98-02 Accord V6
EGR Block Off (F22B1 & F22B2)
How-To Check & Fix your Fast Idle Thermo Valve (FITV)
Cleaning the Idle Air Control Valve (IACV), Fast Idle Thermo Valve (FITV) and Throttle Body (TB)
Converting from External Coil to Internal Coil
90-93 Accord Fuel Filter Replacement
94-97 Accord Fuel Filter Replacement
Replacing 5th Gen Fuel Pump
How-To: Replace Internal Seal of Distributor (Internal Oil Leak)
How-To Replace Thermostat and Radiator
F22Bx Torque Spec and Sequence for Head Bolts
How to check and replace TPS (Throttle Position Sensor)
How-To: Replace VTEC Solenoid & Distributor O-Rings
Drivetrain
How to: Auto to 5spd Swap **lots of pics**
5th Gen Auto to 5spd Swap
6th Gen Auto to 5spd Swap Guide
Why your car "whines" in reverse.
F/H Series Gear Ratios
Inside the 6th gen V6 automatic, and what fails in them.
How To Replace Manual Transmission Fluid
How to replace clutch master cylinder
How to replace your clutch
Suspension
Suspension Thread (contains Pictures and Specs)
6th Gen Rear Swaybar Install
6th Gen Rear Swaybar Endlink Bracket Replacement
Swaybar Bushing Lube
Ingalls Camber Arm Install
6th Gen Spring/Shock/Coilover Install
Power Steering Rack Converted to Manual Steering Rack (Done on an ITR but may be useful)
Additional Info on the Power to Manual Steering Rack Conversion (Done on an ITR but may be useful)
5th gen accord rear camber washer trick guide and how to
5th gen accord spring and shock install guide and how to
DIY: "Boat look" Fix
How to: Turn Tanabe Sustec Pro SO-C Type 2 coilovers into Type 1
Progress Rear Anti-Sway Install
Steering Knuckle Removal for 1998-2002 Accords
Easy and Painless Way to Separate the Lower Ball Joint
94-97 Front Swaybar End-Link Install
Brakes
1997 Accord Front Brake Tutorial
Applies to all 90-97 Accord front brakes
1994 Accord Rear Brake How-To
V-6 Front Brakes on a '95 4cyl
95 Accord Legend 2 Piston Brake Upgrade
5th Gen 5 Lug Swap and Brake Upgrade
Rotor-Over-Hub Conversion
Front Rotor-Over-Hub Conversion
Accord, Prelude, ITR, Legend and more interchangeable brake pads
4th Gen Rear Disc Brakes
Rear Drum to Disc Conversion
SUSP: Rear Disc Conversion
5-Lug Swap and Rear Disc Swap
Brake Bleeding/Flushing
Brake Pad Replacement
6th Gen Front Brake Rotor Replacement
Stainless Steel Braided Brake Hose Install
Fix your ABS system for $1.51 - no gimmicks
Difference Between Akebono and Nissin Calipers
90-93 Accord Calipers and Pads - Akebono versus Nissin
HOW-TO: Front/Rear Pads & Rotor Change
6th Gen Wheel Stud Replacement (Grinding Method)
Rims/Tires
Tire Size Calculator
Interior
Radio Install Guide 4th gen Accord
Radio Install Guide 5th gen Accord
Accord Coupe/Acura CL Front Seat Install Into a 6th Gen Sedan
Harness Install
TL-S Steering Wheel Install Into a 6th Gen
Wheel Spacers
How To: Relocate Your HVAC ***** - 5th Gen
94-97 Gauge Cluster Removal
94-97 Gauge Cluster Removal (with Pics)
94-97 Gauge Cluster Dis-assembly
97-01 Prelude Cluster Install into a 94-97 Accord
90-93 Blower Motor Removal
Radio code Retrieval
Ignition switch replacement
Inner Door Handle Replacement
5th Gen Accord Cluster Disassembly Write-Up (Pics)
90-93 Accord Dash Bezel Removal
<u>Exterior</u>
94-95 EX Front Lip onto 96-97 Front Bumper
Audi TT HID Retrofit
Removing Haze from Headlights
5 Minute Headlight Oxidation Removal
DIY: Black Housing Headlights
DIY: Install City Lights
Understanding Automotive Lighting
SiR Wing Fitment
Cornering (Side Bumper) Lights for 94-97 Accords
DIY: ITR Front Lip Install
Dent Removal
How To Wire Up Your Power Folding Mirrors
Installing Window Visors on 94-97 Accords
94-95 Trunk vs 96-97 Trunk (Scroll to post #5 for start of 94-95 vs 96-97 trunk lid discussion)
Chassis
1991 Accord AC condensor removal
Battery Relocation
Battery Tray Modification
4th Gen Prelude Shifter Assembly Conversion
Short Shifter
PSPEC & Forbidden Short Shifter Discussion
Tech Review: PSPEC Tuning Short Shifter
6th Gen Short Shift Adapter Install
Installing a eBay Short Shift Adapter (6th Gen)
Antenna Mast Replacement on 90-97 Accords
Specifications
Honda/Acura Fuel Injector Flow Rates
Accord Type R U2Q7 LSD Information
H & F Series Engine Info
94-97 Accord Weight, Wheelbase, etc.
Electrical
How To Replace a Honda Main Relay
DIY: Hyperblinker
Difference Between Good and Blown Fuses
How To Fix Your Daytime Running Lights Module
HOW TO: Bypass SRS for Aftermarket Wheel
HOW TO: Wire Horn for NRG Short Hub
98-02 Accord Coupe Bulb Guide
How To Replace Burnt Out Emergency Switch Bulb
How To Replace Burnt Out Rear Window Defrost Switch Bulb
Swaps
H22A Swap into a 4th Gen
H22A Swap into a 5th Gen
F22B1 VTEC Headswap
F22B1 Headswap onto F22A1 block
H22A Head Swap onto a F23A1 Block
H22A1 Head Swap onto a F22B2 Block
H23A1 Head Swap onto a F23A1 Block
H22A Head Swap onto a H23A Block
CL-S Motor Swap
CL-S Motor Swap Parts List
Turbo F22 build H22 rods 4g63 pistons low compression
F22 DOHC Swap into 90-93 Accord
Turbo Manifold for H22A Accords (A/C and P/S Compatible
DSM Injector Install
General
Guide to Basic Accords
Accord Picture Thread (Old Locked Thread)
Accord Picture Thread (Current Thread)
Accord 1/4 Mile Times and Set-Up Used
Accord Exhaust Sound Clip Thread
Jack Points
Honda Accord Recalls
How Stuff Works: VTEC
Official CD Squad
Official CG Squad
<u>Maintenance</u>
Repacking Exhaust
6th Gen A/C In-Cabin Filter Replacement
Resetting Maintenance Required Light - 4th Gen (90-93)
Resetting Maintenance Required Light - 5th Gen (94-97)
Resetting Maintenance Required Light - 6th Gen (98-02)
OBD-II CEL Codes and Descriptions (for OBD-I CEL Codes and Descriptions scroll to the bottom of first post)
A/C Troubleshooting
How-To: Oil Change
How-To Evacuate and Recharge your R134a A/C System
<u>Classifieds</u>
Accord FS/WTT/WTB Thread (Sticky located at top of the Accord Forum)
Just for buying or selling Accord parts.
Honda-Tech: Honda Market Place
For all your buying and selling needs on Honda-Tech.
Official 4x114.3 Wheel Thread FS/WTT/WTB
If your looking to buy or sell 4x114.3 rims, this thread is for you.
Official 5x114.3 Wheel Thread FS/WTT/WTB
If your looking to buy or sell 5x114.3 rims, this thread is for you.
<u>Websites</u>
HELM Inc. (Factory Service Manuals)
Majestic Honda (HAP)
Honda Discount Parts
Honda Parts Deals
Acura Carland
Delray Acrua
H and A Accessories
Car-Part
Forbidden Motorsports
Race Engineering, Inc.
JE Pistons
Wiseco Performance Products
Cruzin Performance
JDM ****
ICB Motorsport (JDMLand)
Password JDM
JHP USA
Top End Motorsports
Crank Scrapers
Import Performance Parts
Kteller
LOVEFAB
Kaizenspeed
Maxbore
F22 Parts
H-Motors Online
JKOBD Wire Harnesses
Rywire
Tire Rack
Discount Tire
Vulcan Tire Sales
Eibach Springs
H&R Springs
KONI
Tokico
TEIN
Last edited by tech8; 06-24-2018 at 06:00 PM. Reason: Replace broken or dead links
-RedneckDave- is offline
fljmruiz
06-23-2017 06:23 PM
chrisfletcher
01-11-2007 05:04 PM
Jason kiDD
09-05-2003 09:21 PM
Quick Reply: ► 1990-2002 Accord FAQ
