1988 HONDA ACCORD 2.0L CARB. SHIFT PROBLEMS.....
Old 05-22-2006, 10:04 AM
unhappy_idle's Avatar
Default 1988 HONDA ACCORD 2.0L CARB. SHIFT PROBLEMS.....
Does the 1988 Honda Accord Carb 2.0L, have an ECU that generates diag codes? If so how can I access it?
The transmission is showing up and refusing to move into 4th gear when in D4. It normally gets worse at this when the car has been driven for around 10 miles. Normally iin D3 if I race to around 40 miles, at 3000rpm and then take my foot of the accelerator, change to D4 the A/T will shift into 4th.
The fluid level in the A/T is ok. The fluid does not smell burnt. I think the fluid is Dexron IV in the A/T.
I am unsure whether the problem is due to engine problems; i.e a vacuum leak,; an old Oxygen sensor that probably needs to be replaced, actual problems with the Vacuum modulator ( does it need adjustment, broken spring etc). I think the A/T on this car is purely vaccum operate, but I am not sure.
Its amazing how little information is available on how A/T's work and manuals etc.
How exactly does the ECU cause the A/T to shift up and down into different gears?
I am interested in knowing if anyone else had similar issues and how they resolved it. If it involves a complete tranny rebuild I probably will junk the car.
SOMEONE PLEASE REPLY.....
Old 05-22-2006, 10:13 AM
In a Junkyard near you.
Ross 2.0's Avatar
1. check the adjustment of the shift cable
2. the 3-4 shift valve could be stuck
3. the shift timing valve/ accumulator stuck
Unfortunately # 2 and 3 require the transmission to be torn apart. So let me know if you want to dive in that far.
But a flush with Honda ATF-Z1 (NO ADDITIVES) may help the problem.
sporter20
Transmission & Drivetrain
02-17-2014 12:09 AM
whathekeeps
10-25-2011 02:50 PM
masterkill455
02-20-2009 10:37 AM
mjmont
06-13-2007 04:20 PM
unhappy_idle
05-16-2006 09:35 AM
Quick Reply: 1988 HONDA ACCORD 2.0L CARB. SHIFT PROBLEMS.....
