93 h22a whinning when startup? VTEC cut off??
Old 02-02-2006, 09:19 PM
bucdenny's Avatar
Default 93 h22a whinning when startup? VTEC cut off??
i have a 93 h22a non lsd for some reason everytime i startup my car is makes this whinning noise but after like 2 mins it stops n runs fine. i think it has to do with my power steering fuild soaking the altenator but im not sure... also when im in high rpm my vtec seems to sputter like its trying to spit out oil.....and sometimes it seems like it doesnt come on at all ive changed to synthic oil it seems to work better but should i change to a heavier weight??? HELP!!!!!!
Old 02-02-2006, 09:34 PM
momstaxi's Avatar
Default Re: 93 h22a whinning when startup? VTEC cut off?? (bucdenny)
as for the whining noise, check your belts for your powersteering pump and alternator. make sure the tension is correct...
Old 02-02-2006, 10:22 PM
duceducecord's Avatar
sounds like a rattling noise really.. i'll check the belt tension tommaro..thanks
playlife
12-03-2008 09:48 AM
rayrayh22a
08-01-2008 01:58 PM
duceducecord
08-01-2007 04:46 PM
hondaaccord613
05-10-2007 08:23 AM
Quick Reply: 93 h22a whinning when startup? VTEC cut off??
