95 accord wiper problem
Ok, yesterday it rained a little while I was driving, and I used the mist function to clear the window. I did this a few times, and the last time, the wipers got stuck in the up position.
As far as I can tell, I hear the motor working, and the wipers are still connected to each other b/c when you move one, the other moves. Anyone have any idea what to look for? I am going to take it apart in a little while. The wipers will not work when you put them on High, low, or intermittent.
TIA
TIA
Re: 95 accord wiper problem (jb.)
so after taking a look at it, the main linkage arm that attaches to the motor came off. How can I put it back on w/o having to buy a new motor? thanks
*sigh* this is a real tough one, i dont think there are many options here, your only alternative seems to be to try to mend it together by welding? i rlly dont know much about this but try to get sum1 to take a look at it, get a few opinions and the favorable choice is the 1 u should go with i guess, cuz a new motor for sumthing small like that is gunna cost u time AND money mostly
Re: 95 accord wiper problem (SKYLINE GT)
On mine the linkage attaches to the motor with a nut and washer.The linkage should have a hole with two flats.If this is the case you can take the motor out and try to find a nut and washer that fits.
Mark
Mark
Re: 95 accord wiper problem (moonjaw2002)
ok so i got a part from the dealer. it is the shorter linkage bar with the clips built in. hopefully this works
tedog69er
05-23-2008 06:21 AM
