16/17 inch Honda wheels that would fit 97 Accord? - Honda-Tech
Old 04-14-2007, 04:11 PM   #1
Secret Chimp's Avatar
Default 16/17 inch Honda wheels that would fit 97 Accord?
I'd like to upsize my tires, but instead of dropping several hundred on new wheels, I'd like to use stock Honda steelies or alloys of 16 or 17 inch diameters. Are there any wheels in that size range that would fit the bolt and hub pattern of a 97 4 cyl?
Secret Chimp is offline   Reply With Quote
Old 04-14-2007, 05:07 PM   #2
corrosive23's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (Secret Chimp)
You can use the 97 Special Edition Alloy wheels.
corrosive23 is offline   Reply With Quote
Old 04-14-2007, 05:24 PM   #3
slomob18b's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (corrosive23)
Try this:
http://www.honda-tech.com/zerothread?id=1938439
Can't think of any stock Honda wheel that is 17" and has a 4x114 bolt pattern. Maybe the factory option ones, but they are probably expensive if they exist.
slomob18b is offline   Reply With Quote
Old 04-14-2007, 06:12 PM   #4
SkimN's Avatar
Quote:
Special Edition wheels are only 15"
SkimN is offline   Reply With Quote
Old 04-14-2007, 06:24 PM   #5
JDM_DC4_Fanatic's Avatar
just go to a tire place, and ask them for 17x6.5 steelies that are 4x114.3 bolt pattern with a honda hub bore. There are no 17" 4 bolt OEM honda wheels. but, there should be some kind of aftermarket steelies avaliable.
JDM_DC4_Fanatic is offline   Reply With Quote
Old 04-14-2007, 06:34 PM   #6
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (JDM_DC4_Fanatic)
I didn't realize this was possible. Any idea on what the per-wheel cost would be?
Old 04-14-2007, 08:03 PM   #7
SneezinCD5's Avatar
16" CL wheels
15" EX Wheels
SneezinCD5 is offline   Reply With Quote
Old 04-14-2007, 08:40 PM   #8
Honda_Accord's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (SneezinCD5)
Whats the drop on that sneezin? (the first few pics)
Honda_Accord is offline   Reply With Quote
Old 04-14-2007, 10:26 PM   #9
SneezinCD5's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (Honda_Accord)
I've got full Omni coilovers. If I were to guess id say 3-3 1/4"
2 low for daily driving (Just lowered it for the C8's and to do a mini shoot). Car is currently down for new interior turbo/engine build.
Here are some pics with 16" C8's. (Same drop as the CL wheels)
Modified by SneezinCD5 at 1:58 AM 4/15/2007
Old 04-14-2007, 11:03 PM   #10
ate my pixel
Twixle's Avatar
Why would you want to put on 17" steelies with low profile tires? It seems to me that the benefits on that are horribly outweighed by the consequences.
Twixle is offline   Reply With Quote
Old 04-15-2007, 12:58 AM   #11
SuShiBoiiii's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (accord2021)
or get some 16 itr wheels
SuShiBoiiii is offline   Reply With Quote
Old 04-15-2007, 01:36 AM   #12
slomob18b's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (SuShiBoiiii)
Quote:
He's looking for wheels with a 4x114 bolt pattern
Old 04-15-2007, 10:03 AM   #13
I checked at work, we can get them for 75$ CDN each
Old 04-15-2007, 10:06 AM   #14
Black Ex Coupe's Avatar
Damn sneezin your car looks great on any wheel.
Black Ex Coupe is offline   Reply With Quote
Old 04-15-2007, 10:54 AM   #15
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (slomob18b)
Quote:
i think momstaxi has 16's itrs on a 4x114 bolt pattern on his accord, but i could be wrong, i cant find his car with them on it. looks hella sweet though.
http://www.honda-tech.com/zero...age=2
scroll a bit until you see them on his accord , awesome lookin car, i belive those are 16's
Old 04-15-2007, 11:45 AM   #16
Those are 96 itr wheels. They are 15" wheels and the only 4x114.3 ITR wheel.
Old 04-15-2007, 12:19 PM   #17
Old 04-19-2007, 09:00 PM   #18
SneezinCD5's Avatar
Default Re: (Black Ex Coupe)
Thanks Gotta get a new set of wheels soon. Getting tired of the Cl wheels
Old 07-08-2013, 07:39 PM   #19
I know this thread is super old, but I just got a '95 Accord LX 4cyl and purchased some 15x6 114.3x4 6-spoke rims from a 2000 Accord. The car is stock height and after trial fitting the rims with the car jacked up in the air and no tires, clearance was pretty tight on the inside. In the rear, the wheels get close to the lower trailing arm and spring assembly, and in the front it's close to the spring assembly. Does anyone know if rims for the '00 won't fit on the '95? If I had tires on the wheels and put it on the ground, do you think more room would open up?
Also, would the 16" CL rims featured in this thread work on the '95 without wheel spacers? They look good on the '97 in the pics, can the owner of that car verify if wheel spacers were used and or if there were any inner clearance problems? This is a daily driver and I don't plan on lowering it.
Thanks in advance for any help!!!
xx_the_piper_xx is offline   Reply With Quote
Pic request...EK/EM1's or DC's on 17-19" wheels. TurboJesse Honda / Acura 32 12-13-2013 10:30 AM
Agressive wheel fitment on ep3?? 2005 Civic Si honda_90 Wheel and Tire 7 01-06-2013 08:41 AM
Anyone using 16in Honda Fit wheels on their EG's? ehLAaay Honda Civic / Del Sol (1992 - 2000) 0 04-23-2011 01:08 AM
NEED HELP - Getting new tires for my R CND ITR 01-374 Acura Integra Type-R 6 04-22-2011 03:44 AM
FD gears and 17 inch wheels TypeR1558 Acura Integra Type-R 3 12-05-2002 09:43 PM
Tags
16, 16s, 17, 1997, 4x1143, 97, accord, drop, fit, honda, inch, rims, steelies, tired, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
