03 Honda Accord Fuel Filter - Honda-Tech
Old 09-05-2007, 08:26 PM   #1
B bOy CrAyOn's Avatar
Default 03 Honda Accord Fuel Filter
does anyone know where it is located in this car ?
took a quick look under the hood for my friend and couldnt find it..
were guessing maybe it needs a new one because its starting to hesitate somtimes from 0 -20 mph....
we were thinkin maybe it also needs new wires and spark plugs and distributor cap
B bOy CrAyOn is offline   Reply With Quote
Old 09-05-2007, 09:28 PM   #2
JimBlake's Avatar
Default Re: 03 Honda Accord Fuel Filter (B bOy CrAyOn)
What engine does it have?
My '03 4-cyl does not even have a distributor, cap, or plug wires. It has an individual coil on each spark plug.
I think it's also got no fuel filter. Only a fine mesh screen at the pump inlet in the tank.
JimBlake is offline   Reply With Quote
Old 09-05-2007, 10:05 PM   #3
It Wasn't Me!
someone else's Avatar
Default Re: 03 Honda Accord Fuel Filter (JimBlake)
Correct, V6 is the same setup. There is a very small screen in the fuel rail IIRC. Might be thinking of a different year though.
Is it an auto or manual, how many miles, check engine light on? No immediate problems matching your description come to mind.
someone else is offline   Reply With Quote
Old 09-05-2007, 10:24 PM   #4
msedacca's Avatar
Could also be gummed injectors, or o2 sensor going bad, which is a very persistent problem among these cars. That could be messing with the fuel.
msedacca is offline   Reply With Quote
Old 09-06-2007, 12:39 AM   #5
no check engine light on, 40,000 miles on it, its an automatic.. i personally think shes just trippin out, i drove it and the thing felt fine, but she kept insisting that it hella lags a lot of time and starts to hesitate
Old 09-06-2007, 07:36 AM   #6
It Wasn't Me!
Default Re: (B bOy CrAyOn)
Quote:
It might just be the a/c compressor cycling. That is pretty noticeable on a lot of those cars at lower speeds.
Old 09-06-2007, 09:32 AM   #7
all accords since 1998 do not have a fuel filter per sae, they have strainer sock on the fuel pump intake.
YeuEmMaiMai is offline   Reply With Quote
Self Analysis time: Do you get envious subtly of people more successful than you? rico91stang General Discussion and Debate 140 12-31-2013 10:28 AM
Need to get a clutch and flywheel. Opinions? northcb7 Honda Civic / Del Sol (1992 - 2000) 5 04-04-2010 10:53 PM
Need a oil Pan for a D16z6! 00situner Forced Induction 6 12-06-2005 12:51 PM
tie rod diagnostic .. How to check/know you need new tie rods!? patastinky Tech / Misc 3 07-29-2004 01:07 AM
Was this mechanic BS'ing me?? 91GSteggy General Discussion and Debate 7 02-22-2004 12:01 PM
Tags
03, 2002, 2003, 2004, 92, accord, cyl, filter, fuel, honda, lags, located, location, pump, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
