02 accord pcm swap?
Old 12-22-2011, 11:55 AM
petey_97's Avatar
Default 02 accord pcm swap?
hey guys the spedometer in my friends 02 accord stopped working. I determined the pcm got shorted when he did his stereo install. The question I have in will a pcm swap work or will it have to be re calibrated? The car is an 02 accord V6 auto. Im in canada and the only accords my wrecker has is 2 V6 accord coupes. Will the pcm from a 98-02 accord coupe v6 work in a 02 accord 4 door V6? I just want to make sure before I go mucking about, I've done pcm swaps in the past on different makes but never on a honda and I don't know if they are specific. Thanks for any info.
Old 12-22-2011, 01:36 PM
GhostAccord's Avatar
Default Re: 02 accord pcm swap?
They have an immobilizer chip installed in each ECU. Therefore you would have to flash the new ECU to match his ignition/key chip. As long as the engine and transmission are the same you can use an ECU from ether a 2dr or 4dr. 98-02.
Old 12-22-2011, 05:30 PM
petey_97's Avatar
ah, you see I didn't know that. Thank you very much! Where would I have to get this done and about how much do you think it would be? thanks again for your help!!
Old 12-22-2011, 08:09 PM
I think there are some towing companies that have access to the scanners/programmers these days. It used to be a dealer only thing for a long time. As for how much, I'm not 100%. You would have to call around to your local shops to find out costs. Try towing companies, maybe even a lock smith and your local Honda/Acura dealership.
2005ineedhelp
12-05-2023 07:36 PM
northcb7
01-31-2014 11:15 AM
a2dadamm
04-17-2012 03:03 PM
v4lu3s
03-28-2012 06:20 PM
Quick Reply: 02 accord pcm swap?
