at to 5spd
Old 06-04-2010, 12:47 PM
blazedealh91's Avatar
Default at to 5spd
does this make it a little easer to do the swap ???
Old 06-04-2010, 12:52 PM
He knows where you live!
TheMuffinMan's Avatar
Default Re: at to 5spd
< Insert descriptive post here >
Old 06-04-2010, 01:18 PM
Old 06-04-2010, 01:19 PM
there thats better
Old 06-04-2010, 01:55 PM
Without giving any frame of reference as to where that picture is other than "does this make it easier to do the swap" no one is going to have a clue.
What is it you are looking at in the picture and what are you trying to do (or not do) with it?
I am also assuming this is for your 1992 Accord listed, but you don't specify in the post. You need to post up some more details. Have you also looked at any of the Auto to 5spd swap FAQ's in the FAQ?
Old 06-04-2010, 03:36 PM
zombo's Avatar
Looks like the bung for the clutch master cylinder, and yes makes it a ****load easier! if you unbolt that bung its a metal kinda thing with two bolts, then you have the perfect circle and mounting holes for the master cyl
Old 06-04-2010, 03:44 PM
wat else would i need
Old 06-05-2010, 06:51 PM
02 accord's Avatar
Manual trans, clutch, flywheel, slave cylinder and lines, MT mount, intermediate shaft, driver's side axle, shifter, shifter cables, clutch pedal, manual starter, just to name a few things.
Old 06-05-2010, 07:49 PM
Senior Taco's Avatar
dont forget the manual ecu
dtran002
06-12-2013 10:12 AM
osiris1741
01-24-2007 07:27 PM
95exr
03-29-2004 10:34 AM
DSmithBoi
08-21-2003 11:41 PM
CmptchAV6
02-28-2002 09:59 PM
Quick Reply: at to 5spd
