Timing Belt Question
Old 07-18-2011, 09:08 AM
cavrdave's Avatar
Default Timing Belt Question
There are two belts when I pull up the parts diagram on the Honda Estore for timing belt. What is the second belt all about? It says something to the line of timing balancer and I'm assuming it's a good idea to replace it as well since I'll be there replacing the h2o pump and timing belt.
Old 07-18-2011, 09:17 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: Timing Belt Question
the second belt drives the balance shafts, and yes it should be replaced when replacing the timing belt.
here is a write-up that covers replacing the balance shaft belt, just for reference...
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Comp97GSR
12-30-2022 12:10 PM
jtwoj1
06-05-2015 08:24 PM
eg6T
08-14-2005 02:35 AM
Quick Reply: Timing Belt Question
