01 4cyl Accord bad rattle (Water Pump?)
I drive an 01 Honda Accord and 2 nights ago it started doing this. Here is a recording of what it has been doing, recorded with the car idling after 10+ minutes of driving. https://*******/iS1y
I have been reading online and it seems like it might be water pump bearings? Possibly Exhaust manifold rattle.
Here is another video. https://*******/qMP3
Thanks for any help or direction.
MM Gruppe B
Re: 01 4cyl Accord bad rattle (Water Pump?)
Doesn't sound like water pump to me.
It could be the exhaust manifold has cracked, or the gasket between the manifold and down pipe has failed. Use a quality penetrating oil like AeroKroil on the exhaust manifold heat shield bolts, remove the heat shield, and inspect the manifold for damage.
MM Gruppe B
Clean out the reservoir, refill.
Verify the radiator has coolant in it.
Verify temp gauge is functional.
Verify oil is full.
Verify oil is full.
freedomlives
12-20-2012 10:56 AM
91DA9
04-22-2002 09:34 AM
