00 Accord Clock backlight is out. How to change it?
Re: 00 Accord Clock backlight is out. How to change it? (RedGSR)
same thing on my 91 accord i kinda miss having a clock i am just to lazy to look even though yours is proly way diffrent
the 6th gens should have a peanut bulb or 2 behind the clock somewhere... u could replace them with LED's if you want. u cant do the same for the 4th gens.. u would need a new clock.
just pop the clock out with a small screwdriver and replace the bulb behind it.
you may have to pop out the hazard switch to get to it but i forget....good luck!
I changed mine like last week, pop out the clock by prying at it from below the clock, then look on the back you will see a small black screw like looking thing, twist that out and replace it. I did it on mine and now it works.
On a side note mine doesn't dim anymore ? I cant remember if the clock light is supposed to dim with the rest of the gauges, anybody know if it does ? and what guess what may be wrong ?
Re: 00 Accord Clock backlight is out. How to change it? (Kavehman)
no, they are indepent from the dimmer switch i think.
you just need to replace the bad blub with a new one from honda.
rice size bulbs
rice size bulbs
Oh yeah I forgot I can edit my own title! Yay!
Re: (cpmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpmike »</TD></TR><TR><TD CLASS="quote">the 6th gens should have a peanut bulb or 2 behind the clock somewhere... u could replace them with LED's if you want. u cant do the same for the 4th gens.. u would need a new clock.</TD></TR></TABLE>
So i could get a cool blue one??
Thanks for the topic though. Mine just went out a few days ago. Too lazy to post the question.
