Big problem with car stalling out when it warms up
Old 12-07-2008, 09:34 PM
BB6rude's Avatar
Default Big problem with car stalling out when it warms up
Ok so my buddy has a 93 Accord and he just replaced the injector O rings that go into the intake manifold cuz they were trash. He also wanted to change the plugs and wires so naturally he just pulled all the wires off and didnt label anything like where they go back! I dont know what the # setup is on the destributor, Help? (2) while we had the fuel rail off we cleaned out all the carbon and crap under that piece that sits below the fuel rail (its got about 4 or 5 bolts in the top) also removed the EGR valve and tried to clean it. Now when the car warms up it wont stay running without being on the gas, What the hell?
Old 12-08-2008, 09:28 AM
Duane_in_Japan's Avatar
fuel injectors leaking air past the new seals??? You cleaned things up too well now the engine dont know how to act. The correct procedures are in the How To section.
Something got accidentally disconnected, look for vacuum hoses or electrical connectors hanging or broken.
The plug wires should be good if the engine starts and runs cold. If he did not actually loosen up the distributor and mess up the timing.
Old 12-11-2008, 10:21 AM
BB6rude's Avatar
Ill check all the conn. but I dont think theres anything unplugged or not hooked up. I will check though.
egGSR_hi
05-16-2009 12:23 PM
90IntegraTuner
04-20-2009 07:52 PM
ITLNstallion818
10-02-2004 05:32 PM
spock_rocker
04-20-2004 05:35 PM
vishous
07-23-2003 06:53 PM
Quick Reply: Big problem with car stalling out when it warms up
