What size font for fitting in as much notes as possible on note card to be used on final? - Honda-Tech
Old 07-23-2008, 12:22 AM   #1
w1ck3dR's Avatar
Default What size font for fitting in as much notes as possible on note card to be used on final?
I have a final later this week and my professor is letting us bring in one page of notes that is 8.5 x 11. I am trying to type up as much notes as I can to take advantage of this opportunity. What type of font and size would be best where I can fit as much in as possible but without having to use a magnifying glass to read? Are there fonts besides times new roman where I can fit in more words? What size font would be ideal? I'm planning on typing up notes on different pages an then printing them out and pasting it with glue onto the final piece of paper so I don't have to worry about formatting or the margins. Thanks for the help.
Modified by w1ck3dR at 3:59 AM 7/23/2008
w1ck3dR is offline   Reply With Quote
Old 07-23-2008, 12:38 AM   #2
.:Swig:.'s Avatar
Default Re: What size font for fitting in as much notes as possible on note card to be used on final? (w1ck3
umm im pretty sure if you have that big of notes to put on you shouldnt worry. i had to use a 3x4 note card and i got an 8x3 and just folded it in half he couldnt tell
.:Swig:. is offline   Reply With Quote
Old 07-23-2008, 12:43 AM   #3
H-T White Ops
Frozen E's Avatar
It's less the font and size than it is the quality of the printer. Make sure you print your stuff out on a nice laser printer.
Ink jet will fugg you over.
Frozen E is offline   Reply With Quote
Old 07-23-2008, 12:43 AM   #4
silentballer's Avatar
Times New Roman Size 6 font
/thread
Edit: Don't forget to change margin sizes
silentballer is offline   Reply With Quote
Old 07-23-2008, 12:44 AM   #5
EGlovr's Avatar
EGlovr is offline   Reply With Quote
Old 07-23-2008, 12:50 AM   #6
zones's Avatar
i used to print the notes on a piece of paper (on the smallest font that I can read) and then cut them up and tape them to the cards. can you actually print right on the cards?
zones is offline   Reply With Quote
Old 07-23-2008, 02:15 AM   #7
Night Owl
6-7.
Quote:
Just set the margin to 3x5 or whatever, then print and cut, voila no need to tape etc
Leo C is offline   Reply With Quote
Old 07-23-2008, 08:55 AM   #8
BluLude's Avatar
it really depends on what size font YOU can read. like i would print it out several times to see how well or bad it works. the smallest i went before was 5.5. also take into account the fact that during a test if you are rushed or something or a little tired towards the end you are gonna have a hard time making out wut u put down if you can barely read it at home so dont go too extreme.
btw good luck
BluLude is offline   Reply With Quote
Old 07-23-2008, 08:57 AM   #9
mgags7's Avatar
If you really feel like you need to fit that much, you've already set in stone your bad grade.
mgags7 is offline   Reply With Quote
Old 07-23-2008, 09:03 AM   #10
98bucket's Avatar
Default Re: (mgags7)
98bucket is offline   Reply With Quote
Old 07-23-2008, 09:04 AM   #11
The Factor's Avatar
Quote:
Uh, not really. Every class I had where I was allowed to do that I fit as much as I freaking could and I usually got A's or Bs.
The Factor is offline   Reply With Quote
Old 07-23-2008, 09:18 AM   #12
saywhat's Avatar
Default Re: (The Factor)
Use a copy machine to shrink all your notes then glue them on the card.
/thread
saywhat is offline   Reply With Quote
Old 07-23-2008, 09:23 AM   #13
mgags7's Avatar
Quote:
what in like a history class?
If it is anything that requires thought, copying endless amounts of notes isn't gonna do.
I guess I made the assumption here that the class is somewhat challenging. I had an exam where you could do this the past spring semester. I worked straight for 3 hours on the test with no time to be searching all of my sheets, and got the thing in just on time. I was the first person to get up from that test btw, and I got an A+ in the class.
Old 07-23-2008, 09:26 AM   #14
saywhat's Avatar
Since when did "A+" exist?
Old 07-23-2008, 09:38 AM   #15
nbcivic's Avatar
i never had a class that allowed notecards, prob because my class wasn't for idoits i meaaaaannnnnnn ummmm haha jk
nbcivic is offline   Reply With Quote
Old 07-23-2008, 10:34 AM   #16
JohnD1079's Avatar
Default Re: (nbcivic)
when i would cheat in HS on my vocabulary, I usually typed them up on one a little sheet of paper, size 6
JohnD1079 is offline   Reply With Quote
Old 07-23-2008, 12:11 PM   #17
mgags7's Avatar
Default Re: (saywhat)
Quote:
Uh...at NC State University (I'm in the nationally ranked engineering program)
Not trying to brag, but I don't go to some cracker-jack school.
Old 07-23-2008, 07:36 PM   #18
H-T White Ops
Frozen E's Avatar
Basically what all my teachers used to say.
[DIY] OEM JDM/EDM 1992-95 Honda Civic Low Fuel Indicator Retrofit deschlong Honda Civic / Del Sol (1992 - 2000) 21 11-11-2016 06:07 PM
[FAQ-DIY] OEM 5G 92-95 Civic Security Systems and Keyless Entry deschlong Honda Civic / Del Sol (1992 - 2000) 8 04-04-2015 05:23 AM
Rules, Thread Titles, Car Information, Searching, and Picture Posting Former User Honda CRX / EF Civic (1988 - 1991) 1 10-01-2012 12:06 PM
GSR Cluster into 91 Std EF Hatch: Wiring Questions [Ennis_D] Honda CRX / EF Civic (1988 - 1991) 3 09-07-2010 08:49 PM
PARTS 92-95 EG COUPE/HATCH & 99 GSR kid6061 Southern California (Sales) 151 04-21-2010 10:26 AM
Tags
card, cards, fit, fitting, font, good, note, notecard, notes, page, read, size, smallest, test, w1ck3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
