At what proof does alcohol freeze? - Honda-Tech
Old 03-20-2004, 11:16 AM   #1
Default At what proof does alcohol freeze?
I always thought it froze at anything 80 or above but last night we were drinking cheap Vodka and when we took it out of the fridge it had a big chunk of ice in it. Can anyone offer some insight?
TheAntiEggroll is offline   Reply With Quote
Old 03-20-2004, 11:22 AM   #2
RIP ILL: 26Jan1945-02Feb2017 -&- JLVK: 14Jun1925-13Dec2016
ZylexSNL's Avatar
Default Re: At what proof does alcohol freeze? (TheAntiEggroll)
i keep about 1/2 my b00ze in the freezer.
then again, none of it is cheap.
...and none of it has ever frozen.
kaluha tends to get thick and syrupy, though.
ZylexSNL is offline   Reply With Quote
Old 03-20-2004, 11:25 AM   #3
diearzte2
Guest
Posts: n/a
I thought proof was just a measure of amount of alchohol actually contained in something. Like 80 proof is 40% alchohol. Alchohol freezing temp is lower then that off water. So the frozen part was water, the remaining liquid was concentrated alcohol.
Old 03-20-2004, 12:46 PM   #4
lowrightor's Avatar
Not sure what the relationship between proof and freezing is but I cane share some light on the origin of "proof."
100 Proof stuff has a 100% chance of igniting on fire. As it turns out, it has to be 50% alcohol for that to happen.
lowrightor is offline   Reply With Quote
Old 03-20-2004, 12:47 PM   #5
Default Re: At what proof does alcohol freeze? (lowrightor)
The main reason I ask this is I am getting some good 80 proof alcohol tonight in a glass bottle instead of plastic and I don't feel like having it shatter.
Old 03-20-2004, 01:03 PM   #6
space cadet
Shakes's Avatar
Quote:
glass bottles are new for you??
ditch the old crow buddy, it will do you no good!
Shakes is offline   Reply With Quote
Old 03-20-2004, 01:10 PM   #7
Mr. Vapor's Avatar
Default Re: At what proof does alcohol freeze? (shakes)
Bartons Vodka with the plastic squeeze grip! ...........ahhh high school memories
Mr. Vapor is offline   Reply With Quote
Old 03-20-2004, 01:11 PM   #8
No there not but I am a beer drinker usually so most of the time I don't even bother chilling the hard **** but I'm having people over tonight and they would probably prefer it.
Old 03-20-2004, 02:28 PM   #9
kablamo's Avatar
"at what proof does alcohol freeze?"
it depends on two things: temperature and proof (obviously)
at the freezing point, most alcohol won't freeze. vodka for example (40% alcohol, 80 proof) won't freeze at -20.
note that cheap alcohol will however, because it is diluted with water; so cheap beer (or vodka or tequila or whatever) will freeze sooner because there is more water in it, even if there is the same amount of alcohol - although generally this "freezing" will only mean ice crystals inside.
kablamo is offline   Reply With Quote
Old 03-20-2004, 02:37 PM   #10
Default Re: At what proof does alcohol freeze? (kablamo)
The stuff I bought must have been real cheap cause it had a bigass chunk of ice in it.
Old 03-20-2004, 03:19 PM   #11
Al Bundy's Avatar
I didn't know that. I drink Jack Daniels all the time and it doesn't seem all that strong to me.
Al Bundy is offline   Reply With Quote
Old 03-20-2004, 03:57 PM   #12
01-0720's Avatar
Default Re: At what proof does alcohol freeze? (Al Bundy)
yeah dude dont nuy cheap alcohol, i had a bottle of sky vodka in my frezzer for a while and it never froze or had ice crystals, buy the nice **** like they said less water more of the good stuff
01-0720 is offline   Reply With Quote
Old 03-21-2004, 01:38 PM   #13
Unaffiliated
Saltine Box Racer's Avatar
Default Re: At what proof does alcohol freeze? (01-0720)
John Powers Irish Whiskey and El Jimador Tequilla chillin' in the freezer all the time with no freezing. You must have bought some awful crap! Even the good old 5 o'clock Vodka didn't freeze on me back in the day.....
Saltine Box Racer is offline   Reply With Quote
Old 03-21-2004, 01:41 PM   #14
Default Re: At what proof does alcohol freeze? (Lude Behavior)
I just dont see how 1 80 proof alchohal can freeze while the other doesnt.
Old 03-21-2004, 01:49 PM   #15
Nu Sigma Alpha
K.F14's Avatar
I've placed both my bottles of SKYY vodka and Bacardi 151 rum and left it overnight in the freezer without them freezing or shattering.They were both glass bottles so I don't think you need to worry too much if they are decent quality.
K.F14 is offline   Reply With Quote
Old 03-21-2004, 02:01 PM   #16
2lowintegra's Avatar
Default Re: At what proof does alcohol freeze? (E B K)
i've never heard (or witnessed) 40% alcohol freezing and i put all my liqour in the freezer.
2lowintegra is offline   Reply With Quote
Old 03-21-2004, 02:03 PM   #17
Stripped Si's Avatar
Default Re: At what proof does alcohol freeze? (2lowintegra)
1. Alcohol has a much lower freezing point (FP) than water.
2. Proof is the measurement of the percentage of alcohol in the drink
Therefore, the lower the proof, the easier your drink will freeze. This is why a beer will most certainly freeze when put in a freezer and bacardi 151 will just get cold.
Stripped Si is offline   Reply With Quote
Old 03-21-2004, 02:11 PM   #18
Al Bundy's Avatar
Default Re: At what proof does alcohol freeze? (Stripped Si)
Man.....you just mentioned bacardi 151, i feel like throwing up now.
Old 03-21-2004, 02:48 PM   #19
Synthesis's Avatar
pure alcohol freezes at -80 celsius, which is lower then that lowest recorded temperature on earth(-70 C)
bacardi 151 doesnt freeze of course because its 75.5 percent alcohol.
-273 is absolute zero on the celsius scale. water freezes at 0 (32 F)and mercury at -39 C.
so yeah that is your answer. thats why ice-filtered beer has a higher alcohol content, because impurities are filtered out.
Synthesis is offline   Reply With Quote
Old 11-04-2004, 05:08 PM   #20
riz7psi's Avatar
Default Re: At what proof does alcohol freeze? (Synthesis)
yep good answer
riz7psi is offline   Reply With Quote
Old 11-04-2004, 05:37 PM   #21
technine's Avatar
Stop buying boot legged alcohol and you will be fine. I've put 75 proof and above in the freezer no prob. All glass bottles, too. My girl put her Alezae (spelling) in the freezer and it came out slushy right after opening it (turned to slush upon opening, 25 proof I think).
technine is offline   Reply With Quote
*****The Official We're not Texans Thread***** civicsareslow General Discussion and Debate 46 05-03-2014 07:09 AM
If we only use 10% of our brain...... mixxed General Discussion and Debate 13 01-20-2005 08:39 PM
Do we really need PENNIES? RTW DC2R General Discussion and Debate 8 06-10-2004 01:21 PM
What are we going to do now??? Joe General Discussion and Debate 10 06-14-2002 04:26 PM
Tags
151, 40, alchohol, alcohol, bacardi, cheap, freeze, freezer, freezing, point, proof, rum, scale, skyy, temp, temperature, vodka
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
