What is the difference between carb cleaner and brake cleaner? - Honda-Tech
Old 01-28-2007, 06:52 AM   #1
* B A N N E D *
Default What is the difference between carb cleaner and brake cleaner?
What is the difference between carb cleaner and brake cleaner? Is there any?
cbmprelude is offline   Reply With Quote
Old 01-28-2007, 07:00 AM   #2
space cadet
Shakes's Avatar
Default Re: What is the difference between carb cleaner and brake cleaner? (cbmprelude)
one is stronger then the other.
Shakes is offline   Reply With Quote
Old 01-28-2007, 07:10 AM   #3
* B A N N E D *
Default Re: What is the difference between carb cleaner and brake cleaner? (Shakes)
can carb cleaner be used to get grease off new brake rotors?
Old 01-28-2007, 07:19 AM   #4
space cadet
Shakes's Avatar
Quote:
Yeah. Not sure if its bad for the brakes though but I doubt it.
I think the order of strength goes
Starter fluid
Carb Cleaner
Brake cleaner
Old 01-28-2007, 07:39 AM   #5
Brake cleaner is better because it does not leave any residue behind/ any type of film. On something as important as the brakes I would go spend a couple bucks and get a can of brake cleaner.
ImprtTunr is offline   Reply With Quote
Old 01-28-2007, 07:41 AM   #6
2point2's Avatar
that's a really good question!
Do you have any engine parts laying around? Spray some brake cleaner on some carbon build-up and see what happens.
2point2 is offline   Reply With Quote
Old 01-28-2007, 08:08 AM   #7
Stew Pidasso's Avatar
Default Re: (2point2)
Carb cleaner sometimes leaves a residual lubricant (oily film) to lube moving parts of a carb (see label) . Also, never use carb cleaner in a throttle body..only use throttle body cleaner and if it's a Ford, make sure the throttle body cleaner is compatible with the lining.
Stew Pidasso is offline   Reply With Quote
Old 01-28-2007, 08:58 AM   #8
shinobijesus's Avatar
Default Re: (Stew Pidasso)
the best thing to do is mix them together whenever you buy either into one huge spray bottle. then you have twice as much cleaner and its 1.5x stronger.
shinobijesus is offline   Reply With Quote
What is a good fuel injector cleaner? krisfnbs Honda Civic / Del Sol (1992 - 2000) 19 02-08-2009 01:46 PM
brake cleaner vs. carb cleaner tpot90 Honda Accord (1990 - 2002) 4 08-17-2008 10:11 PM
De-carbing, fuel injection system cleaning, and cleaning IACV A_Rotary_Guy Honda Civic / Del Sol (1992 - 2000) 7 01-19-2008 08:55 PM
De-carbing, fuel injection system cleaning, and cleaning IACV A_Rotary_Guy Honda Accord (1990 - 2002) 8 01-19-2008 08:36 PM
curborator cleaner and carb,chock throttle body cleaner(quick Q) joy123 Honda Civic / Del Sol (1992 - 2000) 2 01-03-2008 10:01 AM
Tags
accord, body, brake, carb, carburetor, civic, cleaner, differance, difference, fluid, honda, lubricate, mix, starter, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
