What causes oil to come out of the exhaust? - Honda-Tech
Old 05-19-2009, 10:15 AM   #1
hometheaterman's Avatar
Default What causes oil to come out of the exhaust?
This isn't really Honda related so that's why I'm posting it here. It's a 94 Nissan Sentra. Anyway, when you let it idle it smokes a little but not too bad. A bit of some comes out when you give it gas. However, I noticed when it was just idling I put my hand behind the exhaust and it got misted with oil. What's causing this? Is it the valves or something else?
My mother had a old Dodge truck like this she ran for years and just kept adding oil. Is this the normal or is it something that's likely to blow up next week?
Basically a friend is looking at buy this as they need a cheap car and this thing is $600. It has this issue, the paint is faded, and the power seatbelt on the drivers side is broken. The top power piece is like it slides freely it's not hooked onto the motor or whatever it's supposed to be hooked onto. Any idea how much that would cost to fix? I'm thinking the seatbelt has to be fixed but the rest you could just drive it until it broke. It seems decent to me for $600 as that doesn't get you much in todays world. However, they also don't want something that will only last them a week if that.
hometheaterman is offline   Reply With Quote
Old 05-19-2009, 10:19 AM   #2
My Name is Nobody
MSchu's Avatar
Default Re: What causes oil to come out of the exhaust?
lol... serious?
MSchu is offline   Reply With Quote
Old 05-19-2009, 10:20 AM   #3
crazy mad murdock
csingham's Avatar
she's cheating on you..there..im the first dick in here
csingham is offline   Reply With Quote
Old 05-19-2009, 10:25 AM   #4
GDD Moderator
tony tone's Avatar
right before it's about to nut
tony tone is offline   Reply With Quote
Old 05-19-2009, 10:26 AM   #5
94HB's Avatar
Oil from the tailpipe means the car is gay
94HB is offline   Reply With Quote
Old 05-19-2009, 10:27 AM   #6
omega02379's Avatar
omega02379 is offline   Reply With Quote
Old 05-19-2009, 10:28 AM   #7
Unceasing Measure
Archidictus's Avatar
Valve stem seal leakage (bad) can cause this, as can cracks in the head near the exhaust manifold. Are you sure it's oil and not water mixed with carbon soot from the normal exhaust emissions? Does it burn a lot of oil as well?
Archidictus is offline   Reply With Quote
Old 05-19-2009, 10:29 AM   #8
MonkeyMagic's Avatar
could be carbon that is being carried out with the condensation at idle...
are you sure its oil? if you get oil smoke under acceleration its piston rings. if you get smoke under decel or idle (manifold vacuum) its valve seals. if it smokes like its on fire... well its probably a ford
MonkeyMagic is offline   Reply With Quote
Old 05-19-2009, 10:33 AM   #9
im hench irl
skateboard_ej8's Avatar
^ lol
Make sure its oil, and not soot mixed with condensation.
skateboard_ej8 is offline   Reply With Quote
Old 05-19-2009, 10:35 AM   #10
Boba Connoisseur
SkyeC's Avatar
it's a 600 dollar car. get the seatbelt issue fixed and add oil when needed. it probably burns enough that it isn't even worth doing an oil change. when it needs a repair, you get rid of it. it should last a year or so. a good price for a car to drive for one year.
SkyeC is offline   Reply With Quote
Old 05-19-2009, 10:41 AM   #11
Quote:
Maybe it is carbon and water. It seemed watery but looked sort of like oil. Not 100% sure here though. It did smoke some too which is what made me think it's oil.
Old 05-19-2009, 10:42 AM   #12
at the jetties fishin'
stackz's Avatar
bad bad things
stackz is offline   Reply With Quote
Old 05-19-2009, 10:53 AM   #13
fatpride111's Avatar
dont waste your $600
fatpride111 is offline   Reply With Quote
Old 05-19-2009, 10:56 AM   #14
GDD Member
slomofo's Avatar
Valve seals - Most common.
Bad PCV Valve.
Bad piston rings
Incorrect vacuum routing.
slomofo is offline   Reply With Quote
Old 05-19-2009, 10:59 AM   #15
stackz's Avatar
Quote:
Bad PCV Valve.
Bad piston rings
valve stem seals?? lol. there's no more valve stem seals at that point if you have oil visible in the tailpipe hahahahahahahaah
Old 05-19-2009, 11:06 AM   #16
Unceasing Measure
Quote:
Okay - so it's not oil, it's just the normal carbon/water mixture that comes out of all exhausts. If there's an excessive amount of it, it's a general indication of head gasket damage.
Did you think to ask the owner of the car if it burned or lost oil? That would have been a pretty logical first step, don't you think?
Old 05-19-2009, 11:07 AM   #17
cute little bastard
SkoundrelUSA's Avatar
maybe its a tumar?
SkoundrelUSA is offline   Reply With Quote
Old 05-19-2009, 11:44 AM   #18
Well, the owner of the car is a junkyard. So not like I got to talk to whoever last drove it. They junkyard is actually still waiting for the title before they can sell it which makes me think they just got it. I've never seen an exhaust do that before other than my mothers old truck which like I said burned oil.
This car did smoke some so you could tell it probably burns oil.
Old 05-19-2009, 02:58 PM   #19
stackz's Avatar
so basically, they get an abandoned car and put a storage lien on it and because they toss a half lit battery in it and it happens to have keys....they attempt to crank it..and voila it runs/drives when put in gear.
wow.
other than that, they have NO FUGGIN CLUE on the history or why its abandoned and you are broke as hell and see "ooooo cheap transport" that bitch will leave you on the side of the road just like the previous abandonment owner did.
save your $600, catch the bus a few more weeks....and save up and buy a decent $1500 beater man.
Old 05-19-2009, 03:07 PM   #20
your car has AIDS
Presto800 is offline   Reply With Quote
Old 05-19-2009, 03:25 PM   #21
Pirate General...YARRRR
Ass$nyper's Avatar
Quote:
Originally Posted by Presto800 View Post
your car has AIDS
LOL
probably.
Ass$nyper is offline   Reply With Quote
Old 05-19-2009, 03:37 PM   #22
stackz's Avatar
Quote:
Originally Posted by ***$nyper View Post
LOL
probably.
probably?? that shyte is terminal yo!
Old 05-19-2009, 03:40 PM   #23
Drunk Wagon Pilot
Pinja's Avatar
Quote:
o god i lol'ed
Pinja is offline   Reply With Quote
worst honda ever. larudy Honda Civic / Del Sol (1992 - 2000) 20 03-13-2015 09:24 PM
Automatic Seatbelts in my DA GirlieRacer7o2 Acura Integra 8 08-28-2009 10:37 AM
GSR nightmare, need good advice Phre0nBurn Tech / Misc 4 03-11-2008 10:33 PM
New engine? New car? What to do now? 97AClude Honda Prelude 32 09-15-2006 07:17 AM
New guy with Honda issues. ConceptS14 Honda Civic / Del Sol (1992 - 2000) 10 07-07-2005 04:19 PM
Tags
360, bad, blow, carbon, ehaust, excessive, exhast, exhaust, honda, nissan, oil, pcv, pvc, raw, sentra, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
