Welding with pocket butane torches???? - Honda-Tech
Old 07-08-2004, 01:17 AM   #1
Westrock2000's Avatar
Default Welding with pocket butane torches????
Hey guys, I was wondering if you can do light use welding of like steel and aluminum with these hand held butane torches. They say they can get up to and over 2000*F
Like these little things;
Westrock2000 is offline   Reply With Quote
Old 07-08-2004, 01:48 AM   #2
dustin's Avatar
Default Re: Welding with pocket butane torches???? (Westrock2000)
Umm good luck.
How do you plan to "weld" again?
What's your plan for shielding gas?
You can definately *braze*/solder with one though. Silver soldering renders a very strong joint.
dustin is offline   Reply With Quote
Old 07-08-2004, 01:55 AM   #3
Accord94DX's Avatar
Default Re: Welding with pocket butane torches???? (dustin)
****. I was going to weld a 3 ton rated towing hitch to my civic with that.
Accord94DX is offline   Reply With Quote
Old 07-08-2004, 02:02 AM   #4
Default Re: Welding with pocket butane torches???? (Accord94DX)
Alright since you all want to be sarcastic asses!
I'm talking light duty here, like something that would have probably 3-4 pounds on it, inside a house. Nothing going on a car, not even car related.
I don't know how to weld with it, thats why I'm asking. I guess you use one of those rods, and melt it on???? I don't know.
Old 07-08-2004, 02:04 AM   #5
dustin's Avatar
What material are you welding?
brass?
steel?
aluminum?
Old 07-08-2004, 02:05 AM   #6
If you really ned something welded you'd be better off taking it to someone that knows what they are doing, so you don't hurt yourself, or anyone else.
Nid Styles is offline   Reply With Quote
Old 07-08-2004, 02:06 AM   #7
dustin's Avatar
Regardless, if it's only 4-5 lbs, solder it.
Acid core solder is extremely strong.
In addition to the acid core, you can even use flux for an easier joint.
Silver solder is even stronger.
I silver soldered the ends onto the clutch cable for my go-kart.
Old 07-08-2004, 02:17 AM   #8
Well Dustin you are just special anyways
Old 07-08-2004, 02:19 AM   #9
But solder doesn't really stick well to all surfaces. Your talking electrical solder right? Like for electrical circuits? Or some other kind of solder....they have thick stuff in the plumbing section of Home Depot I have seen before.
The application is plated steel I believe, its one of those 1"x1" square tubes that has 1/4" holes every 1" or so. I need to attach an aluminum 1.25" conduit to it.
The bar looks like the feet in this picture.
Old 07-08-2004, 02:21 AM   #10
You could use some quick arc welding, but it really depends on what it's made out of, and what it's being welded to.
Old 07-08-2004, 06:36 AM   #11
New User
Drew M's Avatar
Quote:
Oxy-Acetylene welding doesn't use any shielding gas and I guarantee you that there are people out there who can gas weld with a torch every bit as nice as what someone can do with a MIG/TIG.
Westrock: It would cost you less money to pay someone to MIG the weld for you than it will cost you to buy that stupid little BRAZING torch.
Also - solder doesn't stick to metal when the metal is not hot enough. Electric irons don't generally have enough wattage to get metal much more than a 16th of an inch thick hot.
Drew M is offline   Reply With Quote
Old 07-08-2004, 06:39 AM   #12
New User
Drew M's Avatar
Default Re: Welding with pocket butane torches???? (Nid Styles)
Quote:
You aren't saying he could do some quick ARC welding with that little butane torch are you?
Please tell me you aren't.
Old 07-08-2004, 06:53 AM   #13
Electrician
Deemeetree's Avatar
Go to Home Depot and get a $15 Propane torch. With that, you can solder and flux. More than you need. The Bernz-O-Matic ones.
Deemeetree is offline   Reply With Quote
Old 07-08-2004, 08:01 AM   #14
Banned
Default Re: (Dimi)
This guy I used to work w/ had a pocket butane lighter he used to smoke his meth with.
blykins is offline   Reply With Quote
Old 07-08-2004, 08:05 AM   #15
david@didrace.com's Avatar
You can't arc weld with a torch and you especially can't arc weld steel to aluminum with a torch.
david@didrace.com is offline   Reply With Quote
Old 07-08-2004, 08:06 AM   #16
Quote:
The only way to bond steel to aluminum correctly without getting into some high-end welding technology is to braze/solder.
Old 07-08-2004, 08:14 AM   #17
New User
Drew M's Avatar
Default Re: Welding with pocket butane torches???? (10-94-55)
Quote:
You can't ARC weld anything with a torch EVER. ARC is electric. Torches are gas.
Old 07-08-2004, 08:34 AM   #18
Default Re: Welding with pocket butane torches???? (Evil Drew M)
Quote:
My statement is true. Thanks for clearing it up a little bit better for those that don't know though.
Old 07-08-2004, 01:01 PM   #19
dustin's Avatar
Oh blah blah. The byproducts of the acetylene catalyzation and the high ratio of acetylene vs. oxygen in the mix form a "shielding gas" that prevents the metal from oxidizing.
How do you plan on working that out with a butane torch? If you actually could get the metal hot enough to melt it (assuming we are talking about steel here), the metal would "burn" rather than melt -- so you could not weld.
Of course, this is a moot point, considering mild steel melts above 2700 degrees fahrenheit.
Old 07-08-2004, 01:03 PM   #20
dustin's Avatar
I am talking about acid core solder. Rosin core solder (used for electronics) has no strength and will not bond to much of anything.
You can't weld steel to aluminum anyways. You will have to braze/solder it.
Old 07-08-2004, 01:04 PM   #21
dustin's Avatar
Tig is electric, and it has a torch.
Old 07-08-2004, 01:35 PM   #22
Skoobie no more...
HatchBox's Avatar
check this out, u can weld with this stuff with a regular propane torch.
http://www.alumaloy.net/
anyone have experience with this?
HatchBox is offline   Reply With Quote
Old 07-08-2004, 01:45 PM   #23
Happyman's Avatar
pwnt!
Happyman is offline   Reply With Quote
Old 07-08-2004, 02:22 PM   #24
H-T White Ops
Frozen E's Avatar
....And to braze anything you need a hell of a lot more heat than you're going to get out of your little butane torch thing there. We use oxy/acetylene rigs to braze copper lines to the steel outlet fittings on compressors when we do installs. I'm talking anything from small 3/8" lines to big 3" bastards. We use brass to braze and I'm just telling you that a butane torch like the one pictured is NOT going to be melting any brass rods any time soon.
Anyway, to the OP, go to a shop and have them work some magic for you. Trying to do it yourself when you have no idea what you're doing is just going to screw things up with you having to go to a shop anyway. So just skip the middleman (yourself).
Frozen E is online now   Reply With Quote
Old 07-08-2004, 02:28 PM   #25
PlastikOwl
Guest
Posts: n/a
Default Re: Welding with pocket butane torches???? (IslandSi)
you could make Creme Brulee with that torch. And then you can come on HT and tell us all how "fabulous" it was and how an accident with it gave you a permanent lisp.
High Quality Butane Torch Lighters Cyclops General Discussion and Debate 45 08-28-2010 05:41 PM
Making carbon fiber Nameless RB26 Welding / Fabrication 24 10-28-2004 01:57 AM
solder gun enrique Audio / Security / Video 5 06-23-2004 09:36 PM
Torching bolts to get them loose? FourthGenHatch Honda CRX / EF Civic (1988 - 1991) 5 09-25-2002 06:09 AM
lighters cardoobie General Discussion and Debate 3 03-30-2002 02:25 PM
Tags
butane, contact, depot, good, hawaii, home, metal, pocket, projects, small, torch, torches, weld, welding, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
