vw tranny on honda motor - Honda-Tech
Old 11-15-2011, 09:45 PM   #1
Spoolinls's Avatar
Default vw tranny on honda motor
looking to drop a honda motor in my sandrail. i know the b series rotate backwards for a vw, what do i need to make it work with the vw tranny or should i just put a s2000 motor in. what do you guys think
Spoolinls is offline   Reply With Quote
Old 11-15-2011, 09:53 PM   #2
rookn00b
xtrac1's Avatar
Default Re: vw tranny on honda motor
If an LSx fits, why not? Cheap hp and lots of it.
Lightly blown S2K (or k20) on E85 sounds nice.
xtrac1 is offline   Reply With Quote
Old 11-15-2011, 09:54 PM   #3
Arriving somewhere but not here
328FTW's Avatar
use a honda transmission? Odds are you just need custom axles then. Even then if they are for the right track width just throw honda hubs to match on it with the original shafts
By the time you make adaption plates, custom clutch plate (or at least buy a new one that fits the vw spline and is the right diameter for the honda flywheel) then work out your throwout arm and bearing carrier it's easier to just do the axles. Get the end resplined or just get them made, whatever works
328FTW is online now   Reply With Quote
Old 11-15-2011, 09:55 PM   #4
GDD Member
slomofo's Avatar
Counterclockwise engines aren't going to work.
You need to find out what your transmission can support before you go jumping into this highly unlikely scenario because those VWs did not put down a lot of power from the factory and their transmissions might not be able to support the power you're looking to get out of them.
Also, google: Porsche G50
Also... why do you need a longitudal transmission anyhow? What's wrong with stock?
Lastly... if you really really really want a longitudal mounted Honda counterclockwise engine, then it's cheaper to get a corvair transmission because the corvair engine also spun counterclockwise. I actually dropped a Honda Accord engine into the back of a corvair a few months ago and it went in just fine.
slomofo is offline   Reply With Quote
Old 11-15-2011, 10:08 PM   #5
Can't be Tamed
boredumb's Avatar
Quote:
Counterclockwise engine will work. Just need to run it upside down. My uncle did that on his and its never broken down.
boredumb is offline   Reply With Quote
Old 11-15-2011, 10:08 PM   #6
TRAY's Avatar
there is a ton of honda powered sandrails and they are mostly using factory trans
I know the acura V6 is VERY popular for this
TRAY is offline   Reply With Quote
Old 11-15-2011, 10:14 PM   #7
rookn00b
xtrac1's Avatar
Yes, the Honda V-6 is very popular.
Old 11-15-2011, 10:15 PM   #8
Spoolinls's Avatar
A honda motor will fit without having to refab it but if I go with a sbc ill have to refab it to fit I already have a built type 1 trans and axles jus need a motor
Old 11-15-2011, 10:28 PM   #9
GDD Member
slomofo's Avatar
Quote:
You need to figure out the proper way to say it. Upside down is not the correct jargon to use but everyone always says it that way
I'll explain why saying upside down makes you sound like a retard.
Imagine a wheel spinning clockwise.
Okay, I'm going to turn this image upside down. Brace yourself because this one's going to be a doozy...
Ready?
Prepare yourself now because bricks will definitely be shat.
POW MUTHUFUKKA! What direction is the wheel spinning now?
Wait a second.... is it just me or is it spinning in the same direction?
Old 11-15-2011, 10:32 PM   #10
Can't be Tamed
boredumb's Avatar
It just looks like the same direction cause its going really fast.
It also makes it way easier to do Oil changes since the drain plug will be facing up towards you.
Old 11-15-2011, 10:59 PM   #11
GDD Member
slomofo's Avatar
It started out as me trolling you, but now you're trying to troll me because you really have no clue how transmission flipping works.
Guess I'll explain...
The VW engine sits behind the transmission, so the transmission's bell housing is facing rearwards. Some people require a mid engine setup and need the engine in front of the transmission. Simply turning the transmission around isn't going to work because the wheels will then spin backwards, so they turn the transmission upside down and the wheels will subsequently turn forwards since the axles are coming directly out of the side of the transmission.
That's one way to get a VW transmission to have the bell housing facing forward. The other way is more in depth. The VW's ring gear only has teeth on one side, so if you flip it over, the teeth will be on the opposing side of the pinion and the transmission will then spin backwards, wel sort of. The wheels will be spinning counterclockwise while the input shaft and all the gears are still spinning in the same direction they always were. The only benefit to flipping the ring gear is that you can have a forward facing bell housing without having your transmission upside down.
Old 11-15-2011, 11:13 PM   #12
Spoolinls's Avatar
how hard is it to flip the ring gear
Old 11-15-2011, 11:20 PM   #13
GDD Member
slomofo's Avatar
Flipping the ring gear is easy, but I don't think you understand.
You flip the ring gear and you still need a clockwise turning engine to run it. The wheels will spin counterclockwise, but the input shaft still needs to spin clockwise.
If you want to run an F20, K-Series, J-Series, or other clockwise turning Honda engine, you can do a ring gear flip and run the VW transmission behind the engine, but it will not work with a counterclockwise spinning engine.
All these stories you hear that start off with my uncle, my brother, my friend, my cousin, my neighbor, my mechanic, my dad's friend, etc. and end with "is running a Honda engine with an upside down VW transmission... are all bullshit, every single one of those motherfukkers is a god damned liar. A lot of these people also have stories about how their brother in law's uncle's friend's neighbor's grandson put a Porsche 911 engine in the back of a beetle because that seems to be a popular fabricated story to throw out there as well.
Old 11-16-2011, 05:11 AM   #14
integra15's Avatar
Just do it and install the steering wheel and seats facing backwards. Problem solved.
integra15 is offline   Reply With Quote
Old 11-16-2011, 05:51 AM   #15
951parts's Avatar
Quote:
you can build another crank shaft in your garage
or you could rip the mainshaft out of the VW trans, shove a honda b series one in there and then do w/e it was in your nonsensical mind to mount the that bell housing/transaxle on the b, probably a back yard redneck mounting plate
951parts is offline   Reply With Quote
Old 11-16-2011, 07:35 AM   #16
TerribleToo's Avatar
Engine needs to run clockwise, its been done. In fact if I recall there is a big class of buggies that run this setup in the Netherlands. Clockwise b16 to a VW T2/T3 gearbox
Vids on youtube as well
TerribleToo is offline   Reply With Quote
Old 11-16-2011, 08:47 AM   #17
Spoolinls's Avatar
Ok thanks for the help
Old 11-16-2011, 10:08 AM   #18
KILLAB17VTEC
acmoc's Avatar
What bout all the VW guys saying Honda is crap
acmoc is offline   Reply With Quote
Old 11-16-2011, 01:07 PM   #19
beeseries's Avatar
How much do you want to spend?
http://kennedyenginc.com/default.aspx
I would go with a Twin Turbo LS7 with a mendeola or albins lol
beeseries is offline   Reply With Quote
Old 11-17-2011, 08:24 AM   #20
Spoolinls's Avatar
[QUOTE=beeseries;46365007]How much do you want to spend?
I would go with a Twin Turbo LS7 with a mendeola or albins lol[/QUOTE
i don mind spending money but a ls7 and mendeola is a little to much. would like to keep it within 2-3k
Old 11-17-2011, 10:31 AM   #21
Team Purple
Maverick's Avatar
you still need a clockwise turning engine to run it. The wheels will spin counterclockwise\
Make the front the back and the back the front and you're all set Problem solved.
Maverick is offline   Reply With Quote
Old 11-17-2011, 11:43 AM   #22
Gustav129's Avatar
There's two VW trans to use....
In a Chumpcar here...
VW Beetle Trans....
Saab 900's use the same style trans as the beetle for their front wheel drive...
The trans is in front of the engine, with the front of the engine at the firewall.
As for gears, you'd have to get custom gears, If you have a counter clockwise engine to spin the trans opposite of the direction it's supposed to (take the "engine behind" trans, and put it behind the engine) then you have four (or more) reverse gears, and one slow forward gear. But you would be putting pressure on the wrong side of gears and wearing them out faster.
My best bet would be use the Beetle trans (I saw many at the local Pull-N-Save last time I was there) and have the Honda Engine (same rotation as the 1600 Boxer engine) behind the trans for weight distribution.
Gustav129 is offline   Reply With Quote
Old 11-17-2011, 12:20 PM   #23
Spoolinls's Avatar
i already have a vw type 1 trans just need a motor for it
Old 11-17-2011, 01:58 PM   #24
mouab18c1's Avatar
Quote:
lulz
mouab18c1 is offline   Reply With Quote
Old 11-17-2011, 02:35 PM   #25
Gustav129's Avatar
I'm not a VW guy, so I don't know what a "Type 1 trans" is I'm assuming that's the one in the Beetle?
If so and you have the engine behind (furthest to the rear) the trans, and it rotates the same direction as the original VW engine, then I doubt you will have problems...
What Is The Bolt Pattern.... IHEARTMYHONDA91 Wheel and Tire 2 05-22-2010 10:55 PM
VW bus IRS tranny to h22? RIP V8s Welding / Fabrication 20 01-15-2008 10:50 PM
2007 VW Rabbit...yay or nay? hypnosisracing General Discussion and Debate 97 07-09-2006 05:25 PM
vw insults .adam. General Discussion and Debate 51 11-28-2005 01:27 PM
totaled 91 SI CRX....what parts do YOU need?!?!?! vw-honda-hatches For Sale 10 12-23-2002 01:17 PM
Tags
900, engine, fit, flip, gear, hard, honda, motor, pull, put, ring, run, saab, sandrail, trans, type, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
