Using car audio on your home - ac - dc power inverter - Honda-Tech
Old 04-02-2004, 10:57 AM   #1
Default Using car audio in your home .... ac - dc power inverter
So....my buddy has a car amp and sub that we're thinking about turning into a home sub set up. All we need is a 120v AC to (12 - 14)v DC converter. I looked forever and the only one I could find is here:
http://www.voltageconverters.com/ac_dc.html
Its only 5 amps, and I don't know that it will sufficiently run his amplifier. Anyone else have some info on this topic, or advice as to where I could find a decent converter? Thanks.
hybridcrx is offline   Reply With Quote
Old 04-02-2004, 11:36 AM   #2
tonyxcom's Avatar
Default Re: Using car audio in your home .... ac - dc power inverter (hybridcrx)
you will probably need at least 20 amps if you want it loud. It will be much easier and probably cheaper to just buy a home sub.
tonyxcom is offline   Reply With Quote
Old 04-02-2004, 11:54 AM   #3
Default Re: Using car audio in your home .... ac - dc power inverter (tonyXcom)
Honestly....I don't see how it could be easier or cheaper. He has a decent sub and amp already. RCA's, power wire and speaker wire are already in possesion. So the only purchase needed would be the inverter. And easier? It would take about 10 minutes to set up, how is that difficult in any sense?
Also...if the amp has a 20 amp fuse on it....I couldn't even use a higher amperage than 15 or so anyway, it would just blow the fuse if it ever peaked above 20.
Old 04-02-2004, 01:31 PM   #4
tonyxcom's Avatar
If you look at this logically. You haven't even found a DC power supply, how is your thinking even easier.
And yuo don't want to run any power supply near 100% of its rated output, so 20 amps is realistic.
Just goto circut city with 150-200 bux and buy a sub. Especially since you don't even know what you are doing.
Old 04-03-2004, 01:33 AM   #5
How is my thinking not easier? Give me a break. 150 - 200 bucks is going to buy a shitty *** sub.....where as I can buy 100 dollar inverter and have a nice setup. All I want from the viewers of this thread is a good site to get a power inverter from, not idiotic responses from you. Thanks though.
Old 04-03-2004, 01:35 AM   #6
something that i though about a while back is using a car battery, would this not work?
lkshs123 is offline   Reply With Quote
Old 04-03-2004, 01:57 AM   #7
Westrock2000's Avatar
Default Re: Using car audio in your home .... ac - dc power inverter (lkshs123)
Well, one easy way, is to go to the computer store and buy a hefty Computer power supply. They have 12V supplies and usually put out some amperage, especially the 300-400W ones. Check the label on the PSU to see how many amps they are kicking out.
If you have a computer reseller around, maybe check them out. We have some Sun computers that have power supplies that put out 12V@70A , and since Sun is so damn different than everyone else, the powersupply (big sum of a bitch) won't fit in a PC case, so no one wants them. But you may be able to find an older AT case powersupply for cheaper than a new "wanted" ATX supply.
Just be carefull here man, it aint worth dying for.
Westrock2000 is offline   Reply With Quote
Old 04-03-2004, 08:33 AM   #8
Default Re: Using car audio in your home .... ac - dc power inverter (Westrock2000)
computer power supply eh? Sounds like a plan to me, thanks a lot man. I'll let you all know how it goes.
Old 04-03-2004, 09:44 AM   #9
Luke's Avatar
Go take a look into McMaster Carr, I think, but am not sure that they do power supplies. I would go for a regulated 120 - 12/24. Check out Rockwell as they have tons of options. Lastly dont forget your local transformer company. Last year I managed to sort out a line transformer that is as good as any BS mains conditioner for about 20% of the cost...good luck
Luke is offline   Reply With Quote
Old 04-03-2004, 09:46 AM   #10
TwistedSI's Avatar
You can also use a car battery charger but get ready to hear humming a lot. And remember that you car amplifier is rated at 4 ohms and almost all house speakers/subs are 8ohms so you loose half your amps power right there. Putting sound into a house with car audio components isn't as simple as it seams. It won't sound nearly as good as you would hope. I played this game many many years ago with very high end car audio and it never sounded nearly as good as any mid line home audio equipment.
TwistedSI is offline   Reply With Quote
Old 04-03-2004, 12:35 PM   #11
Default Re: (TwistedSI)
haha, don't worry, I know my stereo stuff. We're running a car sub so it will be at 4 ohms. No loss in power. Plus, we're not looking to get anything spectacular out of this. He just got a new car with a nice stock stereo so hes got this 8 year old amp and sub from his old car that wouldn't sell for anything over 10 bucks. We figure spend 50 bucks on an inverter and it would sound better than a 50 dollar home audio setup which really don't exist for under 100 - even then they are sketchy at best.
Thanks again guys.
Anyone just wanna give me a link to one of these damn things? I'm going to these sites and just finding a bunch of confusing links. But nothing specifically stating 120v ac to 12v dc. BAH!
Old 04-03-2004, 01:37 PM   #12
Luke's Avatar
Default Re: (hybridcrx)
http://www.ab.com/industrialco....html
and dont forget to check out your local transformer suppliers as they may be able to cut you a deal
audio gurus, is this safe to run??? yc_dc4mar Audio / Security / Video 1 05-15-2012 07:53 AM
JL audio 12w3v2 Fat Cash Stack Audio / Security / Video 22 04-08-2012 10:35 PM
[B]75w Smart Auto AC Inverter[/B] autodoodad.com Miscellaneous - Appearance - Lighting 0 08-25-2007 12:59 PM
Hybrid Tig welder - Using AC/DC stick welder - Advise plz. 326power Welding / Fabrication 2 11-08-2004 02:43 PM
Sony XM-2150GSX, 2 ID12V.2 D4 Image Dynamics Subs, in a Sealed Box bhaz413 For Sale 0 04-15-2002 10:01 AM
Tags
12, 120, ac, amp, amplifier, audio, car, converter, dc, home, house, inverter, power, put, qurwxacdc, stereo, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
