Turbo and 200,000 miles - Page 2 - Honda-Tech
Old 10-03-2012, 03:23 PM   #26
White98LS's Avatar
Default Re: Turbo and 200,000 miles
Quote:
Originally Posted by Uncle Ben's View Post
there are TONS of turbo Volvos over 200k miles. I don't think it is a coincidence that both the Volvo T5 and Mitsu 4g63 have both been used for about two decades without much issues. Designing an engine for boost > boosting an NA engine after tinkering with fuel delivery etc.
Friend in HS had an '87 Volvo wagon with 190k on it. Boosted that stock turbo up to 19psi, cracked into the 14s (not bad in '00), survived. Those things are solid.
White98LS is offline   Reply With Quote
Old 10-03-2012, 03:28 PM   #27
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Location: Completing my training with my Supreme Leader
Yeah a friend bought a 240 from the '80s as her first car, used it through the late '00s at least. They seem like extremely durable powertrains surrounded by average durability through the rest of the vehicle.
Uncle Ben's is offline   Reply With Quote
Old 10-03-2012, 05:33 PM   #28
El Chico
Knightsport's Avatar
My '96 Supra TT had 215k miles when I sold it. Only thing I ever had issues with bushings wearing out (normal) and a harmonic balancer that seperated from the crank pulley (normal for the MKIV). 60k miles of that was single turbo. 18-22psi on average.
Other than that? Brake jobs and oil changes, wish I had held onto that car.
Knightsport is offline   Reply With Quote
Old 10-03-2012, 05:51 PM   #29
Quote:
Originally Posted by __oversea View Post
tis true
the only reason turbo cars are known for failing.....
is because we double the damn hp of what the motor should be handling
DaZman69! is offline   Reply With Quote
Old 10-03-2012, 05:58 PM   #30
El Chico
If you want to get technical any car that wasn't dsigned to be turbocharged is undergoing stresses the motor was not intended to see.
The fact that any of them last as long as they do is a testament to good tuning and not really just the fact that it is turbocharged.
Old 10-03-2012, 05:59 PM   #31
89efDUSTY's Avatar
Quote:
Originally Posted by xtrac1 View Post
Rebuilt turbo business is going to skyrocket in a few years.
Pm'd about future business plan...
89efDUSTY is offline   Reply With Quote
Old 10-03-2012, 06:02 PM   #32
89efDUSTY's Avatar
Seems like iron blocks help the car to survive the testament of boosting on stock applications.
Old 10-03-2012, 06:07 PM   #33
well yeah, thats just because you are adding power to it.
Not saying if you add a turbo to a factory car, it's going to last longer.
I'm saying if you want 300hp out of your 200hp motor, a turbo is safer than revving
Old 10-03-2012, 06:08 PM   #34
Turbo Diesels around your areas must be less redneck than mine. I doubt many around here last longer than 200k when they want to lope and try to drown everyone in smoke.
"HAHA! I smoked you out... hey, why did my turbo just turn into a grenade..."
EJeff8 is offline   Reply With Quote
Old 10-03-2012, 06:12 PM   #35
89efDUSTY's Avatar
Old 10-03-2012, 06:27 PM   #36
Widow's Son
Johnny.'s Avatar
Turbos need rebuilding just like any other wear item on a vehicle.
We're @ 104k on our WRX. No issues whatsoever. Just oil changes, brake pads/rotors, and tires.
COME AT ME 200K
Johnny. is offline   Reply With Quote
Old 10-03-2012, 06:31 PM   #37
My step father has owned numerous turbo diesel Mercedes(1980's) ..one of them was at over 500k miles and another was close to 400k. Now regular gasoline motors turbo'd is a different story.
del sol1658 is offline   Reply With Quote
Old 10-03-2012, 06:35 PM   #38
Honda-Tech Double Platinum Member
sCeRaXn's Avatar
My S4 is getting close to 180k miles and shes still going strong. Stock turbos and everything
sCeRaXn is offline   Reply With Quote
Old 10-03-2012, 06:38 PM   #39
96dxB16's Avatar
I sold my 2005 Evo with 160,000 miles on the clock. Was plenty reliable, no issues at all. Making 360whp on E85 for the last 80,000 miles of its life. That thing was bulletproof.
96dxB16 is offline   Reply With Quote
Old 10-03-2012, 06:45 PM   #40
El Chico
I'm saying if you want 300hp out of your 200hp motor, a turbo is cheaper than revving
FTFY
Tolerances are tolerances.
Any old NA motor MIGHT be over-engineered but not THAT much.
Old 10-03-2012, 06:50 PM   #41
Will you make something up for me please?
shamoo's Avatar
Quote:
Originally Posted by GoLowDrew View Post
Why is it that turbo diesels seem to last longer than turbo gasoline cars? I can't imagine the rubber seals or rings be much different.
Not sure if anyone else responded, but diesel vehicles in general are much more "solid". The entire premise of a diesel is to ignite the air/fuel with compression alone (vs. a spark). The block is essentially bulletproof. Timing is ridiculouly high in a diesel engine as well. I'm pretty sure that's one of the main reasons big rigs use them, and they last into the millions of miles.
A "normal" vehicle with a turbo has to get a lot of things right for things to operate smoothly. A diesel, not so much. A little too much boost here and there, a little too much fuel/air, and you're still fine.
I'm obviously oversimplifying it too.
shamoo is offline   Reply With Quote
Old 10-03-2012, 07:16 PM   #42
El Chico
Right.
The only real weak link in a turbo-diesel is the turbo and generally speaking only if boost is raised above and beyond what anyone would consider reasonable.
Old 10-03-2012, 09:15 PM   #43
"Haters Gonna Hate"
FrostyDC4's Avatar
Quote:
How did the rest of the car holdup?
FrostyDC4 is offline   Reply With Quote
Old 10-03-2012, 09:16 PM   #44
Risky Business
BauleyCivic's Avatar
Quote:
W140 TD
:megusta:
BauleyCivic is offline   Reply With Quote
Old 10-03-2012, 09:23 PM   #45
B20 Bhai M.B.B.S
b20sedan's Avatar
E85
b20sedan is offline   Reply With Quote
Old 10-03-2012, 09:23 PM   #46
rookn00b
xtrac1's Avatar
E85 on 13:1 compression and some mad timing.
xtrac1 is offline   Reply With Quote
Old 10-03-2012, 09:25 PM   #47
Ironically the only thing that E85 ended up being useful for, is the exact opposite of what it was intended for: ensuring the safest and best unnecessary expenditure of gasoline.
Old 10-04-2012, 12:40 AM   #48
fabioso's Avatar
I have a 82 mercedes diesel that has been daily driven all it's life, haven't really done much except for replace water pumps every decade. Odometer stopped working around 1996 at 205k.
fabioso is offline   Reply With Quote
Old 10-04-2012, 05:20 AM   #49
put title here
b_ack51's Avatar
Quote:
Scary, mine hit maybe 80,000 and everything on that car was going wrong.
b_ack51 is offline   Reply With Quote
Old 10-04-2012, 08:15 AM   #50
GoLowDrew's Avatar
When talking about turbo diesels, a lot of you guys use semi truck engines. What about VW TDI for example? So let's compare passenger car engines to passenger car engines.
Are TDI engines built more hardy vs. other turbos?
GoLowDrew is offline   Reply With Quote
Ford's EgoBoost Turbo engine - Experts GoLowDrew General Discussion and Debate 58 02-04-2014 08:00 AM
ford fusion better then accord and camry? pos_cd5 General Discussion and Debate 109 02-16-2007 05:22 AM
Ford Fusion The Notorious Frosty General Discussion and Debate 129 12-01-2005 01:28 PM
getting a rex ecovillain Honda CRX / EF Civic (1988 - 1991) 8 09-10-2004 11:37 PM
My Civic's 200,000 mile birthday... Koori General Discussion and Debate 25 07-20-2002 06:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
