Top tier gasoline - Page 3 - Honda-Tech
Top tier gasoline
Old 07-30-2013, 11:33 AM   #51
Road House
FijiBlueFG2's Avatar
Default Re: Top tier gasoline
Mobil ftw
FijiBlueFG2 is offline   Reply With Quote
Old 07-30-2013, 11:57 AM   #52
Slow*Jim's Avatar
I usually fill up at UDF (Mobil gas). We have a Sunoco on the corner too with 94 octane but all my cars take 87 at the moment. Once I turbo the Miata I'll have it tuned on 94 doe.
Slow*Jim is offline   Reply With Quote
Old 07-30-2013, 12:26 PM   #53
Good, Bad…I'm the one with the gun
Ash J. Williams's Avatar
Location: Trapped in time, Surrounded by evil, Low on gas
from what i understand the additives are nothing more than some higher chain hydrocarbons and detergents. you can make your own and dump it into the cheapest gas you find. i put acetone into tanks from time to time to clean the cats.
Ash J. Williams is offline   Reply With Quote
Old 07-30-2013, 12:29 PM   #54
UA6 BALLER STATUS's Avatar
I put gas from any gas station but the octane thats recommended, I put 91 octane in my Acura TL and CBR1000RR and 87 octane in my dodge ram hemi and GSXR600, Arco is what I usually put, gas is gas
UA6 BALLER STATUS is offline   Reply With Quote
Old 07-30-2013, 12:35 PM   #55
clean rice's Avatar
Chevron and Texaco are the best in my area(NW).
My old turbo'd coupe would detonate on anything other than the two mentioned above. Granted this was in 99-00' when we didn't really know what engine management was, but it still speaks volumes for the quality of gasoline in the two.
*edit
Jealous of those that have anything higher than 92 at your pumps
clean rice is offline   Reply With Quote
Old 07-30-2013, 12:41 PM   #56
racebum's Avatar
Quote:
Originally Posted by solbrothers View Post
inb4 gas ruined my car
plot twist: it didn't
uh, no, actually it can
certain cars have fuel level sending units that are sensitive to sulfur levels in the gas. it's not uncommon to see fuel gauge problems in a car that runs on BP go away if the car is switched to chevron and giving a healthy 40oz shot of techron
racebum is offline   Reply With Quote
Old 07-30-2013, 12:48 PM   #57
eMpAtHy's Avatar
Quote:
Originally Posted by acmoc View Post
Costco here because that gas is probably the freshest
I use redline cleaner twice a year
i've been using costco gas when it is convenient for me because it ends up being significantly cheaper than tier 1 companies (25-30 cent difference) and still cheaper than Arco by about 12-15 cents per gallon once cash back rewards are factored in from credit card and you can't use CC at Arco.
80k miles on my 06 rsx-s and i sitll get 30.5 mpg when driving highway and 25 mpg for mixed driving.
I save about $3.75 per fill-up when compared to tier 1 companies and I fill up about once per week, so thats $195 per year. bamanotbad:
eMpAtHy is offline   Reply With Quote
Old 07-30-2013, 01:57 PM   #58
I really don't know
A D NOH's Avatar
BP has a gas station? You must not be from around here...
I use Chevron 91 in the weekend car and Costco 87 in the daily.
A D NOH is offline   Reply With Quote
Old 07-30-2013, 02:27 PM   #59
Keyboard Humorist
4drEF's Avatar
Quote:
The gas all comes from the same place.
What the various companies add to it is what makes it different.
Top Tier simply means that the company adds more detergents than what EPA requires.
Most every place mixes ethanol in their fuel now.
ARCO, cheap gas, states that their gas reduces fuel economy by 2~4%.
"Gas" is gas, but the crap they put in it makes them different.
I stopped using ARCO many moons ago when I got stranded after a rubber fuel line got eaten through.
Experimented with the more expensive brands and noticed smoother and more powerful running engine.
4drEF is offline   Reply With Quote
Old 07-30-2013, 02:29 PM   #60
I like to party
2LEM1's Avatar
Quote:
That's not exactly true. Chevron, Shell, 76, etc all come from the same place. Cheapo mom and pop stations do NOT get it from the same refineries.
I question Costco as well.
2LEM1 is offline   Reply With Quote
Old 07-30-2013, 03:07 PM   #61
eMpAtHy's Avatar
in CA, our summer blend only comes from refineries in CA because we're the only state that requires a cleaner burning blend during the summer months, so there is some merit when people say our gas comes from the same refineries.
Old 07-30-2013, 06:26 PM   #62
It Wasn't Me!
someone else's Avatar
Quote:
Arco is not as good a fuel. A large share of the low mileage catalytic converter and o2 sensor failures I see are in Arco gas cars. "where do you get your gas" is a question I've been asking for a long time and a lot of runability issues can be traced back to cheap fuel.
I've worked for two Japanese manufacturers for the past 11 years and both of them have idle issues with Costco fuel.
We've recently been seeing some problems with ethanol content in their fuel being a little higher than it should be as well.
someone else is offline   Reply With Quote
Old 07-30-2013, 06:28 PM   #63
racebum's Avatar
wrong again
do any of you guys actually know what goes into refining gasoline?
long story short the big difference that matters is sulfur content.
there are more than a couple reasons low sulfur gas is better to run
it's also one HELL of a lot harder to refine oil sands than it is saudi light sweet
Old 07-30-2013, 06:55 PM   #64
I took way too long
slowman's Avatar
Quote:
Originally Posted by racebum View Post
wrong again
So what'd better BP with Invigorate or Shell Vpower? Talking premium 93 here.
slowman is offline   Reply With Quote
Old 07-30-2013, 07:10 PM   #65
tw1tch's Avatar
Shell by a landslide. Shell is top tier and BP is not. I ran BP for 10 years straight until I found out about top tier. I will now only fill up with Shell 93 vpower. I can't notice a difference, but it gives me peace of mind.
tw1tch is offline   Reply With Quote
Old 07-30-2013, 07:24 PM   #66
racebum's Avatar
Quote:
this
read up on the top tier gas site and it explains what the few cents per gallon extra buy you
some vehicles also are more sensitive than others. my z06 for example has the worlds worst fuel sending unit. if you don't run top tier the sulfur content of cheap gas will scale the sending unit
Old 07-30-2013, 07:45 PM   #67
Topher.'s Avatar
Quote:
Originally Posted by FijiBlueFG2 View Post
I've found I get MUCH better fuel mileage with 91 w/ 0% ethanol than I do with 93 w/ 10% ethanol.
That's because ethanol has less energy per volume than gasoline.
I run a 50/50 blend of E-85 and 93
Topher. is offline   Reply With Quote
Old 07-30-2013, 08:28 PM   #68
Keyboard Humorist
4drEF's Avatar
wrong again
Yes, I know what goes into gas.
Do you know how it's manufactured?
All comes from the same place at the same time (we are talking TOP TIER).
Old 07-30-2013, 08:34 PM   #69
__oversea's Avatar
I use Shell by my house, because it's cheapest. Then I found Chevron by my work, it's cheaper, so I might start using them.
__oversea is online now   Reply With Quote
Old 07-31-2013, 08:26 AM   #70
It Wasn't Me!
Care to explain this? I know we have multiple refineries here in Washington owned by different companies so I guess I don't get what you are saying.
Old 07-31-2013, 08:29 AM   #71
Road House
ARCO, cheap gas, states that their gas reduces fuel economy by 2-4%
Depends on state I believe. NY/CT is usually 15% I believe...MA is 10%....Maine, NH, 0%, etc.
Old 07-31-2013, 09:17 AM   #72
del sol1658 is offline   Reply With Quote
Horrible fuel economy and knocking with BP gas furious94ls Honda Prelude 2 03-11-2014 08:28 AM
BP gas rubikscube General Discussion and Debate 27 06-01-2010 09:11 PM
Gas Preference's? Del Namco Solo Honda Civic / Del Sol (1992 - 2000) 56 01-03-2010 08:49 PM
bp gas McFlurry Honda CRX / EF Civic (1988 - 1991) 9 12-25-2009 01:52 PM
Here I am hat in hand concerning grades of gasoline mfisher1967 Honda Civic (2006 - 2015) 28 06-25-2007 06:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
