Teeth knocked a little loose...will they tighten up on their own? - Honda-Tech
Old 01-09-2009, 12:48 PM   #1
swifty4u's Avatar
Default Teeth knocked a little loose...will they tighten up on their own?
On new years i got into a little fight...and my front two bottom teeth are a little loose. I can move them barely with my hand...and they only moved a tiny bit from where they were supposed to be. It's been over a week and they still seem pretty much the same as when it happened. Will they tighten up by themselves or do I need to see a dentist. No insurance owns me right now..
swifty4u is offline   Reply With Quote
Old 01-09-2009, 12:52 PM   #2
H-T Poker champion
Hatchy-Ownzjo0's Avatar
Default Re: Teeth knocked a little loose...will they tighten up on their own?
Did you lose? Stop moving them-that will only make them more loose. I'd go see a dentist, or at least call the dentists office and ask about it.
Hatchy-Ownzjo0 is offline   Reply With Quote
Old 01-09-2009, 12:52 PM   #3
VitViper's Avatar
They should.
VitViper is offline   Reply With Quote
Old 01-09-2009, 12:54 PM   #4
Road House
FijiBlueFG2's Avatar
After I got my braces off my teeth were all sorts of loose. Just give it time.
FijiBlueFG2 is offline   Reply With Quote
Old 01-09-2009, 12:55 PM   #5
Durka durka
LT6916's Avatar
Eventually your gum tissue will expand back out to hold them in place nicely.
LT6916 is offline   Reply With Quote
Old 01-09-2009, 12:58 PM   #6
Superhatch's Avatar
I got in to a fight with some skinheads back in the day and there was a lot of people getting ****ed up on both sides.
I got my teeth knocked together and one of my lower canines was actually twisted almost 90 degrees out of place. I had it twisted back in to place (emergency Dentist with no novocaine!) and it came out just fine. But the dentist warned that the nerve could have been damaged to the point where it might die.
Either way...go see a dentist!
Superhatch is offline   Reply With Quote
Old 01-09-2009, 01:12 PM   #7
Banned
Lost Boyz's Avatar
JB Weld
Lost Boyz is offline   Reply With Quote
Old 01-09-2009, 01:13 PM   #8
Not now Chief, I'm in the F'n zone!
Code's Avatar
Quit blocking punches with your face, and stop wiggling them. They'll tighten up.
Code is offline   Reply With Quote
Old 01-09-2009, 01:15 PM   #9
Batpool
Yes they will. Just leave them alone.
SilentEdge is offline   Reply With Quote
Old 01-09-2009, 01:15 PM   #10
Εν Τούτω, Νίκα
Labarum's Avatar
Like others said, it'll get back to normal(ish) depending on the damage if you leave it alone. If you've left it alone for a few weeks and it hasn't changed at all, consider seeing a dentist, because something could be broken.
Labarum is offline   Reply With Quote
Old 01-09-2009, 01:17 PM   #11
ol'red's Avatar
yeah i got in accident one time and my teeth were all loose from hitting the steering wheel. i remember waking up and feeling them all loose and bent back a little and thinking they were all going to fall out. but couple days later they were back to normal.
ol'red is offline   Reply With Quote
Old 01-09-2009, 02:13 PM   #12
whiteDCfiver's Avatar
You'll be fine. I had some upper teeth knocked loose at a company xmas party gone bad. 3 weeks later theyre A OK.
whiteDCfiver is offline   Reply With Quote
Old 01-09-2009, 02:23 PM   #13
silvercivicgrl's Avatar
I'd go to the dentist to atleast have an exam. Something later on down the line can happen to teeth with trauma. It is called internal resorbtion. Bascially the tooth eats itself from the inside out.
silvercivicgrl is offline   Reply With Quote
Old 01-09-2009, 02:33 PM   #14
(teh)H2OUUP2's Avatar
Quote:
I'd listen to her, she knows what she is talking about. Most of the time they will heal, depending on the trauma, but will they heal correctly can only be determined by the doctor and what steps they take to make sure they do. I'd see a dentist immediately depending on the importance of those teeth. The dentist probably will have to mechanically splint them up to get to heal correctly, kind of like a cast for the teeth.
BTW Hi, ASHLEY RDH 4 LYFE....
(teh)H2OUUP2 is offline   Reply With Quote
Old 01-09-2009, 03:28 PM   #15
Flashmn's Avatar
I got hit in the mouth with the buttstock of an AK type rifle and man my teeth hurt a while, but they dont seem loose and they didnt seem loose at the time. However, I get this weird feeling every now and then, I bet they're gonna fall out... if they do, its time to get some front teeth made out of stainless steel gotta have a grill ;D
Flashmn is offline   Reply With Quote
Old 01-09-2009, 03:40 PM   #16
Radim's Avatar
Have them made out of cyanide instead.
Radim is offline   Reply With Quote
turn engine wrong way a little okay? sgull Honda Accord (1990 - 2002) 7 07-07-2013 07:59 PM
quick question on timing belt job, tdc, locking on tdc? clindberg86 Honda Civic / Del Sol (1992 - 2000) 7 05-21-2013 05:40 AM
Blown head gasket nicknack25 Honda CRX / EF Civic (1988 - 1991) 15 10-26-2010 09:16 PM
E brake novvti Honda Civic / Del Sol (1992 - 2000) 1 03-27-2006 12:18 PM
Tightened Timing belt and car hesitates some and other Qs... blufke Tech / Misc 17 03-07-2003 12:39 PM
Tags
back, dentistry, fall, front, heal, jb, knocked, long, loose, moved, teeth, tighten, tooth, trauma, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
