Speedfan Q: What is "remote temperature"? - Honda-Tech
Old 12-14-2006, 07:12 PM   #1
FalkenSiR's Avatar
Default Speedfan Q: What is "remote temperature"?
I run speedfan in one of my computers and one of the measurements it senses is "remote temperature"
What is that? because it's always overheating. The little flame icon is next to it while local temp and my 2 hd's have a green check mark, indicating that their temperature is fine.
FalkenSiR is offline   Reply With Quote
Old 12-16-2006, 10:36 PM   #2
R.I.P.
hapexamendios 2.0's Avatar
Default Re: Speedfan Q: What is "remote temperature"? (J.MONEY)
on my brand new system Speedfan and another app read my CPU temp at 71 degrees all the time (which is way fawking hot) but its actually at 31-32 according to the BIOS... if that helps
hapexamendios 2.0 is offline   Reply With Quote
Old 12-17-2006, 01:39 AM   #3
FalkenSiR's Avatar
Default Re: Speedfan Q: What is "remote temperature"? (honda 3300)
Ok, I was doing some searching on some boards and I think I got the temp issue under control. However, both my HD's are "in flames" My 250 gb brand new hd is at like 98% just idling (scary) and the other one (old- 30 gb) around 80% temp
Why is this? is the case too small? its a micro ATX I think. The comp is a hp pavillion 531w.
How do I go about adding a fan? I couldn't find any info on it. How do I know what fits my computer and what size should I get?
Old 12-17-2006, 01:44 AM   #4
H-T White Ops
Frozen E's Avatar
Rig up some kind of a fan setup on those hard drives. Those suckers spin at 5400-10,000 RPM. Heat is their enemy. I have 4 hard drives in my computer and they stay at about room temperature because I have a big *** 120mm fan sucking air across them all the time. Cheap insurance that will more than likely extend the life of your drives.
A $5 fan might keep your priceless data safe.
Frozen E is online now   Reply With Quote
Old 12-17-2006, 01:47 AM   #5
H-T White Ops
Frozen E's Avatar
Here's my fan setup. The black plastic is a piece of a DVD case I cut out to make sure that the air being sucked over the hard drives is coming from outside the case, and not just recirculated air from inside the case that's a hell of a lot warmer than my room. Works like a charm
With the air diverter in place
"Air diverter" off
Old 12-24-2006, 05:05 AM   #6
uNF$@#!'s Avatar
Default Re: (IslandSi)
the antec sonata is a sucky case to be overclocking with anyhow...
the vent in front is useless.....
uNF$@#! is offline   Reply With Quote
Old 12-24-2006, 10:27 AM   #7
H-T White Ops
Frozen E's Avatar
Default Re: (uNF$@#!)
Uhmm, how do you figure? The "vent" in the front s an air inlet. The big *** 120 in the back has to pull air from somewhere. Works out great. As the exhaust fan is pulling air out of the case, the air coming into the case is getting pulled over the hard drives, cooling them down as well.
Cold air comes in the bottom, over the hard drives, padded the CPU heat sink and out the back. Doesn't really get any more efficient than that if you ask me.
what is the normal temperature of GSR motor (94-95) Gsrftw17 Acura Integra 7 01-21-2011 03:04 PM
temperature gauge 92_BlackSi Honda Civic / Del Sol (1992 - 2000) 3 09-16-2009 05:25 PM
Outside Temperature Display Stoplight Honda Civic (2006 - 2015) 19 04-13-2007 09:06 AM
VALET alarm remotes TWO WAY PAGER REMOTE and BACKUP GFurm For Sale 6 11-23-2006 03:20 PM
Temperature volkracing99 Tech / Misc 5 10-14-2001 10:57 PM
Tags
128c, bios, computer, fan, flame, pc, remote, speed, speedfan, sppedfan, temp, temperature, viewer, what, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
