sliced my finger. 3 days pass and still bleeds like no tommorow. - Honda-Tech
Old 07-02-2002, 02:23 AM   #1
uNF$@#!'s Avatar
Default sliced my finger. 3 days pass and still bleeds like no tommorow.
well,
i sliced my finger on a piece of sharp metal, and the cut is very thin but deep. (about 3 mm) into my index finger. ... on my fingerprint.
the wound keeps reopening and i've been bleeding all over the place. While not fatal, seeing all this blood is just bothering. my mouse just got a shower in blood.
to give you an idea of how much blood is coming out, its just a stream of blood when the wound is open. i can fill a tablespoon of blood in 9 seconds. (tested)
my bedsheets, are bloody... it looks like a gunshot victim decided to sleep on my bed.
i actually may need stitches . sucks to not have medical insurance... god damn it my keyboard is bloody now.
[Modified by Soup ****, 5:25 AM 7/2/2002]
uNF$@#! is offline   Reply With Quote
Old 07-02-2002, 02:31 AM   #2
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (Soup ****)
Thats shitty, funny for us shitty for you
Rob
rjardy is offline   Reply With Quote
Old 07-02-2002, 02:39 AM   #3
Kamin's Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (rjardy)
go to a doctor
if it bleeds for more than 45 minuets you have a problem.
Kamin is offline   Reply With Quote
Old 07-02-2002, 02:45 AM   #4
Kengs's Avatar
If you want to try an interim measure, go to an Asian (preferably Chinese) medicinal/herb shop and ask for something called YUNNAN BAIYAO ("Yunnan White Medicine"). It's a powder made from botanical extracts, it will help to close the wound, promote healing and prevent infection. I've used it before
BTW, this stuff is what the Chinese People's Liberation Army STILL uses to treat gunshot/shrapnel wounds in the field...
Just remember to cleanse your wound with something like Betadine soap, then pat dry before applying the powder. Change your dressings frequently.
Kengs is offline   Reply With Quote
Old 07-02-2002, 02:47 AM   #5
FusionITR's Avatar
good thing it isnt me
FusionITR is offline   Reply With Quote
Old 07-02-2002, 05:00 AM   #6
Luke's Avatar
If you dont want to bother with the 'quack' then get an old toothbrush and cut it to make a splint. Thoroughly clean the wound with antisceptic before cutting strips of plaster (fabric not plastic) and laying accross the cut. Use three of four about 1/8" wide. Then put the 'splint' under your finger and using more strips attach to your finger. Apply a general dressing when you go to bed so that it doesnt snag. With the 'splint' in place the cut should be less likely to open up.
Luke is offline   Reply With Quote
Old 07-02-2002, 05:18 AM   #7
Apocalypse's Avatar
If more than 12 hours has passed since you cut it they will not stitch for fear of infection. The best you can do is bathe the thing in hydrogen peroxide twice a day and keep one of those butterfly bandages on it. It's the kind that looks like the breathing strips athletes wear on their nose.
Apocalypse is offline   Reply With Quote
Old 07-02-2002, 06:05 AM   #8
DragII's Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (Freek24)
ya mang you need stitches....get a needle and do it yourself
DragII is offline   Reply With Quote
Old 07-02-2002, 06:14 AM   #9
ryanstev's Avatar
Are you crazy? After 3 days you still haven't done anything?
ryanstev is offline   Reply With Quote
Old 07-02-2002, 06:17 AM   #10
Collector-o-Guns and Drinker
Splat's Avatar
Yep. You keep opening the wound before it can heal sufficiently. Finger cuts generally heal slowly because of the constant flexing. In addition to the butterfly bandages to keep the wound closed, you need to immobilize it. Use the toothbrush idea or a popsicle stick to splint it.
Splat is offline   Reply With Quote
Old 07-02-2002, 06:17 AM   #11
New User
Drew M's Avatar
You need to imobilize the laceration. Get a popsicle stick or pencil or something and tape it to your finger. Every time you bend your finger it pulls on the skin which opens it back up. It won't fuse back together until it has had a good 2-3 days of no movement.
You could also cut your whole hand off just above the wrist.
Drew M is offline   Reply With Quote
Old 07-02-2002, 06:20 AM   #12
98DC2's Avatar
dude....go to the doctor. i'm sure somebody's willing ti help you out. get that **** stiched up
98DC2 is offline   Reply With Quote
Old 07-02-2002, 06:22 AM   #13
New User
John's Avatar
Do you have a lot plate count in your blood? It sounds like your blood isn't coagulating at the laceration like it should. But as mentioned above, you need to immobilize the laceration.
John is offline   Reply With Quote
Old 07-02-2002, 07:02 AM   #14
HT White Ops
PapaPark's Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (DunReit)
buwhwhahahahahahahahahahahahahahahahah
that's good stuff man
PapaPark is offline   Reply With Quote
Old 07-02-2002, 07:08 AM   #15
CRXRageD's Avatar
I'm suprised you're not dead yet. You've been bleeding like that for 3 days. You may have to amputate it. I know I'm a doctor, I play one on TV. jk Yeah I'd go to see someone in the medical field about that.
CRXRageD is offline   Reply With Quote
Old 07-02-2002, 07:13 AM   #16
FyrFytr's Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (CRXRageD)
Get the "Second Skin" bandage.
Should help.
FyrFytr is offline   Reply With Quote
Old 07-02-2002, 07:19 AM   #17
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (White98TypeR)
If you don't have insurance maybe there is a local clinic that you can walk into and get stitches at a reasonable price? I know a while back a I took my friend to a local clinic because he had pink eye and would not go to the doctor due to the fact he had no insurance. We went in and he got a doctors exam and medication for like $30 or so.
HTH
M
01ITR#700 is offline   Reply With Quote
Old 07-02-2002, 11:14 AM   #18
uNF$@#!'s Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (DragIIDigital)
haha! yeah, i did stitch myself! I threw my finger in ice cold water for 10 minutes and began to stitch with needle and thread. total 5 stitches. still very painful
thanks all for advice but seeing a doctor would have ran a good 1000 dollars or so just for the stitching im sure
...by the way, blood still kind of seeps thru even with the tight stitching i done. okok, im not using ,my index finger again fora while. im going to find that spray that acts like a second skin.
Old 07-02-2002, 11:21 AM   #19
JG Luder's Avatar
duct tape.
JG Luder is offline   Reply With Quote
Old 07-02-2002, 11:23 AM   #20
SoulSurfer's Avatar
Quote:
well,
i sliced my finger on a piece of sharp metal, and the cut is very thin but deep. (about 3 mm) into my index finger...the wound keeps reopening and i've been bleeding all over the place.
Maybe it would quit bleeding if you quit shoving a ruler in there to measure the depth.
[Modified by LSDelSol, 4:24 AM 7/3/2002]
SoulSurfer is offline   Reply With Quote
Old 07-02-2002, 11:26 AM   #21
You can do it
Krow is offline   Reply With Quote
Old 07-02-2002, 11:28 AM   #22
JL 74's Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (Krow)
Stitches are what you need.
If it it not too deep, cuts should normally close/heal in a matter of hours unless your immune system is severely weakened.
JL 74 is offline   Reply With Quote
Old 07-02-2002, 11:33 AM   #23
New User
WuShu's Avatar
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (Todd 94)
crazy glue, i know it sounds crazy and it may be really really bad for you but, i know some gymnasts and some of my martial arts buddies including me have done this. when you have a cut thats fresh and it keeps opening up when using weapons or like when gymnasts use the bars. slap some crazy glue on it, keeps it closed and stops it from being irritive(dont think thats a word) but if i were you id go get a doctor to see it, that cut sounds deep.
WuShu is offline   Reply With Quote
Old 07-02-2002, 06:51 PM   #24
New User
Default Re: sliced my finger. 3 days pass and still bleeds like no tommorow. (HondaCRX)
Actually guess what super glue / crazy glue was invented for... to close wounds! I had this suggested by a friend who is a fire fighter and I've tried it several times. Works great, wears off in a few days after the wound has had time to close on its own.
dbman96 is offline   Reply With Quote
OT: To thieves and scammers uNF$@#! Acura Integra Type-R 27 08-15-2002 04:38 PM
Honda Stuff, New & Used The Mole For Sale 24 07-06-2002 12:45 AM
b2finity's transformation uNF$@#! General Discussion and Debate 8 07-01-2002 11:55 PM
FS: Kosei K1's, LS rims, and Tanabe G-medallion. Morphious For Sale 4 07-01-2002 09:35 AM
Just got back from the doctor. Shitty stuff abraunworth General Discussion and Debate 8 05-13-2002 02:32 PM
Tags
back, bleeding, cut, deep, dont, finger, fingertip, fuse, hours, insurance, metal, off, opening, piece, sliced, stitches
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
