Question about Seafoam engine treatment - Honda-Tech
Old 07-27-2012, 03:22 PM   #1
NSXRguy's Avatar
Default Question about Seafoam engine treatment
Ive used seafoam on all my cars so i know all about how to actually "suck" it into the engine.
My question is how much is too much?
I have a supercharger on my c32b and used one of the vacuum lines on te side towards the firewall. Fed about 1/2 the can into it. I thought it was a bit weird that only one my muffler outlets was smoking. Didnt mind it much because during winter time, only that side would smoke also. It did the whole smoking of the highway thing.
Today, i was bored so i sprayed seafoam blaster in the vacuum ports and cleaned out my tb as well as i could. This time, i used a dofferent vacuum line, which would be more center on the supercharger. The car immediately started smoking white, but this time both exhaust outlets smoked. I can even say i polluted the environment more this time than last. Cars actually stayed behind me more. I also have test pipes.
So now the question. If you seafoam a very clean engine with very little carbon buildup, will it still smoke? Is the smoke due to the seafoam mostly? Or carbon mostly?
And how frequent is too frequent? I want to seafoam it until i have no smoke, but i dont want to ruin the motor and possibly ruin my rings or walls. Thanks!!
NSXRguy is offline   Reply With Quote
Old 07-27-2012, 03:26 PM   #2
Solbros Owns Me
Evs-One's Avatar
Default Re: Question about Seafoam engine treatment
Seafoam will leave you with a lot of smoke, even when the deposits are cleared.
Some others, like Amsoil Power Foam, will stop smoking once the carbon build ups are cleared.
Evs-One is offline   Reply With Quote
Old 07-27-2012, 03:28 PM   #3
__oversea's Avatar
seafoam will bring every fire departments in your city.
__oversea is offline   Reply With Quote
Old 07-27-2012, 03:29 PM   #4
R.I.P.
hapexamendios 2.0's Avatar
In my experience it smokes less the "cleaner" the engine is..
hapexamendios 2.0 is offline   Reply With Quote
Old 07-27-2012, 03:29 PM   #5
bigdent's Avatar
I heard every 10-20k miles for the de carb interval
bigdent is offline   Reply With Quote
Old 07-27-2012, 03:32 PM   #6
Builda'Teg_92's Avatar
boy is seafoam fun lol
Builda'Teg_92 is offline   Reply With Quote
Old 07-27-2012, 03:36 PM   #7
Solbros Owns Me
Evs-One's Avatar
Quote:
Originally Posted by rota92 View Post
I find it works best if you remove the spark plugs and flush out the carbon in the cylinders with it. Definitely smokes on startup but it goes away when the motor stops running.
I've actually gained 20-30 psi compression in an engine by removing the plugs and allowing sea foam to soak in overnight on top of the piston/rings.
Old 07-27-2012, 03:38 PM   #8
im hench irl
skateboard_ej8's Avatar
Ahh, i could never get myself to do this sea foam thing to any engine.
skateboard_ej8 is offline   Reply With Quote
Old 07-27-2012, 03:45 PM   #9
Master Detailer
98civdx's Avatar
I do not trust putting **** like that anywhere near a motor lol
This. I almost did but I was too
98civdx is online now   Reply With Quote
Old 07-27-2012, 04:13 PM   #10
MonkeyMagic's Avatar
+1
reminds me of that "stop smoke" ****.. like, hey *******, if you need something like that, you just need a new engine.
...and don't go 20,000 miles between oil changes this time.
MonkeyMagic is offline   Reply With Quote
Old 07-27-2012, 04:15 PM   #11
SHAME ON YOU REBECCA!
kidcool1977's Avatar
Is it true doing it to often will kill the engine?.
kidcool1977 is offline   Reply With Quote
Old 07-27-2012, 04:51 PM   #12
slowly blowing brothers
solbrothers's Avatar
lets talk about this. i want to do it to teggy but fear it will make it worse
solbrothers is offline   Reply With Quote
Old 07-27-2012, 05:02 PM   #13
El Chico
Knightsport's Avatar
Might remove all your rusts.
Knightsport is online now   Reply With Quote
Old 07-27-2012, 05:04 PM   #14
:fckthat:
Old 07-27-2012, 05:05 PM   #15
ritalin.v2's Avatar
My engines must be remotely clean. Hardly see any smoke at all.
ritalin.v2 is offline   Reply With Quote
Old 07-27-2012, 05:14 PM   #16
NSXRguy's Avatar
I just seafoamed my dads 90k mile camry... Smoked like crazy which is good. Probably fed about 1/2 the can into it.
My dad wants to do it again hoping to get rid of more of the carbon. This is why i want to know if the smoke is due to the seafoam or more th carbon buildup
Old 07-27-2012, 05:29 PM   #17
GDD Member
slomofo's Avatar
Sea foam is petroleum based, do you think the smoke is caused by anything other than the seafoam? The smoke you see is almost entirely sea foam.
slomofo is offline   Reply With Quote
Old 07-27-2012, 05:36 PM   #18
90_EX_Civic's Avatar
inb4xtrac
90_EX_Civic is offline   Reply With Quote
Old 07-27-2012, 05:36 PM   #19
A.C. Slater's Avatar
1000 times this, especially in an NSX out of all cars
wood try in an old pos ford escort
inb4 ppl saying
I PUT SEAFOMEZ IN MY b16 AND GAINED 6WHP
A.C. Slater is offline   Reply With Quote
Old 07-27-2012, 05:45 PM   #20
inb4 ppl saying
does not commute
Old 07-27-2012, 05:49 PM   #21
Touching My Member
.Manny.'s Avatar
Why get rid of that sweet compression raising carbon?? Lose horsepowers. no thx
.Manny. is online now   Reply With Quote
Questions About SeaFoam, 2001 Odyssey LilThnikkaMan Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 1 08-16-2012 09:38 PM
GUARANTEED way to increase your horsepower in 10 minutes!... Seafoam drumminforev Honda Civic / Del Sol (1992 - 2000) 286 07-01-2012 05:01 PM
seafoam help ray559527 Honda Civic / Del Sol (1992 - 2000) 24 11-13-2011 02:53 AM
Seafoam to clean main manifold tt3 Honda Accord (1990 - 2002) 3 10-29-2010 02:35 PM
Seafoam Question dleccord Honda Accord (1990 - 2002) 10 03-31-2008 07:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
