prestone antifreeze, do you use it? - Honda-Tech
Old 11-16-2007, 10:12 PM   #1
__oversea's Avatar
Default prestone antifreeze, do you use it?
__oversea is online now   Reply With Quote
Old 11-16-2007, 10:13 PM   #2
Lan
Lan's Avatar
Default Re: prestone antifreeze, do you use it? (Seungho.K)
Honestly dude, to me, coolant is coolant.
Lan is offline   Reply With Quote
Old 11-16-2007, 10:13 PM   #3
* B A N N E D *
Default Re: prestone antifreeze, do you use it? (Lan)
if you live were there temp dont get below freezing use WATER.
Guiding my way back. is offline   Reply With Quote
Old 11-16-2007, 10:14 PM   #4
Lan
Lan's Avatar
Default Re: prestone antifreeze, do you use it? (Guiding my way back.)
Quote:
And water wetter
Old 11-16-2007, 10:15 PM   #5
* B A N N E D *
Quote:
Originally Posted by Lan
And water wetter
TRUE TRUE !!!!! this guy is like jesus's or something....
Old 11-16-2007, 10:16 PM   #6
Lan
Lan's Avatar
LOL
Old 11-16-2007, 10:19 PM   #7
H-T White Ops
Frozen E's Avatar
Prestone has been around forever. I think they know what they're doing. So I use their stuff all the time.
Frozen E is offline   Reply With Quote
Old 11-16-2007, 10:25 PM   #8
It Wasn't Me!
someone else's Avatar
Default Re: (IslandSi)
I use Factory coolant it makes me feel like I'm running Powerade Mountain Blast in my cooling system. And that cools me down on a hot day.
someone else is offline   Reply With Quote
Old 11-16-2007, 11:27 PM   #9
Desired_Speeds's Avatar
prestone, its cheap at walmart, whatever
Desired_Speeds is offline   Reply With Quote
Old 11-17-2007, 02:29 AM   #10
JohnD1079's Avatar
Default Re: (Desired_Speeds)
wat about peak?
JohnD1079 is offline   Reply With Quote
Old 11-17-2007, 02:32 AM   #11
ate my pixel
Twixle's Avatar
Default Re: (JohnD1079)
Why use 50/50? It's like half as much if you just buy antifreeze and dilute it yourself. however, it's better for your cooling system if you use distilled water, this prevents corrosion from minerals in regular tap water. Lord knows what prestone mixes in their 50/50, but I'd bet it's not distilled water.
Twixle is offline   Reply With Quote
Old 11-17-2007, 06:06 AM   #12
EG2Driver's Avatar
Unless you drive a dumb VW and have to buy THEIR G12 coolant @ 30 bucks a gallon. GRRRRRRr
OP, prestone is fine, its what these cars all run on.
EG2Driver is offline   Reply With Quote
Old 11-17-2007, 09:27 AM   #13
BigMoose's Avatar
...coolant is not coolant...
I have posted on this numerous times, here is a start:
http://honda-tech.com/zerothread?id=1794754
BigMoose is offline   Reply With Quote
Old 11-17-2007, 10:58 AM   #14
hayabusa160's Avatar
Default Re: prestone antifreeze, do you use it? (BigMoose)
just dont mix the dex cool red **** with regular coolent lol.
happen to my friend wasnt fun.
hayabusa160 is offline   Reply With Quote
Old 11-17-2007, 11:07 AM   #15
Default Re: prestone antifreeze, do you use it? (hayabusa160)
shiet what happened
Old 11-17-2007, 02:41 PM   #16
blah13's Avatar
Default Re: (Twixle)
Dont run just water in your system. You need some sort of lubricator/rust inhibitor. If your temps don't get down very low run around a 20/80 or 30-70 mix. Or the water wetter as mentioned. Anti-freeze doesnt just prevent teh freeze. And fyi I run prestone in all my vehicles except my bike.
blah13 is offline   Reply With Quote
Old 11-17-2007, 02:47 PM   #17
inh
inh's Avatar
if you run just water, your **** will corrode. i've seen one too many generators (albeit with iron blocks) that rust and then clog the radiator. no amount of flushign will fix it)
inh is offline   Reply With Quote
Old 11-18-2007, 12:50 PM   #18
Default Re: prestone antifreeze, do you use it? (Desired_Speeds)
Quote:
Originally Posted by Desired_Speeds
shiet what happened
it coagulates clump up.
it also smells horrible.
Old 11-18-2007, 01:01 PM   #19
Lan
Lan's Avatar
Default Re: (inh)
Water + water wetter will not rust your internals and it runs a lot cooler than antifreeze. If you live in a cold *** area use antifreeze.
Old 11-18-2007, 01:34 PM   #20
Righteous Fire's Avatar
Default Re: (Lan)
Its not just antifreeze, its COOLANT.
The 50/50 mixture raises the boiling point of the entire mixture to a safer level than water alone.
If honda intended for us to use water in a honda, they would say so.
Just use green coolant, or the honda type 2 (blue stuff). I use the blue personally because I like to stick with OEM.
True story.
Its also horrible for you car unless you drive a GM product.
Righteous Fire is offline   Reply With Quote
Old 11-18-2007, 01:39 PM   #21
Lan
Lan's Avatar
Default Re: (Righteous Fire)
Water + water wetter runs cooler than COOLANT and it's safe. Ask me how I know.
Old 11-18-2007, 03:43 PM   #22
bmoua's Avatar
i use honda coolant...
bmoua is offline   Reply With Quote
Old 11-18-2007, 03:52 PM   #23
outofstock's Avatar
Default Re: (bmoua)
I used whichever tastes better....
outofstock is offline   Reply With Quote
Old 11-18-2007, 03:59 PM   #24
GoodClothes's Avatar
Default Re: (Lan)
how do you know?
i use prestone cause it's cheap and at walmart so fug it.
GoodClothes is offline   Reply With Quote
Old 11-18-2007, 04:16 PM   #25
Tizight's Avatar
I just put some in my car a hour ago.
Tizight is offline   Reply With Quote
Delete OmarR For Sale 0 02-09-2016 07:16 AM
AZ ... OneSlowEkHatch Vehicles for sale 0 10-16-2015 07:09 AM
------------------------ thaijdmpart For Sale 0 11-20-2014 12:37 AM
civic trade battmancjz Southern California (Sales) 15 03-06-2014 10:41 AM
WOW!!!!!! Newborn_ Acura NSX 3 06-17-2006 12:31 PM
Tags
1000rr, 2003, 2007, 2008, 2080, 5050, accord, anti, antifreeze, cbr, coolant, dexcool, freezeand, honda, odessey, peak, point, prestone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
