Official Home Improvement - Page 271 - Honda-Tech
Old 03-20-2017, 04:44 AM   #6751
Parties with 2LEM1
Brice.Hayden's Avatar
Default Re: Official Home Improvement
Quote:
Originally Posted by 4drEF View Post
Injust want to know what lives in the open space on the left side.
the contractors shoved their trash between the walls. Lazy bums.
Brice.Hayden is offline   Reply With Quote
Old 03-20-2017, 07:07 AM   #6752
White Trash Wish Cash
rino924's Avatar
Wired the lighting in my storage room this weekend. Also measured and mounted all the recessed LED lighting in my laundry room. Will get all of that wired this week.
rino924 is online now   Reply With Quote
Old 03-20-2017, 09:05 AM   #6753
rockcity's Avatar
Adding photocells to a bunch of outdoor lights today. Beautiful day for this stuff.
rockcity is online now   Reply With Quote
Old 03-20-2017, 12:19 PM   #6754
rockcity's Avatar
Yay.
Old 03-20-2017, 12:31 PM   #6755
Bloody Beaver
.Beaver's Avatar
I started using the rubber toilet seals, haven't looked back. Sooo nice.
.Beaver is online now   Reply With Quote
Old 03-20-2017, 12:33 PM   #6756
INSERT TITLE HERE
newt2's Avatar
I've got two new toilets to install next weekend also. Have to replace the shut off valves too. After 15 years they won't completely turn off as I found out last weekend when I tried to install one and wound up with water all over the floor.
newt2 is online now   Reply With Quote
Old 03-20-2017, 12:34 PM   #6757
something gnarly
5SpdH22's Avatar
I was going to try those rubber ones but my new toilet came with a wax ring. My other toilet drain is like 4x5 and needs an oval one so I had to make one myself out of 2 round wax rings. Sucks.
5SpdH22 is online now   Reply With Quote
Old 03-20-2017, 12:40 PM   #6758
rockcity's Avatar
This is for a client. He's a cheap wealthy bastsrd. Just left after installing it. I don't remember the brand, but I used a big rubber one with a compression fitting on our downstairs bath.
Old 03-20-2017, 12:43 PM   #6759
rockcity's Avatar
However, the master plumber that I hire for all of my big jobs always tells me not to use the rubber ones because the chlorine in the water will **** it up. I don't know of that's true or not, but I always let him use whatever he wants since he warranties all of his work.
Old 03-20-2017, 01:38 PM   #6760
HT Order of Merit
JDM_Ej's Avatar
Pulled off the hardibacker from my bath/shower wall again. The tub and walls are all crooked as **** so I used some 5 gallon paint stirrers as furring strips and spaced it out and leveled it as much as I could. So the wall opposite of the shower itself will be stepped out about 1/4" more than the other wall.... so that will look weird but with a shower curtain I doubt anyone will notice except me.
JDM_Ej is offline   Reply With Quote
Old 03-20-2017, 02:10 PM   #6761
rockcity's Avatar
Quote:
If you're interested in trying a different approach, you could probably get it damn near perfect using a cheap block plane, some string line, and a couple of new 2"x4"s. This may not work at all in your scenario since I haven't seen it, but if the studs aren't playing well, I use the longest level I can use for the space and a combo square to find the two studs that are closest to the plane that I want. Then run a few string lines at different heights and mark the high spots with a pencil. Then make them level with the block plane. For the studs that may be too far back altogether, I'll just pop a new one in right next to it on the same plane as the others.
Old 03-20-2017, 02:14 PM   #6762
Bloody Beaver
.Beaver's Avatar
Quote:
not a bad point, but am on a well so no worries.
Old 03-20-2017, 03:10 PM   #6763
HT Order of Merit
JDM_Ej's Avatar
Honestly if the tub was not "installed" already I would, but for now I'm just going to space and level the walls as much as possible. That is a good technique though.
Old 03-20-2017, 04:34 PM   #6764
rockcity's Avatar
Made a simple storage space for my MIL's house. I'm going to add two more shelves once she determines the height she wants them.
Old 03-20-2017, 04:36 PM   #6765
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Deng love that weathered look.
Samurai carpenter made that awesome dust collector cabinet recently. Dude is talented as ****
Setsuna F Seiei is online now   Reply With Quote
Old 03-20-2017, 04:38 PM   #6766
rockcity's Avatar
He's pretty legit. He and Jimmy Diresta (the GOAT) are the only two people I really really pay attention to on YouTube.
Old 03-21-2017, 05:59 PM   #6767
-Intl Steve Krew
Caoboy's Avatar
Is there a minimum requirement/guideline for how much would should be below the foundation of the house?
I see anywhere from 2-12 inches on the interwebs. Right now I have like zero.
Plan is to dig a baseline from the bottom of the stucco to the recommended depth and then grade that away from the house, in preparation for either relaying the pavers or laying cement.
Caoboy is offline   Reply With Quote
Old 03-21-2017, 07:48 PM   #6768
tony_2018's Avatar
Is your house, really a house? Or a condo?
tony_2018 is offline   Reply With Quote
Old 03-21-2017, 07:57 PM   #6769
-Intl Steve Krew
Caoboy's Avatar
Quote:
its a house.
http://www.investopedia.com/terms/z/zero-lot-line-house.asp
Old 03-22-2017, 04:10 AM   #6770
tony_2018's Avatar
So, its a step up from a Condo. I would keep it below the stucco, or below that fence line. I mean, you have to dig it up to lay down your new foundation or paver anyways.
Old 03-22-2017, 06:16 AM   #6771
Keyboard Humorist
4drEF's Avatar
I would think the reasoning is to keep ground moisture away from the exterior wall. If there is ever heavy rainfall or standing water, wall isn't much of a barrier.
4drEF is online now   Reply With Quote
Old 03-22-2017, 06:29 AM   #6772
tony_2018's Avatar
Yeah, specially when your tiny space starts pooling and has no where to exit.
Old 03-22-2017, 06:41 AM   #6773
at the jetties fishin'
stackz's Avatar
are you having any adverse issues with the house or you just dont like how the dirt is so close to the stucco compared to what looks like the brick foundation?
stackz is offline   Reply With Quote
Old 03-22-2017, 07:00 AM   #6774
aka DaZman69!
granted I'm not familiar at all with building codes in CA, or a lot of recommended practices in a climate like CA, but I'm pretty sure what really sucks is that your foundation is at or below grade.
The foundation should be above grade, and the stucco should overlap the foundation but not go below grade.
Are you sure your foundation ends there? If you're not and you have a basement or crawl space you could probanly figure out how high it is.
Do you have a wood framed house? Would be messed up if the bottom plate of your framing is below grade
sflkgjsfndgn is online now   Reply With Quote
Old 03-22-2017, 05:00 PM   #6775
-Intl Steve Krew
Caoboy's Avatar
Cement slab foundation, no basement or crawl space.
I was thinking that even something like 6 inches below the stucco will suffice, then grade away from the house and towards the front fence.
@tony, I have two outdoor spaces on my property, the atrium, and the backyard. The atrium obviously has no area to drain away water as it's completely enclosed.
The backyard is a different issue, yet somewhat easily rectified.
Don't worry doe, the next house will come with some landscapers and butlers
Introduction jeff@chaotic Introduce Yourself 0 03-15-2017 08:49 AM
Better for house resale - full hardwoods or carpet in bedrooms? Splat General Discussion and Debate 46 09-21-2016 08:24 PM
improving handling SeanK325 Honda Civic / Del Sol (1992 - 2000) 25 07-08-2010 01:31 PM
Extremely low Gas mileage :( kingpen Honda Civic / Del Sol (1992 - 2000) 9 08-31-2002 09:27 PM
Truechoice suspension packages? xMetal Acura Integra Type-R 9 08-17-2001 03:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
