New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter? - Honda-Tech
Old 03-20-2006, 12:44 PM   #1
T-RO's Avatar
Default New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter?
I just swapped power supplys on my computer (went from 200 to 500).
The OLD PS plugged into the motherboard with a 20pin connector (MB has a 20 pin slot on it).
The NEW PS has a 24 pin connector on it. I plugged the 24 into the MB's 20 pin slot and it powered up and is running.
Question
1) Does it matter that the remaining 4 pins are not connected?
2) Is there an adapter that will make the MB's 20 pin slot a 24 pin slot?
Thanks...
T-RO is offline   Reply With Quote
Old 03-20-2006, 01:44 PM   #2
loki2323's Avatar
Default Re: New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter? (T-RO)
What kind of psu do you have?
I know on mine that the last 4 pins break apart from the clip. I'd assume that the first 20 pins have to be the same. I mean the only difference is that on mine they snap apart from the clip, and on yours they might not.
Only issue I could really think of is that the psu clip might not line up and snap down on the motherboard clip. But it should stay in place regardless
loki2323 is offline   Reply With Quote
Old 03-20-2006, 02:31 PM   #3
EE_Chris's Avatar
It's just the difference between revisions of connectors. Newer mobo's need some extra juice but the 20 pin part of the 24 that plugs into your mobo is compatible, so no worries there.
EE_Chris is offline   Reply With Quote
Old 03-20-2006, 02:38 PM   #4
Slow*Jim's Avatar
Default Re: New power supply. 20 pin VS 24 pin connector. Adapter needed? Does it matter? (EE_Chris)
a lot of the higher-end motherboards require a 24-pin native connection.
Slow*Jim is offline   Reply With Quote
Old 03-20-2006, 04:36 PM   #5
T-RO's Avatar
ok cool. Yeah if i line it up then 20 of the 24 pins plug right in and snap in place. I just wanted to make sure it wasnt gonna cause some issues
Old 03-20-2006, 04:49 PM   #6
HT Black Ops
Ishouldbebanned's Avatar
Default Re: (T-RO)
I just got a new PSU too and I had the same thing happen. I have a 20 pin MB, so when I opened up the box and saw it was a 24 pin connector and thought "Oh ****, will this work?" I was afraid my system was going to get fried somehow.
Ishouldbebanned is offline   Reply With Quote
obd2b dizzy wiring RocHatchDX Honda Civic / Del Sol (1992 - 2000) 3 05-26-2014 01:27 PM
2007 Fit M/T Remote start install tleatham Audio / Security / Video 14 06-28-2012 02:49 AM
datalogging in cn2 xander1100 Engine Management and Tuning 1 07-12-2009 02:15 PM
Power supply issues. Stroker General Discussion and Debate 16 04-18-2006 05:37 PM
OEM "style" Foglight Wiring Harness Problem pmendoza Honda Civic / Del Sol (1992 - 2000) 2 03-31-2006 05:21 AM
Tags
20, 20pin, 24, 24pin, adapter, connectors, convert, diffrence, mbs, pin, power, ro, snap, supply, vs24, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
