my nose won't stop bleeding :( - Honda-Tech
Old 03-01-2004, 08:13 AM   #1
lke2drvgsr's Avatar
Default my nose won't stop bleeding :(
last night my nose was stuffy, so i blew my nose and all that came out was blood... so i left it alone for awhile. but then hours later i went to gently blow my nose again and all that came out was blood. then this morning i go to gently blow it again, and of course, there's even more blood. how come the blood aint drying and clotting up, the damn thing keeps bleeding!! help
lke2drvgsr is offline   Reply With Quote
Old 03-01-2004, 08:14 AM   #2
ucb
Default Re: my nose won't stop bleeding :( (lke2drvgsr)
stop snorting coke
put ice on it and pinch the top of your nose
ucb is offline   Reply With Quote
Old 03-01-2004, 08:15 AM   #3
Ricey McRicerton's Avatar
Hemophilia?
I dunno man, I have the same problem (get nose bleeds for no reason). I started giving blood and taking my clainex and it helped it stop almost 100%.
Ricey McRicerton is offline   Reply With Quote
Old 03-01-2004, 08:17 AM   #4
Default Re: my nose won't stop bleeding :( (Ricey McRicerton)
Hey look at the bright side, when it stops youll have some fun picking out blood boogers instead of the norm sticky green ones, your priveledged
Full Race A6 is offline   Reply With Quote
Old 03-01-2004, 08:18 AM   #5
lke2drvgsr's Avatar
damn, i knew that coke wasn't good for me
ive got thin veins in my nose, and ive had that problem since i was like 4.. when i was around that age, every night for several years i had nose bleeds for no reason, i never picked my nose or anything, the veins were just really really sensitive. but the bleeding eventually stopped... it's not stopping right now
Old 03-01-2004, 08:19 AM   #6
who00knows's Avatar
Sounds like a sinus infection........I had one like that about 8 months ago! SUCKS! Z-PACK OWNZ!
who00knows is offline   Reply With Quote
Old 03-01-2004, 08:20 AM   #7
lke2drvgsr's Avatar
**** did i mention i've been sneezing like crazy??? ive never had allergies or anything, ugh this sucks.
Old 03-01-2004, 08:33 AM   #8
Superhatch's Avatar
I have a little sunburn on my back and its starting to peel.
Superhatch is offline   Reply With Quote
Old 03-01-2004, 09:05 AM   #9
Z
Old User.
Z's Avatar
Sometimes small things like a change in the weather can dry out your nose. If it doesn't stop bleeding go to the doctor. He will shove a big Q-tip up there with some nice chemicals that will react with the blood causing it to burn like hell but also stop the bleeding.
Z is offline   Reply With Quote
Old 03-01-2004, 09:06 AM   #10
Big Phat R's Avatar
Go to your doctor or an otolaryngologist (ENT specialist).
Prolonged unexplained bleeding is a bad thing.
You might have an unknown allergy.
You might have high blood pressure - do you take anabolic steroids?
You might have sinusitis or a cyst growing in there - snort coke or meth?
Or maybe you just pick your nose way too much.
Big Phat R is offline   Reply With Quote
Old 03-01-2004, 09:16 AM   #11
wall of tvs's Avatar
Default Re: my nose won't stop bleeding :( (Big Phat R)
Also try putting a humidifier in your house. I used to get nosebleeds in the winter due to the dry air.
wall of tvs is offline   Reply With Quote
Old 03-01-2004, 09:42 AM   #12
EL Vap133's Avatar
Default Re: my nose won't stop bleeding :( (Z)
Quote:
I had my veins cauterized (sp?) once before cause I was bleeding bad from both nostrils non-stop!! I could barely breath, I went to the ER and the doctor stuffed some long skinny gauze in my nostrils and boy that hurt like a ****!!! He said to go back 3 days later and leave the gauze in. There was no way I was gonna go to work like that so that night I pulled them out, felt like the worlds longest bugers, lol. I went back 3 days later and he stuck what looked like a long match in each nostril and burned the veins. That worked for a few years but now I am slowly getting that bleeding back again.....
EL Vap133 is offline   Reply With Quote
Old 03-01-2004, 09:44 AM   #13
amin n'rangwa edanea
fluxion's Avatar
one time i was digging the **** out of my nostrils and got an assload of blood all over my calculus homework. i wasn't about to redo that **** so i just turned it in
fluxion is offline   Reply With Quote
Old 03-01-2004, 09:44 AM   #14
TsunamiZC's Avatar
Default Re: my nose won't stop bleeding :( (EL Vap133)
Quote:
haha ....you said "couterized"
TsunamiZC is offline   Reply With Quote
Old 03-01-2004, 10:18 AM   #15
EL Vap133's Avatar
Default Re: my nose won't stop bleeding :( (tsunami_zc)
Quote:
I did?
Old 03-01-2004, 10:34 AM   #16
sporkcrx's Avatar
I use to get them all the time, saw a doctor about it, and he said it's just because of the skin drying up, and to put vasoline on the area where it bleeds every morning. So I do that and I rarely get them now
sporkcrx is offline   Reply With Quote
Old 03-01-2004, 11:03 AM   #17
Lei Siew Long's Avatar
stop sniffing your roommate's ***. he, he. j/k
http://www.honda-tech.com/zero...age=1
Lei Siew Long is offline   Reply With Quote
Old 03-01-2004, 11:05 AM   #18
Default Re: my nose won't stop bleeding :( (UCBGSR)
Quote:
Originally Posted by UCBGSR
stop snorting coke
Grimm is offline   Reply With Quote
Old 03-01-2004, 11:32 AM   #19
BeerMoon's Avatar
Ike, a sinus infection might cause it, weather might cause it, hell asprin can cause it(asprin makes the bloodvessels in your body bigger and open up kinda, could cause enough pressure to explode some vessels) I'd say call the doc immediately just to be on the safe side. He can tell you to either come in or go to the ER, either way you should probably seek medical treatment instead of asking a bunch of medical dipshits on H-T. H-t is a great place for stupid **** and a wealth of car info, but medical things I wouldn't trust to these guys. These are the same people that thing its healthy to eat tons of spicy **** and its okay to bleed for days from a wound caused by a wrench slipping. (J/k of course)
BeerMoon is offline   Reply With Quote
Old 03-01-2004, 11:38 AM   #20
ucb
Default Re: my nose won't stop bleeding :( (AcousticDork)
Oh yeah, I got a bloody nose last night also.
After 2 days of barreling down the sierra nevada mountains on a fiberglass plank.
The snow was sweet!
Old 03-01-2004, 11:45 AM   #21
scrolanky's Avatar
are you on accutane...when I was on accutane it dried my sinus's out so bad that i bled the whole time too....
scrolanky is offline   Reply With Quote
Old 03-01-2004, 11:52 AM   #22
warwagon's Avatar
Default Re: my nose won't stop bleeding :( (scrolanky)
Quote:
i used to take that **** and i bled all the time. i have heard of people having to have their nostrils burnt before too eek that sux
warwagon is offline   Reply With Quote
Old 03-01-2004, 11:52 AM   #23
barto's Avatar
ive come to the conclusion that you either have a drug problem or you are a hemopheliac
barto is offline   Reply With Quote
Old 03-01-2004, 11:54 AM   #24
uncle's Avatar
Tampons are your friend. Quick and easy (Back in the day they were all we had for wrestling nose bleeds)
uncle is offline   Reply With Quote
Old 03-01-2004, 11:57 AM   #25
PauLiE RN's Avatar
Quote:
thats not what aspirin does. aspirin thins the blood, which can cause bleeding. If aspirin can make blood vessels open up, which what you said, then a lot of people who are takin it will have a ruptured aneurysm and actually die from it.
you should just go straight to your doctor. dont ask people who are not in the medical field. they will just diagnose you without even asking any more info about you.. but just because they read it from somewhere that nose bleeds are caused by this and that.. it will just add more stress to you
it might be everything from just the weather or something more serious
in the meantime.. ice on your nose, cotton ***** in your nostrils, and keep head down. (not up!)
then go to the clinic.
PauLiE RN is offline   Reply With Quote
the "broken nose" thread Odiedogcx General Discussion and Debate 75 08-14-2008 09:27 PM
Anyone ever get caught picking their nose Chubz General Discussion and Debate 35 03-17-2006 11:04 PM
help! my nose is bleeding . C h e n l a General Discussion and Debate 45 12-04-2005 03:46 PM
ever had your face ripped off by a bulldog 00-501itrspec General Discussion and Debate 62 11-04-2005 06:00 PM
JRSC: Disassemble nose drive Andre Forced Induction 3 08-26-2003 10:54 PM
Tags
bad, bleeding, bleeds, blew, blood, cocaine, dry, er, nose, nostrils, noxe, sinuses, stop, stopped, sunburn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
