Metal shavings embedded in hands and feet, any consequences? - Honda-Tech
Old 10-10-2005, 12:05 PM   #1
Default Metal shavings embedded in hands and feet, any consequences?
Like the title says, I have tiny little steel shavings embedded in my hands and feet. I got most of them out, but I'm wondering if the others that are too deep for me to remove will come out eventually, or if they'll cause any problems in the long run. I know that sandblasting without gloves can induce gangrene (or something of the like), which is obviously bad. But I'm not sure if the same applies for a few metal shavings. There are maybe 10 or so slivers left stuck in my hands.
Oh, and tips on how to remove them would be nice too.
The Phil is offline   Reply With Quote
Old 10-10-2005, 12:07 PM   #2
NooB
IT'S ME DAVID's Avatar
Default Re: Metal shavings embedded in hands and feet, any consequences? (The Phil)
i know those hurt but try tweezers and a magnify glass.
IT'S ME DAVID is offline   Reply With Quote
Old 10-10-2005, 12:08 PM   #3
Default Re: Metal shavings embedded in hands and feet, any consequences? (K SERIES)
Quote:
That's how I got the others out, minus the magnifying glass. The remaining ones seem to be sunken under the top layer of skin.
Old 10-10-2005, 12:08 PM   #4
MolecularIntegra's Avatar
You'll never fly again.
MolecularIntegra is offline   Reply With Quote
Old 10-10-2005, 12:22 PM   #5
Honda Hick's Avatar
I usually use a sharp, sterile (hold a match to it) pin to get out my embedded splinters/shavings.
Next time use proper protection. I learned when I got a metal shaving in my eye, it scared the living **** out of me.
Honda Hick is offline   Reply With Quote
Old 10-10-2005, 12:25 PM   #6
Z
Old User.
Z's Avatar
They are going to eventually reach your bloodstream, head into your heart and you are going to die. Nothing you can do either.
Z is offline   Reply With Quote
Old 10-10-2005, 12:25 PM   #7
El Chico
Knightsport's Avatar
Default Re: Metal shavings embedded in hands and feet, any consequences? (Honda Hick)
This is why yuo shouldn't work on your car w/ out gloves and shoes on.
Knightsport is offline   Reply With Quote
Old 10-10-2005, 12:26 PM   #8
notoriousB's Avatar
Default Re: Metal shavings embedded in hands and feet, any consequences? (MolecularIntegra)
Quote:
LOL!!
Quote:
good suggestion there
eventually (unless they're REALLY deep) your body will reject the metal splinters and they'll come out on their own, along with some pus. (lovely)
notoriousB is offline   Reply With Quote
Old 10-10-2005, 12:26 PM   #9
Lookincrazy's Avatar
ice your hands where are shavings are to numb them up and at the same tip hold a pin or safety needle under a fire to kill bacteria, then poke yourself real fast to get the shavings out while your hand is numb.
Lookincrazy is offline   Reply With Quote
Old 10-10-2005, 12:27 PM   #10
infrontofu's Avatar
I have been told to use super glue, and coat a good layer on top of the skin where the shavings are embedded, and let it dry, when it does, pull the layer away and it should pull the metal sliver out of your skin.... Just a suggestion, heard it works...
infrontofu is offline   Reply With Quote
Old 10-10-2005, 12:28 PM   #11
virginia_dude's Avatar
you are going to have major issues if you ever have an MRI...........that magnetic field is strong enough to actually pull some out and blur the image around those that remain...
virginia_dude is offline   Reply With Quote
Old 10-10-2005, 12:32 PM   #12
JoKarma's Avatar
Default Re: (infrontofu)
Good way to get a staff infection.
JoKarma is offline   Reply With Quote
Old 10-10-2005, 12:34 PM   #13
Mike_C's Avatar
normally i'd say try putting some tape on the cuts to soften the skin and maybe adhere the shards to the tape, but this stuff sounds too deep.
option a) visit a doctor
option b) get wasted and just cut em out
they will bother you in the long run. they will always stay sharp and if you put pressure on them in a certain way it'll feel as if you're getting stabbed. i had a piece of glass in the side of my finger for the past few months. it was tiny so i didn't worry about it at the time, but as everything healed up it became a serious nuisance. last night i got pissed off at it and just dug it out. the piece turned out to be about the size of a grain of salt, but it hurt like **** whenever it had pressure on it.
Mike_C is offline   Reply With Quote
Old 10-10-2005, 12:36 PM   #14
ever consider going to the doctor to get them out before they heal...if its not too late already..
Old 10-10-2005, 12:38 PM   #15
amin n'rangwa edanea
fluxion's Avatar
if they stay in the they can fester. my dad had some metal fragments in his lip leftover from a car accident that did that a couple months later (after it had healed)
fluxion is offline   Reply With Quote
Old 10-10-2005, 12:45 PM   #16
I hate everything
Backk InTheDA's Avatar
wow, scary
Backk InTheDA is offline   Reply With Quote
Old 10-10-2005, 12:47 PM   #17
Default Re: Metal shavings embedded in hands and feet, any consequences? (fluxion)
hmm i'd say go to doctor and get it checked out... you might inoculate urself with further infections or make things worse.
Kapolei INTEGRA is offline   Reply With Quote
Old 10-10-2005, 12:54 PM   #18
Kamin's Avatar
Default Re: Metal shavings embedded in hands and feet, any consequences? (Kapolei INTEGRA)
get them out asap
metal + rust = tetnis = death.
Kamin is offline   Reply With Quote
Old 10-10-2005, 01:23 PM   #19
Default Re: Metal shavings embedded in hands and feet, any consequences? (Kamin)
yeah you'll probably be getting lockjaw pretty soon if you don't hurry up
The tetanus neurotoxin causes the muscles to tighten up into a continuous ("tetanic" or "tonic") contraction or spasm. The jaw is "locked" by muscle spasms, giving the name "lockjaw" (also called "trismus"). Muscles throughout the body are affected, including the vital muscles necessary for normal breathing. When the breathing muscles lose their power, breathing becomes difficult or impossible and death can occur without life-support measures. Even with breathing support, infections of the airways within the lungs can lead to death
Toldge is offline   Reply With Quote
Old 10-10-2005, 01:41 PM   #20
.brian.'s Avatar
i think i remember that thread
.brian. is offline   Reply With Quote
Old 10-10-2005, 01:48 PM   #21
andyep3's Avatar
How big are we talking here?
My dumbass used a grinder on my door (trying to fit in bigger speakers than my door could handle, doh) and it left a bunch of small shavings. I tried to wipe them off with my hand and *oof* instant metal splinters. I got some out and just left the rest, I'm now a partial amputee...
...kidding, I'm fine.
andyep3 is offline   Reply With Quote
Old 10-10-2005, 01:49 PM   #22
redGSRguy's Avatar
Would a giant magnet work? Good luck digging them out, I'm cringing just thinking about it.
redGSRguy is offline   Reply With Quote
Old 10-10-2005, 01:51 PM   #23
Lewdin' Incognito's Avatar
Default Re: Metal shavings embedded in hands and feet, any consequences? (redGSRguy)
Quote:
Any scrapyards in the area? Just lie on your back under the big electromagnet crane and stick you hands and feet up.
Lewdin' Incognito is offline   Reply With Quote
Old 10-10-2005, 01:55 PM   #24
GO TIGERS GO!!!!
MemphisNate's Avatar
you could try to put your hand/feet in hot water to open the pores up and scrub.
MemphisNate is offline   Reply With Quote
Old 10-10-2005, 02:05 PM   #25
Chimera
Guest
Posts: n/a
Default Re: (HondaNate)
Quote:
do you even know what a STAPH infection is???
shaved head question.. SLOWAUTOEX Honda Civic / Del Sol (1992 - 2000) 15 01-19-2010 03:34 PM
Re-installing SHAVED Headlights/Tailgihts JustinEKCoupe Paint and Body 1 07-14-2009 06:34 PM
HELP JustinEKCoupe Honda Civic / Del Sol (1992 - 2000) 4 07-10-2009 01:05 PM
shaving eyebrows when you shave your head? .coolguy General Discussion and Debate 43 10-01-2007 11:00 AM
shaving bumps! CrX-To-Tha-Max-v2.0 General Discussion and Debate 31 07-22-2004 12:46 PM
Tags
accident, due, embedded, finger, gangrene, hand, hands, infection, infections, metal, sandblasting, shaving, shavings, skin, staff, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
