HP laptop turns on for 4 seconds then shuts off! - Honda-Tech
Old 08-13-2010, 02:03 PM   #1
Slomo_civic's Avatar
Default HP laptop turns on for 4 seconds then shuts off!
So I have an HP pavillion dv6700 laptop. When i press the power button, all the led's come on and the fans start spinning. Then it just shuts off after about 4 seconds. My guess is its either the power supply or the motherboard. Any inpt would be appreciated.
thanks
Slomo_civic is offline   Reply With Quote
Old 08-13-2010, 02:38 PM   #2
He knows where you live!
TheMuffinMan's Avatar
Default Re: HP laptop turns on for 4 seconds then shuts off!
Reset the ram first and see if that helps
Pull out the battery and remove external power then press power button a few times, then reinsert power cable and try to power on.
TheMuffinMan is offline   Reply With Quote
Old 08-13-2010, 03:44 PM   #3
Ok tried resetting the ram and then did the reset you described. still wont turn on for more than 4 seconds.
Old 08-13-2010, 09:53 PM   #4
ಠ_ಠ
RyanJC's Avatar
Same thing happened to a really old laptop of mine after I reseated the CPU. I'm too lazy to fix that pos.
RyanJC is offline   Reply With Quote
Old 08-14-2010, 03:41 AM   #5
NrG
NrG's Avatar
failing power supply, not getting proper voltage.
NrG is offline   Reply With Quote
Old 08-20-2010, 12:27 AM   #6
f@sth@tch89's Avatar
motherboard.....
i just got my zv5000 fixed. I had all kinds of power issues. Wouldnt stay on...i thought it was the dc jack, but it was the mother board.
f@sth@tch89 is offline   Reply With Quote
Old 08-20-2010, 01:07 PM   #7
Quote:
Originally Posted by f@sth@tch89 View Post
motherboard.....
I figured it was the mother board. I didn't think I would get away with something cheap!
need help fixing a laptop DoGGy General Discussion and Debate 5 06-17-2013 08:09 PM
Computer Guru's...question about sony vaio SOHC_MShue General Discussion and Debate 5 02-10-2007 09:28 PM
Laptop power problem cfran55 General Discussion and Debate 4 07-17-2006 11:39 AM
Laptop question Petah General Discussion and Debate 3 01-29-2005 08:25 AM
Is my laptop phucked? .RJ General Discussion and Debate 37 06-01-2004 05:03 AM
Tags
cycles, dell, dv5, dv6700, hp, laptop, led, notebook, off, power, powers, seconds, shuts, turns, zv5000
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
