how long does it take for gas to 'go bad'. - Honda-Tech
Old 04-10-2005, 07:26 PM   #1
Skoobie no more...
HatchBox's Avatar
Default how long does it take for gas to 'go bad'.
Well my car was on the road a few months ago, and while it was i filled it up, well i went to start it and it runs like crap. Im not sure if its bad gas or not.
So typically how long does it take. Its 93 octaine if that plays any role.
HatchBox is offline   Reply With Quote
Old 04-10-2005, 07:34 PM   #2
disabled's Avatar
i dont think it can go bad, it just evaporates
disabled is offline   Reply With Quote
Old 04-10-2005, 07:35 PM   #3
Skoobie no more...
HatchBox's Avatar
Default Re: (disabled)
Quote:
Well when it evaporates what does it leave? A less combustable fluid?
Old 04-10-2005, 07:51 PM   #4
spyderracing's Avatar
Default Re: (HatchBox)
If it's within the gas tank it would probably just condense on any surface it can (aka it would just turn back into gas.)
spyderracing is offline   Reply With Quote
Old 04-10-2005, 07:52 PM   #5
Grumpy Old Man
Veritas-Aequitas's Avatar
Don't listen to these idiots.
Gas goes bad after a few months. Try to give your gas tank a smell you'll know if it's bad.
Veritas-Aequitas is offline   Reply With Quote
Old 04-10-2005, 07:55 PM   #6
Skoobie no more...
HatchBox's Avatar
Default Re: (RebornGSR)
Hmmm, i thought gas went bad. haha
Is it not as potent as regular gas?
Old 04-10-2005, 07:58 PM   #7
Grumpy Old Man
Old gas looses its octane rating and forms big gooey polymers.
If it really smells like varnish and bad Parmesan cheese you will probably need to drain the tank and change the fuel filters.
If it still smells somewhat good you can probably get away with adding 104+ Octane boost because that will help boost the octane back up and it also contains detergents that will dissolve minor polymer deposits.
Old 04-10-2005, 07:59 PM   #8
Grumpy Old Man
Next time just add fuel stabilizer and let it run through the system before you leave it sitting
Old 04-10-2005, 08:00 PM   #9
Skoobie no more...
HatchBox's Avatar
Hmm, i just went to take a wiff, and smells like gas.
that NOS stuff is 104 right?
yeah i will just drain the tank and put that 'bad fuel' in my buick
Old 04-10-2005, 08:06 PM   #10
Grumpy Old Man
Quote:
I dono I just copy this **** from someone else who knows what the hell they are talking about
Old 04-10-2005, 08:06 PM   #11
Skoobie no more...
HatchBox's Avatar
Cheater, haha
ok well im just gonna put the gas in my beater then fill the civic up with pump gas
Old 04-10-2005, 08:08 PM   #12
del_parker's Avatar
Default Re: how long does it take for gas to 'go bad'. (HatchBox)
I just drain the bad gas and put it into my dad's F150. Runs like a champ on it.
del_parker is offline   Reply With Quote
Old 04-10-2005, 08:12 PM   #13
Skoobie no more...
HatchBox's Avatar
Default Re: how long does it take for gas to 'go bad'. (del_parker)
im sure my buick wont mind the gas, hell i put stewart gas in it. (shitty)
Old 04-10-2005, 09:01 PM   #14
civickiller's Avatar
my car, 91 civic dx 1.5 dpfi, sat for 3 years. after 3 years, started it up. drove to a gas station and filled up. it ran fine to the gas station. then i drove lot within the next couple days to bring it down to E then i filled it up again. most of the gas should be gone.
i wouldnt do this with a performance motor like a b16 but with a stock sohc motor, its all good
civickiller is offline   Reply With Quote
Old 04-10-2005, 09:07 PM   #15
Default Re: how long does it take for gas to 'go bad'. (civickiller)
Quote:
Um yeah
The Phil is offline   Reply With Quote
Old 04-10-2005, 09:28 PM   #16
marsbike's Avatar
Location: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: how long does it take for gas to 'go bad'. (xthephilx)
hmmm...I guess I gotta drain the tank in my benz...It's been sitting for a little too long...so...umm....yeah...(five years...no sta-bil) It still runs...kinda...but, I don't exactly want to take it out with the brakes being in the condition they're in anyways...
marsbike is offline   Reply With Quote
Old 04-11-2005, 01:31 AM   #17
Quote:
Originally Posted by xthephilx
Um yeah
i mean as a motor that uses 91 octane vs a stock sohc 1.5 that could probably use lower than 87
Old 04-11-2005, 02:00 AM   #18
1998hondaaccord's Avatar
It takes 30 days to go bad.Try to use fuel stabilizer if your going to let it sit.
Most problems with lawn equipment is due to people lettting old gas sit in the tank and carb for months.It causes the carb to gum up and not fuel pass. Not crappy equipent just poor care.
1998hondaaccord is offline   Reply With Quote
People asking for gas money... Whats your opinion? Simmerman General Discussion and Debate 75 06-30-2008 01:34 PM
how long does it take for gas to go bad? (itr hasn't been started in a while) Black R Acura Integra Type-R 18 04-03-2006 02:43 PM
car takes a long time to start??? 90efSI Honda CRX / EF Civic (1988 - 1991) 23 03-19-2006 09:13 PM
How long before gas goes bad? Propulsion Tech / Misc 10 02-21-2004 01:20 PM
How, long does it take for a shop to flush and fill radiator fluid conesmasher Acura Integra 3 06-08-2003 07:41 PM
Tags
87, 91, 93, bad, calif, car, fuel, gas, gasoline, long, octane, regular, sitting, tank, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
