How to hook up system with no car? Stereo/amp gurus, help! - Honda-Tech
Old 03-17-2004, 04:10 PM   #1
EL Vap133's Avatar
Default How to hook up system with no car? Stereo/amp gurus, help!
Ok, a friend of mine cannot sell his old amps/subs, speakers/stereo. So what he wants to do is hook all of it up in his garage. Now, other than the easyness of the wires to the amps/speakers and such, how can he go about getting power to the components other than using a car battery? Thanks in advance for your help guys.
EL Vap133 is offline   Reply With Quote
Old 03-17-2004, 04:11 PM   #2
twentywontowin's Avatar
Default Re: How to hook up system with no car? Stereo/amp gurus, help! (EL Vap133)
My friend knows how, but he's at work right now. If nobody answers it for you by later tonight I'll ask him.
twentywontowin is offline   Reply With Quote
Old 03-17-2004, 04:11 PM   #3
psi420's Avatar
AC/DC Converter
Similar to your computers power supply.
psi420 is offline   Reply With Quote
Old 03-17-2004, 04:20 PM   #4
EL Vap133's Avatar
Default Re: (psi420)
Quote:
Originally Posted by psi420
AC/DC Converter
Just an AC/DC convertor? No wiring needed?
Old 03-17-2004, 04:24 PM   #5
ucb
Default Re: (EL Vap133)
Quote:
Well you need to wire the AC/DC converter to the amp.
120vac convert to 12-14v DC plug into amp..if he is using his head unit he has to power that too
ucb is offline   Reply With Quote
Old 03-17-2004, 04:30 PM   #6
EL Vap133's Avatar
Default Re: (UCBGSR)
Ok thanks, I will forward him this info to see if it makes sense to him, lol.
Old 03-17-2004, 05:38 PM   #7
green91's Avatar
it depends.. you can get a 120v ac -> 12v dc converter.. and it may work for a headunit/speakers alone.. the hard part is getting a 12v output with the correct amps.. like typically a head unit can draw 5-15 amps.. if your converter doesnt output that much it can cause distortion. it is even worse if using an amplifier for subs.. i know that my rockford amp draws damn near 60 amps.. its gonna set you back several bills to get a converter with that kind of output
green91 is offline   Reply With Quote
Old 03-17-2004, 05:50 PM   #8
michael O's Avatar
Default Re: (green91)
If it's in his garage why not use a car battery? I can understand if you're setting this up in the house or something though
michael O is offline   Reply With Quote
Old 03-17-2004, 05:52 PM   #9
EL Vap133's Avatar
Quote:
Oh, I didn't know that. Damn I swear I want to take some electrician classes! Thanks for your help, I will let him know!
Quote:
Wouldn't a car battery only last so long after a while?
Old 03-17-2004, 05:52 PM   #10
eL
eL's Avatar
Try they audio section... they helped me with something similar in there.
eL is offline   Reply With Quote
Old 03-17-2004, 05:53 PM   #11
EL Vap133's Avatar
Default Re: (eL)
Quote:
Oh ok, I will post a link to this in there, thanks!
Old 03-17-2004, 06:15 PM   #12
green91's Avatar
one possible solution would be to take an a/c motor and an alternator and run a belt between them.. using the correct size pulleys you could rig up a generator of sorts.. the motor wouldnt even need to be very strong.. and just run it to a battery. may be a good project if your bored lol, would still be cheaper than a converter
Old 03-17-2004, 06:19 PM   #13
EL Vap133's Avatar
LOL!! That sounds like some straight MacGuyver ****!
Old 03-17-2004, 06:48 PM   #14
H-T White Ops
Frozen E's Avatar
I looked into that before. An AC-DC converter big enough to crank out 30 amps is next tompossible to find. And even if you can find one it's probably gonna set the guy back an easy grand. Not worth it.
Frozen E is online now   Reply With Quote
Old 03-17-2004, 06:51 PM   #15
michael O's Avatar
oh yea I forgot I have a battery charger in my garage too...
Old 03-17-2004, 07:42 PM   #16
green91's Avatar
i doubt youre gonna want to leave a battery charger running that long! i thought the motor/alternator thing would be fun to make if i got really bored..
Old 03-17-2004, 07:49 PM   #17
Location: I have crack runin through my veins, seriously, United States
Default Re: (michaelOlson)
My friend and I used to use a Car battery charger hooked up to a battery and then to the system. It worked awesome, with no problems.
tyronebiggums is offline   Reply With Quote
Old 03-19-2004, 03:57 PM   #18
nsxxtreme's Avatar
Default Re: (EastSideImports)
1. You could build yourself a power supply one large enough to supply 100A worth of current would probably set you back $200. This assumes you have the know how to build one. I built one for a friend so he could test amplifiers.
2. You could purchase one, it would probably set you back at least $1500 for one that could supply that current
3. You could go in a rewire the amplifiers to run on 120, which really isn't that hard. They usually have +/- 60V rails. This assumes you know what you are doing.
4. You could rig it like mentioned above which is probably your best option.
nsxxtreme is offline   Reply With Quote
Old 03-19-2004, 05:29 PM   #19
darkvibe's Avatar
you'd need a dc power supply and those are expensive. Just get a car battery and a trickle charger.
darkvibe is offline   Reply With Quote
Old 03-19-2004, 05:37 PM   #20
EL Vap133's Avatar
Default Re: (darkvibe)
I'll pass over the info to him, thanks a lot guys!
Old 03-19-2004, 06:22 PM   #21
jdmotorsports's Avatar
if you have a rv salvage yard near by check with them. i got a 50amp 120vac-13.4vdc converter out of an old rv. might be able to find something like that.
jdmotorsports is offline   Reply With Quote
Please help with speaker noise... weird stuff happening. DsevenEm2 Audio / Security / Video 3 01-07-2009 07:26 PM
My stereo systtem sounds staticy LaOstha Audio / Security / Video 1 11-23-2004 06:01 PM
Stereo wiring question...used search xZeler8 Honda Civic / Del Sol (1992 - 2000) 2 11-09-2004 03:32 PM
wiring amp with no subs RIOredKIRKLANDcrx Audio / Security / Video 4 05-14-2004 08:38 AM
rear speaker help NorCalHB Honda Prelude 3 08-04-2002 08:59 AM
Tags
amp, amplifier, audio, battery, car, charger, froze, garage, hook, house, radio, stereo, sterio, stero, subs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
