how do i pass ny state inspection - Honda-Tech
Old 02-22-2006, 05:00 PM   #1
Civic97s's Avatar
Default how do i pass ny state inspection
i am thinking about buying a obd2 jdm motor
a b16b but my friend says it wont pass because its not a usdm motor
is there any way for me to still but a jdm b16b motor and still pass
please help i need this question answered soon
because i have the money and am ready to but i just dont know for sure if i can pass or how to pass ny inspection
Civic97s is offline   Reply With Quote
Old 02-22-2006, 05:07 PM   #2
cd5_2NR's Avatar
Default Re: how do i pass ny state inspection (Civic97s)
just do it..
cd5_2NR is offline   Reply With Quote
Old 02-22-2006, 05:15 PM   #3
Default Re: how do i pass ny state inspection (cd_5TUNR)
slip some nipple
Spider Man is offline   Reply With Quote
Old 02-22-2006, 05:41 PM   #4
DONT DO IT. Trust me it will be a huge pain in the *** I am a licensed inspector for the state. Get a 95 or older car and have all the fun you want.
Runnerdown is offline   Reply With Quote
Old 02-22-2006, 05:41 PM   #5
chasedatteg's Avatar
Default Re: how do i pass ny state inspection (Spider Man)
2 ways to pass. dont doing anything to your car. or pay the man what he wants so he can pass you . ny sucks with these laws. im going to fl. bye ny
chasedatteg is offline   Reply With Quote
Old 02-22-2006, 06:21 PM   #6
hadehatch's Avatar
Default Re: how do i pass ny state inspection (Runnerdown)
do they check the vins on the motor? There shouldn't be a problem if they connect to the diagnostics port on your obd2 ecu and everything checks out (no check engine light) .. doesnt make a difference if its a jdm or usdm motor just have the right ECU for your car and make sure its not throwing any codes..
hadehatch is offline   Reply With Quote
Old 02-22-2006, 06:38 PM   #7
Civic97s's Avatar
Default Re: how do i pass ny state inspection (hadehatch)
i dont think it will connect to the senors
since its Japanese
Old 02-22-2006, 06:47 PM   #8
AutoXer's Avatar
The motor has to be newer than the car, and all of the OBD functions must be working. The computer has to be able to read the EDU, and thaere can't be any codes.
AutoXer is offline   Reply With Quote
Old 02-23-2006, 10:00 PM   #9
Civic97s's Avatar
Old 02-23-2006, 10:02 PM   #10
AGENT 99's Avatar
Say it with me...
SEAFOAM!!!
AGENT 99 is offline   Reply With Quote
Old 03-03-2006, 12:39 AM   #11
maxxd97's Avatar
Default Re: how do i pass ny state inspection (AGENT 99)
I have a JDM B18C. The only way I passed is when I switched my ECU to a USDM.
The computer cannot read a JDM ECU.
maxxd97 is offline   Reply With Quote
Old 03-03-2006, 04:45 AM   #12
Alexander's Avatar
Quote:
Originally Posted by Spider Man
slip some nipple
In new york, they hook your ECU up to the DMV's private network and run your ECU with all the checks including vehicle type verification... So "slipping some nipple" wouldn't work, you would just be exposing yourself.
I had some problems with a emissions CEL (completely random) and failed twice, before I got an OBDII scanner and fixed the problem myself. If you want the scanner i'll sell it to you
Alexander is offline   Reply With Quote
Old 03-03-2006, 05:05 AM   #13
3rd g3aR vTak
Just get a 95 or older car and your good to go! NY is full of loopholes! They only emissions test OBD2 or newer cars. If you have a 96 or newer , I don't know what to tell you.
. O M E G A is offline   Reply With Quote
Old 03-03-2006, 05:33 AM   #14
Mr. Vapor's Avatar
Default Re: how do i pass ny state inspection (omega02379)
get a friend at the DMV....have him hook the OBDII scanner to the car NEXT to you which is in perfect running condition. gets sent to the DMV, out pops a positive inspection. voila, done.
OR have a friend with a regular non-modified car go get inspected, immediatly take his inspection sticker off and stick it on yours. of course its not for YOUR car but the cops just look for the proper color and within the proper dates. when was the last time you saw a cop SCAN an inspection sticker?
Mr. Vapor is offline   Reply With Quote
Old 03-03-2006, 05:34 AM   #15
3rd g3aR vTak
Default Re: how do i pass ny state inspection (Mr. Vapor)
Quote:
He's got a point^^^
Old 03-03-2006, 06:55 AM   #16
Civic97s's Avatar
very true but if he does check im screwed and prob have a major ticket
Old 03-03-2006, 07:09 AM   #17
Mr. Vapor's Avatar
than maybe you shouldnt be modifying cars? Inherent risks come wth the territory.
Old 03-03-2006, 09:08 AM   #18
maxxd97's Avatar
Without getting your registration scanned, the DMV will know that you did not get an inspection and you will not be able to re-register your car until you do get an inspection.
Only ways around it are:
Getting an OBD1 car.
Using a USDM OBD2 motor or JDM motor w/ a USDM ECU.
Knowing somone who does inspections, having the same exact car as yours go with you. Inspector scans your registration and then inspects the other car.
Pay $450 to get a waiver, but you can only do that once. Next year you would be screwed.
Old 03-03-2006, 12:09 PM   #19
Mr. Vapor's Avatar
Default Re: how do i pass ny state inspection (maxxd97)
wrong.
im going on the basis that the car is not registered. if you cant get the car registered how do they expect you to DRIVE your car to the inspection station. 10-day temp.
edit, and the DMV in Albany has NO WAY of knowing what car they are inspecting. there is NO correlation between the ECU and the car. all they know is if its passes or not. therefore it does not matter if the car is the same make or model.
Old 03-03-2006, 01:41 PM   #20
wrong.
Yes, this is true of some cars. I do know people that have been caught swapping the plug to other cars where the VIN can be identified. A shop not far from where I live got shut down because of that.
Old 03-03-2006, 01:45 PM   #21
Mr. Vapor's Avatar
trust me, the ECU does NOT communicate with the computer in Albany, as far as VIN identification
say for instance my car is broken into and my ECU stolen so i have to purchase a NEW on from HONDA to replace my stolen one?
Old 03-03-2006, 01:52 PM   #22
Alexander's Avatar
The only thing that shows up on the screen is "Verifying Vehicle" while doing the inspection. I spoke with some inspectors and they say the engine doesn't have to be from the vehicle.
Old 03-03-2006, 01:55 PM   #23
hondadriver's Avatar
You can swap ANY motor into your car. You just have to use an OBD2 ecu. Thats all. when you go for an inspection they just plug in the computer into your obd2 diagnostic port and check for readiness codes and any cels. I have a 98 civic with and obd1 2nd gen b16a in it, and i'm running it off an 99 civic si ecu and passed last year. The ecu does not contain any info on the car or motor. Theres just alot more wiring and adding of sesnors for the obd2 ecu.
hondadriver is offline   Reply With Quote
Old 03-03-2006, 02:01 PM   #24
Mr. Vapor's Avatar
Default Re: how do i pass ny state inspection (Alexander)
Quote:
THANK YOU
Old 03-03-2006, 02:07 PM   #25
Overkill's Avatar
It is stupid easy to pass an inspection in NY, my freind passed his Mustang with no cats, my dad passed this older mercury that was smoking..just go to a shitty looking inspection place and slip them some extra cash.
Overkill is offline   Reply With Quote
how to pass inspection obd2 car with obd1 stepdown harness in b16 Alexpbnj Honda Civic / Del Sol (1992 - 2000) 3 03-21-2011 05:41 AM
emission/inspection/ problems and question slitterman Honda Civic / Del Sol (1992 - 2000) 3 04-30-2010 11:40 PM
how to pass emissions test for boosted cars in ny state Axemurderer23 Forced Induction 6 05-27-2009 08:01 PM
How do i get my car to pass inspection?!?!?!?!?!? JDM EK-R Tech / Misc 5 03-06-2008 01:40 PM
OBD1 B18c in OBD2 civic NY state inspection... erich73 Hybrid / Engine Swaps 18 05-02-2007 10:10 AM
Tags
accord, communicate, easy, honda, inspection, integranys, nyc, nyvip, reads, state, texas, turbo, vin, visual, york
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
