how do I break lock tight????? - Honda-Tech
Old 12-25-2005, 08:38 PM   #1
george34's Avatar
Default how do I break lock tight?????
I have a motor mount screw on my r/c car that is held in by lock tight. I have already stripped the screw very bad. The only thing that I can think of that is holding this one screw in so tightly is becauseof the lock tight. What can i do to make the lock tight break free, so I can get the screw out???? Thanks.
george34 is offline   Reply With Quote
Old 12-25-2005, 08:47 PM   #2
Skunk.Werks's Avatar
Default Re: how do I break lock tight????? (george34)
torch it up, slot it, and work on it with a flat head or..
drill it out
Skunk.Werks is offline   Reply With Quote
Old 12-25-2005, 09:20 PM   #3
george34's Avatar
Default Re: how do I break lock tight????? (Skunk.Werkz)
I don't want to drill it out b/c I need to be able to put a new screw in.What would I slot it with?
Old 12-25-2005, 09:29 PM   #4
Starrman85's Avatar
sounds like lock tight is doing it's intended job.
Starrman85 is offline   Reply With Quote
Old 12-25-2005, 09:34 PM   #5
SHystrdyGSRtdy's Avatar
heat... slot it with a dremel.
SHystrdyGSRtdy is offline   Reply With Quote
Old 12-25-2005, 09:47 PM   #6
bustdesenuts's Avatar
Blue: Can be removed with hand tools
Red: Apply heat to remove
Green: Apply heat to remove
have you tried a vise grip to get it out?
bustdesenuts is offline   Reply With Quote
Old 12-25-2005, 09:56 PM   #7
Ajax's Avatar
Default Re: (bustdesenuts)
Heat it up, use vice grips. Unless you accidently knock the top of the screw off, there is never a time when this won't work.
Ajax is offline   Reply With Quote
Old 12-26-2005, 05:18 AM   #8
george34's Avatar
Default Re: (Ajax)
I will try a vice grip and tell you guys how it worked.
do 88/89 crx corner lights fit 90 crx ? crxaddikt Honda CRX / EF Civic (1988 - 1991) 10 10-21-2013 01:22 AM
Del Sol interior door handles are loose hell_sol Honda Civic / Del Sol (1992 - 2000) 3 01-27-2010 11:09 AM
Idle screw problem Da_Special Acura Integra 2 12-22-2009 11:52 AM
How to remove a stripped/rusted screw in a tight area? abmerop18 General Discussion and Debate 6 06-01-2006 06:53 PM
help screw is stripped on door VietFoo Acura Integra 3 03-09-2004 10:43 AM
Tags
break, breaking, free, green, heat, lock, locktight, loose, remove, removing, s2000, scerw, threaded, tight, tite
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
