Fuel injection service at wal-mart, worth it?? - Honda-Tech
Old 03-26-2009, 06:00 PM   #1
SiR Inspired ED7's Avatar
Default Fuel injection service at wal-mart, worth it??
the car is about to hit 100k, is the fuel injection service at walmart a good idea?? it is only 20 bucks i belive... has anyone expirianced this type of service at wal mart or any other place and have noticed a difference in gas econamy??
SiR Inspired ED7 is offline   Reply With Quote
Old 03-26-2009, 06:10 PM   #2
GDD Member
slomofo's Avatar
Default Re: Fuel injection service at wal-mart, worth it??
If it's only $20, then it's probably some guy pouring crap into your gas tank.
slomofo is offline   Reply With Quote
Old 03-26-2009, 06:11 PM   #3
Filliam H. Muffman's Avatar
for 20 bucks they're probably just putting injection cleaner in your tank.
go buy some at your auto parts store yourself.
Filliam H. Muffman is offline   Reply With Quote
Old 03-26-2009, 06:26 PM   #4
__oversea's Avatar
iam sure its one of those you put it in your gas tank.
real ones are bottle hooked up to your fuel line, and runs engine with it, without using gas from the tank.
Or, take off your injectors and have shop clean it up. it really helps.
__oversea is offline   Reply With Quote
Old 03-26-2009, 06:27 PM   #5
sde780's Avatar
seafoam
sde780 is offline   Reply With Quote
Old 03-26-2009, 08:03 PM   #6
hayabusa160's Avatar
**** no. they cant even do an oil change right.
hayabusa160 is offline   Reply With Quote
Old 03-26-2009, 08:05 PM   #7
Photoshop Guru
ipleadthe5th's Avatar
At walmart you get what you pay for. Except for this one product....
ipleadthe5th is offline   Reply With Quote
Old 03-27-2009, 03:40 PM   #8
I just called up wal-mart and the guy mentioned that they have some liquid that gets sucked up by the vac line and the second step is pouring that fuel injector liquid in the gas tank... All the car gets is 89oct from chevron, i am just gonna buy some chevron fuel injector cleaner and pour that in the gas tank. I did some researching and it seems like alot of poeple dont trust wal-mart's techs so i rather not risk it and be safer than sorry. THNX guys.
Old 03-27-2009, 04:03 PM   #9
New User
dewey werk's Avatar
Get the Lucas stuff....little clear bottle with a green cap. its like 6 bucks at Pepboys/Autozone/Etc.....works great.
dewey werk is offline   Reply With Quote
Old 03-27-2009, 04:11 PM   #10
98bucket's Avatar
Quote:
Originally Posted by sde780 View Post
seafoam
98bucket is offline   Reply With Quote
Old 03-27-2009, 04:14 PM   #11
rookn00b
xtrac1's Avatar
If the engine is showing symptoms of a bad injector, it wouldn't be a bad idea to remove the injectors and get them serviced.
xtrac1 is offline   Reply With Quote
Old 03-27-2009, 04:29 PM   #12
Quote:
Srry i rather not risk using that lucas stuff, I have heard many stories of that lucas brand that i just rather not.
Old 03-27-2009, 05:13 PM   #13
bob barker's Avatar
i had a friend do the walmart fuel thing and he said it helped raise his mpg. its probably all in his head thou.
bob barker is offline   Reply With Quote
Old 03-27-2009, 05:30 PM   #14
smileycvc's Avatar
Quote:
Don't trust the "techs" at wal-mart hmmm I wonder why? Have you seen the F*cking people that work there. I am afraid to even park my car in a wal-mart parking lot let alone let any wal-mart employee touch my car with any intention of driving/doing any sort of matinence on it. I can't believe this is even a question.
smileycvc is offline   Reply With Quote
Old 03-27-2009, 05:47 PM   #15
Uncle Willie's Avatar
$20 bucks for that service is a DEAL! My work charges 65.99 for the same stupid service.
Seafoam through the VAC is the same thing and cheaper. But at 100k on the clock, I would just go put SF through the gas tank.
Uncle Willie is offline   Reply With Quote
Old 03-27-2009, 07:11 PM   #16
travman's Avatar
If it were me, I'd throw a bottle of BG44k in the tank and forget about it.
travman is offline   Reply With Quote
Old 03-27-2009, 07:26 PM   #17
Don-Cheto's Avatar
Youre trippin.
Lucas is good stuff.
Don-Cheto is offline   Reply With Quote
Old 03-27-2009, 07:51 PM   #18
Quote:
Originally Posted by Don-Cheto View Post
Youre trippin.
From what i have read on this forum lucas causes the oil to get foamy when the tempurtures rise.
Old 03-27-2009, 10:29 PM   #19
yea the lucas additives causes cavitation.
when i was working at honda i got a ton of cars that came from across the street from walmart with ****ed up drain bolts.
they also left the oil cap off on my friends car and made a mess. but they payed for it.
Old 03-27-2009, 10:54 PM   #20
NrG
NrG's Avatar
don-cheto probably works at autozone and tells everyone that it's good stuff.
lucas is JUNK! dont use it.
OP, why not remove your injectors and send them away to get flow tested and cleaned.
NrG is offline   Reply With Quote
Old 03-27-2009, 11:07 PM   #21
seafoam it
jimmytmach is offline   Reply With Quote
Old 03-27-2009, 11:09 PM   #22
Pee Wee's Avatar
Quote:
only car?
Pee Wee is offline   Reply With Quote
Old 03-30-2009, 04:49 PM   #23
Quote:
Originally Posted by Pee Wee View Post
only car?
YES only car, i did the chevron fuel injection cleaner and i noticed a difference driving on the highway
Old 03-30-2009, 05:09 PM   #24
MonkeyMagic's Avatar
lol its all worthless anyway. a mix of kerosene and other detergents.
Quote:
x2
MonkeyMagic is offline   Reply With Quote
Old 04-01-2009, 06:04 PM   #25
JimDCXC's Avatar
I used to work as a tech at Wal-Mart when I was in college and yes it's true, there are a lot that don't know **** but when all you do is oil changes and mounting tires... you really don't need to be a certified mechanic. The fuel injection service isn't a bad deal though, I did it on my own car once. It will be very smokey.
They hook up a bottle to a vacuum line and also pour a bottle of fuel injector cleaner in the gas tank.
JimDCXC is offline   Reply With Quote
Stay home fatty v.#makewalmartgreatagain signalpuke General Discussion and Debate 15 06-04-2016 10:21 PM
Products of Wal-Mart! Why Didn't I think of This? mgold General Discussion and Debate 19 06-08-2012 01:00 PM
Wal-Mart Wheel Rotation - Scratched Wheel aSDthing Wheel and Tire 33 12-12-2007 09:36 AM
Walmart Crashed my Prelude. gooberwolf General Discussion and Debate 47 05-18-2005 09:33 PM
Wal-Mart Battery RyanEJ8 Honda Civic / Del Sol (1992 - 2000) 10 07-26-2003 08:29 PM
Tags
acura, algonquin, clean, cleaner, cleaning, el, fuel, il, injection, injector, it, offers, service, system, walmart, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
