is fix-a-flat permanent? - Honda-Tech
Old 10-14-2003, 05:04 PM   #1
FD3S's Avatar
Default is fix-a-flat permanent?
taking a road trip tomorrow and my g/f's car recently had fix-a-flat used in one of the tires. we will be traveling over 200 miles each way. is the stuff permanent? will we be ok to make this trip? i think i am going to shucks to read the warning label, but in the mean time can u guys tell me?
FD3S is offline   Reply With Quote
Old 10-14-2003, 05:10 PM   #2
Dramier's Avatar
Default Re: is fix-a-flat permanent? (FD3S)
Dude, don't use that ****. It eats away the tire and the rim.
You can get a patching kit for less than $10 and fix it with an insert patch which will work a whole lot better.
Dramier is offline   Reply With Quote
Old 10-14-2003, 05:20 PM   #3
FD3S's Avatar
Default Re: is fix-a-flat permanent? (Dramier)
it was the g/f...it's already done...what i am asking is if it is safe for the trip...
Old 10-14-2003, 05:21 PM   #4
mantic6t9's Avatar
I think it's only ment for temp use untill you can get a new tire. I have no idea how long it's suposed to last.
mantic6t9 is offline   Reply With Quote
Old 10-14-2003, 05:22 PM   #5
Dramier's Avatar
No it's not. You need to go and get a patch kit and do it right.
Trust me, I have been through this until somebody finally clued me in and told me not to use that spray can crap. Patching a tire is easy and cheapier than the fix-a-flat by quite a bit. Only takes about 45 seconds, and you're done.
Old 10-14-2003, 05:33 PM   #6
overrated.
OnePointFive's Avatar
Fix a flat is only a temporary solution. it is NOT safe for going on a trip. As far as it eating away at your tire, that isn't true. What DOES eat away at your tire, is when you put fix a flat in it and it gets low and you start to drive on it with low air pressure the rim eats up the inner sidewall of the tire and it could cause a blowout. As far as those plug kits you buy at gas stations, those leak all the time. Once again, only temporary solutions. Your best bet is to just go to a tire place and get it patched from the inside.
good luck, and have a good trip
OnePointFive is offline   Reply With Quote
Old 10-14-2003, 05:49 PM   #7
Xumarius's Avatar
Quote:
Xumarius is offline   Reply With Quote
Old 10-14-2003, 05:50 PM   #8
brinks's Avatar
I wil chime in with my agreement. I would never use that fix a flat. If its a small hole it can be patched permanently for about the same price as a can of that stuff. I would get a new tire or patchthe hole the right way.
brinks is offline   Reply With Quote
Old 10-14-2003, 06:34 PM   #9
Dramier's Avatar
Default Re: is fix-a-flat permanent? (OnePointFive)
Quote:
Sorry, I have to say you're wrong. I've seen it first hand learning the hardway. It will eat your rims and your tires. Pontiac Firebird Formula steel rims eaten away by fix-a-flat, and the rubber all in the inside of the tire looked like it had a low-grade acid on it for a few days. I'm telling you the stuff WILL eat your tires and rims. Maybe not all types or brands, but the one I used DID.
Have fun on the trip bro, and get a new tire!
Old 10-14-2003, 06:45 PM   #10
BeerMoon's Avatar
Ate away the tires and rim on a old friends car, he ended up dying because he refused to spend the money for a new tire.
BeerMoon is offline   Reply With Quote
Old 10-14-2003, 06:49 PM   #11
New User
Rain_man's Avatar
Just like everybody else said, fix a flat is temp only. Lets you limp home.
I read a few years ago (from a reputable source) that some fix a flat stuff was flammable and when sometimes while the garage was patching the tire, a small explosion was set off. Chk the side of the can to see if it has any corresponding warnings.
Rain_man is offline   Reply With Quote
Old 10-14-2003, 06:54 PM   #12
overrated.
Default Re: is fix-a-flat permanent? (Rain_man)
I work at Just Tires and i've never seen any corrosion on rims as a result of fix a flat.
But that's straying from the point, the point is, get your ish fixed!!
Old 10-14-2003, 07:03 PM   #13
FD3S's Avatar
looks like an early morning trip to les schwab...
Old 10-14-2003, 07:05 PM   #14
New User
blkbeast's Avatar
i had fix-a-flat in one of my beater's tires for over a year without a problem....but i would still suggest getting the tires patched.
blkbeast is offline   Reply With Quote
Old 10-14-2003, 07:37 PM   #15
PhatboyNYC's Avatar
I used Fix-A-Flat on one of my tires and although I didn't get any corrosion like some of the others have experienced, it caused my wheel to go out of balance.
PhatboyNYC is offline   Reply With Quote
Old 10-14-2003, 07:50 PM   #16
99-0104
Stripped Honda's Avatar
Default Re: is fix-a-flat permanent? (PhAtBoY Si)
dont chance driving on a long trip like that fix tie tire the right way
it doesent nessarly eat away the tire but it is liquid and that mixed in a tire that has a metal rim will tend to rust and i have seen this first hand
at our shop we charge more to dismount a tire with fix a flat or slime in it because it just makes a mess of our shop
Stripped Honda is offline   Reply With Quote
Old 10-14-2003, 08:42 PM   #17
overrated.
Default Re: is fix-a-flat permanent? (Stripped Honda)
Quote:
same here, $5 extra for "fix a flat cleanout".
Old 10-14-2003, 08:46 PM   #18
crujones's Avatar
i dont have a spare, just a can of fix a flat.
So when i had some 17's i got a flat and it saved me. The fix a flat is still in the tire today and it works fine just rides a little off balance. So i traded the wheels anyway, so the fix a flat is no longer my problem. But it is great fix it you got no spare or a motorcycle. Worth the $5, but a regular fix or new tire is obviously better.
crujones is offline   Reply With Quote
Old 10-14-2003, 09:04 PM   #19
amin n'rangwa edanea
fluxion's Avatar
just put it this way:
gf driving + tire blowout = you dead
fluxion is offline   Reply With Quote
Old 10-14-2003, 09:22 PM   #20
Starrman85's Avatar
Default Re: is fix-a-flat permanent? (fluxion)
just get a new tire. i got rims and new tires last month, and then last week, somehow i got a screw in my driver side rear tire. brought it to americas tire company where i got the rims and tires, cost $27 to get a brand new tire mounted, balanced, and a new warrenty on that tire. best deal out there.
i have yokohama avs es100's, and each tire is 120 a piece. i would highly recommend getting tires where you can get a roadside warrenty, such as americas tire company.
Starrman85 is offline   Reply With Quote
Old 10-14-2003, 09:26 PM   #21
turboman's Avatar
Default Re: is fix-a-flat permanent? (STARRMAN85)
Keep that **** ghetto. Fix a flat all the way
turboman is offline   Reply With Quote
Old 10-14-2003, 09:29 PM   #22
Ricey McRicerton's Avatar
Default Re: is fix-a-flat permanent? (turboman)
I busted a can of that **** in my car...worst stink ever. My buddys dad invented the ****...and he even said it's a temporary thing (had to call him real quick )
Ricey McRicerton is offline   Reply With Quote
Old 10-14-2003, 09:33 PM   #23
KOALA YUMMIES's Avatar
Default Re: is fix-a-flat permanent? (crujones)
Not worth risking your life over choosing to NOT carry a spare wheel + tire. Not worth the minimal benefit of weight reduction either. Rally cars are fully stripped and frequently get flat tires, they ALWAYS carry spares. Never seen them use a "fix-a-flat".
KOALA YUMMIES is offline   Reply With Quote
Old 10-14-2003, 09:40 PM   #24
mycivicstoo(s)low's Avatar
Default Re: is fix-a-flat permanent? (KOALA YUMMIES)
Quote:
Don't rally cars carry more than one spare sometimes? About the fix a flat, I used it for a long time on my old car, but I wouldn't do it again. The can says it's for temp use only, so....
mycivicstoo(s)low is offline   Reply With Quote
Old 10-14-2003, 09:42 PM   #25
Default Re: is fix-a-flat permanent? (mycivicstoo(s)low)
O.T. Yeah I think they sometimes do carry more than one spare with them. I should too since mine are all unidirectional.
Can Fix-A-Flat...? gsrvong Wheel and Tire 0 03-30-2009 11:39 PM
can fix-a-flat be used on bicycle (bike) tire/tube? professorman General Discussion and Debate 4 05-22-2005 01:41 PM
slow leak in slicks 964dgsr Drag Racing 2 02-19-2003 07:49 PM
fix-a-flat x00gsr General Discussion and Debate 6 12-02-2002 05:59 PM
Fix-A-Flat VS. Spare Tire ck279 Tech / Misc 9 02-04-2002 01:53 PM
Tags
busted, car, fix, fixaflat, fixed, flat, liquid, long, messy, permanent, permantent, seattle, shucks, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
