Example of deceiving statistical argument. - Honda-Tech
Old 02-09-2005, 06:01 AM   #1
Default Example of deceiving statistical argument.
A while back I read a long story in the paper about how people earning minimum wage could not afford the average rent on an apartment.
http://www.detnews.com/2003/re...0.htm
Does anyone see the huge mistake in this argument? The AVERAGE rent for an apartment is going to be greater than about half of the units on the market. MINIMUM wage should allow you to afford MINIMUM rent. AVERAGE wages should allow you to afford AVERAGE rent.
Anyone who has dealt with me here before can probably guess that I am in favor of raising the minimum wage. However when I see blatant deception like this I will call it out no matter who is using it.
fredtoast is offline   Reply With Quote
Old 02-09-2005, 06:16 AM   #2
Default Re: Example of deceiving statistical argument. (fredtoast)
The average has nothing to do with the midpoint.
fs
Filthy Focker! is offline   Reply With Quote
Old 02-09-2005, 06:17 AM   #3
zer0gauge's Avatar
your argument would hold water if they were referring to the MEDIAN rent for the market, not the AVERAGE. Median is the exact middle point, where average takes the combined sum and divides it by the number of units involved.
For example:
3 ppl live on 1 road. Respectively they 25k, 37k, and 93k a year. The median income for the street is 37k. The average would be 51.6k. See the difference?
zer0gauge is offline   Reply With Quote
Old 02-09-2005, 06:19 AM   #4
Default Re: Example of deceiving statistical argument. (filthy_shovel)
No, it isn't the median. But, he is right on the point. Why should someone making minimum wage be shopping for "average" priced apartments. ie, apartments in my area go for anywhere from $400-$1200 for a 1 bedroom depending on section of town. The average is around $750. Someone making minimum wage is obviously going to be living in a $400 unit, but if we used that statistic here, it would make it seem that people making minimum wage are homeless and have nowhere to live when that isn't the truth.
Quote:
fs
AP-Signworks1 is offline   Reply With Quote
Old 02-09-2005, 06:24 AM   #5
ricodemus's Avatar
Default Re: Example of deceiving statistical argument. (zer0gauge)
Quote:
For example:
Bad example to discredit because that average (51.6k) certainly isn't affordable to the person on the minimum on that street. He's saying that if you use average you get an inflated number like the 51.6k and for sure that person in the minimum category couldn't afford that average price.
ricodemus is offline   Reply With Quote
Old 02-09-2005, 06:27 AM   #6
zer0gauge's Avatar
Default Re: Example of deceiving statistical argument. (ricodemus)
Quote:
the example was only to show the difference between median and average, therefore the example was perfectly apt, especially considering his statement of:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
The AVERAGE rent for an apartment is going to be greater than about half of the units on the market.</TD></TR></TABLE>.
Old 02-09-2005, 06:35 AM   #7
ricodemus's Avatar
well you said that his argument didn't hold water when your example proves that it does. He's pointing out the flaw in the report by not using the median and just the logic that minimum wage probably wouldnt be able to afford the avg apartment, even if the median and the avg were the same.
Old 02-09-2005, 07:43 AM   #8
Actually with a large sample like "all apartments" the average will usually be very close to the median. That is why I put the word "about" in my statement. Either way my point is still valid.
Old 02-09-2005, 07:58 AM   #9
Collector-o-Guns and Drinker
Splat's Avatar
"Liars figure, and figures lie."
My dad is fond of that expression, having spent most of his professional life as an auditor.
The more current equivalent we use around here is "Torture the data long enough, and it will tell you anything you want to know."
Splat is offline   Reply With Quote
Old 02-09-2005, 08:04 AM   #10
purplegsr's Avatar
I am a health policy researcher/statistical programmer, so I know a bit about the subject. There are too many methods questions that can't be answered by this article, so I will try to find the original publication and let you know what I think.
That being said, There are a few issues:
Median and Mean can both be referred to as the 'Average'. Usually, when I do an average, I report the Mean with a 95% confidence interval (which is based on the standard error and degrees of freedom). Based on this short blurb, I don't know whether they used an average mean or average median for their reported 'average'.
Second, it is very very very difficult to get media coverage that understands what the hell you are saying most times. I have been interviewed for tv, print, and radio news and they always want me to boil it down to the most salient, easiest to understand points. If you talk about the limitations of your study, the methods used, the % error, etc they will completely ignore it and try to get you to say something like 'Rent costs $791 and poor people make $237 so they can't afford it.' Unless the reporter really understands the issue, they often try to simplify what you say. So, until I see the actual publication, how they dealt with outliers, sample size, and their data sources for income and home prices, I would assume that the study's authors aren't trying to decieve, but that they probably did a bad job of reporting their findings.
purplegsr is offline   Reply With Quote
Old 02-09-2005, 08:16 AM   #11
purplegsr's Avatar
Default Re: Example of deceiving statistical argument. (purplegsr (Exospeed))
Here is the actual report, although I think this one is newer.
http://www.nlihc.org/pubs/uaw04/UpAgainstaWall.pdf
NOTE: The average reported in the above article is actually a MEDIAN value for rent, they do not calculate a mean in the report (at first glance).
They use a Census Dept. survey, the American Community Survey (ACS), to calculate the median pricing for rent and median income in order to make their assessments. I have heard good things about the survey, and they supposedly have enough sample to make local estimates. The one problem I do have with the study is that there is no multivariate analysis, it is all descriptive and there is no measure of statistical significance. This is usually what happens when a trade organization uses data like this - although their findings are probably relatively accurate, they don't test it, and then they leave those findings in question. As a researcher in an academic setting, we always do more analysis (chi-square, t-test, and regression) to make sure we can make certain statements.
All in all, I think the report is ok, but I think the article is a little bit misleading about how they reached the findings.
Old 02-09-2005, 08:35 AM   #12
Quote:
Originally Posted by purplegsr (Exospeed)
.All in all, I think the report is ok, but I think the article is a little bit misleading about how they reached the findings.
I'm not saying that there is ANYTHING wrong with the numbers. I'm just saying that the CONCLUSION is incorrect. A person making minimum wage should not expect to afford an "average" apartment. It doesn't matter how you define "average". A person making minimum wage should be able to afford minimum rent.
I was afraid that this thread would dissolve into a discussion about minimum wage. I never imagined that we would get into an in depth analysis of statistical methodology.
Old 02-09-2005, 09:02 AM   #13
purplegsr's Avatar
Yeah, I agree, I remember about a month ago I was discussing So. Cal home prices with my girlfriend and another friend - there was another report that came out in CA about median home prices and they had a quote that '80% of people in CA could not afford a home'.
However, they actually meant that 80% of Californians couldn't afford a home if it was priced at the median, which is something like $470,000 now. I argued the same point that you are, it's an unfair comparison because it doesn't mean 80% of people are renters, it means that a fair majority of people buy cheaper houses that are not in urban areas. As someone who does this for a living, I always question 'research' findings that overstate their claims like that.
I think academic researchers are doing better at stating their biases, limitations of their numbers, and not overstating their findings just for a headline. But there are still quite a few trade associations and advocacy groups that tend to find a number and illogically use it for their own goals, or try to. You should read Deborah Stone's 'Policy Paradox', it's a very good book about how research is never objective, and that transparency of methods and dialogue is the only true way to further your research and actually learn anything.
Fmr. McDonald's USA CEO: $35K Robots Cheaper Than Hiring at $15 Per Hour solbrothers General Discussion and Debate 160 06-14-2016 11:12 PM
The hourly wage needed to rent a 2-bedroom apartment in the US foumer General Discussion and Debate 96 06-03-2016 11:11 PM
Living Wage vs. Minimum Wage crawdad689 General Discussion and Debate 425 12-19-2013 05:43 AM
What Happens When the Government Controls Wages 914Racer General Discussion and Debate 32 05-29-2009 08:10 PM
Latest driving pleasure device.... fast4w$ General Discussion and Debate 13 11-05-2003 10:05 PM
Tags
argument, arguments, deceiving, examples, information, numbers, sample, statistical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
