Drill a hole in your muffler - exhaust experts - Honda-Tech
Old 04-13-2010, 09:16 AM   #1
GoLowDrew's Avatar
Default Drill a hole in your muffler - exhaust experts
http://www.thunderracing.com/catalog...installZ06.pdf
Look at page 4. There is a drain hole in the aftermarket exhaust. Many OEM exhaust (GM-Chrysler) system also have a small hole. It suppose to prolong the life of the muffler.
I never seen it on a Honda OEM muffler. Or on a WS2, Magnaflow, or OBX muffler/exhaust systems.
The by-product of the cat for clean air is water. Water sitting in your muffler can will rot out over time.
Is it a good idea to drill a hole?
GoLowDrew is offline   Reply With Quote
Old 04-13-2010, 09:20 AM   #2
at the jetties fishin'
stackz's Avatar
Default Re: Drill a hole in your muffler - exhaust experts
yay, intentional exhaust leaks!
meh, it'll probably get a layer of carbon/water goo built up over it in a little time and clog up anyway resulting in the muffler still rotting apart.
stackz is offline   Reply With Quote
Old 04-13-2010, 09:25 AM   #3
Unceasing Measure
Archidictus's Avatar
I'll just pay $50 for a new muffler when it's time, thanks. No drilling holes in my muffler.
Archidictus is offline   Reply With Quote
Old 04-13-2010, 09:25 AM   #4
Batpool
No. The exhaust is hot enough that the water burns out as steam. The amount that stays in is negligible at best and is almost always burned out by the heat.
Whole exhaust > exhaust hole.
SilentEdge is offline   Reply With Quote
Old 04-13-2010, 09:27 AM   #5
Drunk Wagon Pilot
Pinja's Avatar
I just run open header
Pinja is offline   Reply With Quote
Old 04-13-2010, 09:28 AM   #6
H-T Poker champion
Hatchy-Ownzjo0's Avatar
I don't have a muffler on my car..
Hatchy-Ownzjo0 is offline   Reply With Quote
Old 04-13-2010, 09:42 AM   #7
GoLowDrew's Avatar
Quote:
That is true. And that's (one of the reasons) why short trips are "bad" for a car.
However, just yesterday there was a chem spill (http://www.kgun9.com/Global/story.asp?S=12297868), and several PI Crown Vics were blocking the road. When it was clear to go, the CVs (with it's engine ideling for hours?) starting to move in front of me as I got there.
There were almost a few cups of water coming out of the pipes. So it made me think.
Old 04-13-2010, 09:44 AM   #8
Mrs 5th's Avatar
Quote:
iLol'd
Mrs 5th is offline   Reply With Quote
Old 04-13-2010, 09:45 AM   #9
rookn00b
xtrac1's Avatar
My exhaust already has a hole.
Wait, muffler?
xtrac1 is offline   Reply With Quote
Old 04-13-2010, 09:46 AM   #10
Risky Business
BauleyCivic's Avatar
You must not live within a mile of anyone.
BauleyCivic is offline   Reply With Quote
Old 04-13-2010, 09:48 AM   #11
Mrs 5th's Avatar
Quote:
Wait, muffler?
Old 04-13-2010, 09:49 AM   #12
Pat McGroin's Avatar
This is already a popular mod amongst honda wagovan owners or any hondas with the transverse muffler and there have been pictures of a ton of water just draining out.
Pat McGroin is offline   Reply With Quote
Old 04-13-2010, 10:21 AM   #13
Daisy... Daisy...
Dogginator's Avatar
If the muffler is made out of steel, a hole drilled afterwards will serve as a breach in the corrosion pretection, which will serve as a nucleation point for corrosion. A factory drilled hole should have corrosion protection on it.
The condensation problem is the worst in winter, especially when a car is driven on short trips. If the exhaust is fully warmed and the car is occasionally driven hard, the condensed water should blow out of the muffler.
Is this about the van?
Dogginator is offline   Reply With Quote
Old 04-13-2010, 10:25 AM   #14
PatrickGSR94's Avatar
No hole in my muffler.
<-- original stock 16-yr old muffler GS-R, still rust free! Most of the piping under the car is original, too.
PatrickGSR94 is offline   Reply With Quote
Old 04-13-2010, 10:25 AM   #15
GDD Member
slomofo's Avatar
Depends where the water is. It may be steam before the cat where the temperature is hottest, but once it's inside the muffler baffles, it goes back to liquid form if the exhaust isn't hot enough.
slomofo is offline   Reply With Quote
Old 04-13-2010, 10:34 AM   #16
Screw you guys, I'm... going... home.
tjbizzo's Avatar
Um, no, it isn't a by-product of the cat, it's a by-product of the combustion of hydrocarbons. ALL hydrocarbons do this when burned, which is why modern high-efficiency furnaces, boilers, and water heaters are called "condensing" units. Just sayin'
tjbizzo is offline   Reply With Quote
Old 04-13-2010, 10:39 AM   #17
uhhh condensing units produce water because of the refrigerant pipes passing through a heat exchanger, which causes the moisture in the air around it to condense into liquid form. It has nothing to do with combustion. In fact, condensing units on split HVAC systems do not involve combustion of any kind. This is what the little tube is for underneath your engine that drips water after driving with the A/C on.
I work in an architecture office and work closely with mechanical engineers and see buildings being built every day, and I have NEVER heard a furnace, boiler, or water heater referred to as a "condensing" unit.
Old 04-13-2010, 10:44 AM   #18
GoLowDrew's Avatar
Quote:
Just tossing out ideas for the Accord.
Old 04-13-2010, 10:50 AM   #19
BCICAN
Dunc's Avatar
My OEM catalytic converter on my motorcycle has a small hole in the bottom of it for this purpose. I trust the engineers of that company.
Dunc is offline   Reply With Quote
Old 04-13-2010, 10:51 AM   #20
Daisy... Daisy...
Dogginator's Avatar
Quote:
This is correct. If the gas drops below it's dew point, the water condenses and precipitates as a liquid. The high efficiency furnaces extract enough heat to drop the flue gas below the dew point. A cold exhaust system on a car does the exact same thing.
Old 04-13-2010, 11:02 AM   #21
I Deliver
EJAYATE's Avatar
Quote:
I have a wagovan, when I drilled the hole about a quarter gallon came out. It's not like you can hear a tiny hole in the back portion of your muffler. It doesn't sound like a leaky exhaust.
EJAYATE is offline   Reply With Quote
Old 04-13-2010, 11:14 AM   #22
GoLowDrew's Avatar
Quote:
Thinking back, my 88 Civic did have a rust spot on the muffler after only about < 8 years. I always thought maybe I scrape it going over a speed bump, while carry my three 200lbs+ friends in the car.
Old 04-13-2010, 01:20 PM   #23
stevieteg's Avatar
Quote:
Every <$100 oem style muffler I have every bought has lasted at most 1 year. I went though 2 before I finally just bought a stainless one, well worth the extra money imo.
The hole drilling makes sense to me though. The stock muffler on my DC rusted from the inside out. It still lasted 12 years but it did finally give out. If I had the fore sight I may have drilled it because as stated before, cheap oem replacements are always garbage and have never lasted for me.
stevieteg is offline   Reply With Quote
Old 04-13-2010, 05:01 PM   #24
y7turbo's Avatar
Quote:
So what exactly do you do there?
Tjbizzo is correct.
Byproduct of combustion is water.
the 90%+ furnaces and boilers are condensing. they use a secondary heat exchanger to bring the combustion gasses below its dew point as stated earlier to extract more heat from the unit.
Maybe his wording was incorrect. Its not actually a "Condensing unit", but a "condensing furnace", or "condensing boiler", or whatever piece of mechanical equipment you're talking about.
y7turbo is offline   Reply With Quote
Old 04-13-2010, 05:07 PM   #25
you are talking about something completely different. noone is talking about hvac but you. everything in this thread is about the combustion process. i would tell people to take it easy on you and not flame you, but you had to start your post with "uhhh", like we are all so stupid and you must take time out of your genius life to explain to us. you should work a little closer to the engineers, or better yet, work a little further, and dont influence their work.
TurboEM1 is offline   Reply With Quote
Do all new mufflers have 1/8" holes on the sides for venting? CrxChicken Honda CRX / EF Civic (1988 - 1991) 3 04-25-2013 01:42 AM
Need help with installing a Silencer AdRoz Honda Civic / Del Sol (1992 - 2000) 2 02-19-2009 07:32 AM
o2 sensor highrev98civic Honda Civic / Del Sol (1992 - 2000) 2 04-03-2008 04:59 PM
exhaust questions theaznracer Acura Integra 7 04-27-2005 07:12 PM
Exhaust? crxspeedemon Honda CRX / EF Civic (1988 - 1991) 6 08-25-2002 04:50 PM
Tags
car, clean, danger, drill, drilling, exhaust, good, hole, holes, hondatech, make, muffler, small, sound, supposed, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
