Does Gasoline Damage paint? - Honda-Tech
Old 08-19-2008, 09:43 AM   #1
JohnD1079's Avatar
Default Does Gasoline Damage paint?
I know gas is a very good disolver/cleaner.
Will it damage paint if i use it to remove the bug and tar that accumulates onto the front(or anywhere) of the car without damaging the clear coat?
JohnD1079 is offline   Reply With Quote
Old 08-19-2008, 09:44 AM   #2
Drunk Wagon Pilot
Pinja's Avatar
Default Re: Does Gasoline Damage paint? (JohnD1079)
Go try it on your neighbors car first
Pinja is offline   Reply With Quote
Old 08-19-2008, 09:45 AM   #3
DRAMA's Avatar
Yes, gasoline will eat away at the clear coating.
If you have bugs on the front of your bumper, use this. I use it all the time and it works 100% perfectly too. Just wash the bumper afterwards so you don't have a haze over it.
Plus it's cheaper than gas
DRAMA is offline   Reply With Quote
Old 08-19-2008, 09:47 AM   #4
I've used lighter fluid on small areas of paint to removing badging and hard to get off glue.
After that I cleaned, clay barred and waxed.
You can't tell there was ever badging there.
Stockton is offline   Reply With Quote
Old 08-19-2008, 09:57 AM   #5
drunk_0n_c0r0na's Avatar
wouldn't know. gas is way too expensive to be putting on the outside of the car too.
drunk_0n_c0r0na is offline   Reply With Quote
Old 08-19-2008, 10:40 AM   #6
2010 Honda-Tech Poker champion
Honda Tool's Avatar
WD-40 works great on tar.
Honda Tool is offline   Reply With Quote
Old 08-19-2008, 11:57 AM   #7
AWDxBOOST's Avatar
Default Re: Does Gasoline Damage paint? (drunk_0n_c0r0na)
gasoline and paint thinner has similar effects if that tells you anything
AWDxBOOST is offline   Reply With Quote
WTB: 94-01 Integra driver's fender, 94-97 front bumper allm0torGSR Want to Buy 1 06-02-2016 03:06 PM
removing double stick tape OOOtony Acura Integra 15 08-18-2008 08:28 PM
Interior paint removal? denraweb Honda CRX / EF Civic (1988 - 1991) 5 09-15-2007 12:59 AM
Should I buy this 96 dx hatchback B-money Honda Civic / Del Sol (1992 - 2000) 0 11-14-2004 11:18 AM
Claybar damages clearcoat? ITRFetish2000 Acura Integra Type-R 36 05-27-2004 09:26 AM
Tags
car, cars, clean, clear, coat, damage, damaging, eat, effect, gas, gasoline, hurt, paint, sport, tar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
