denatured alcohol to pass CA smog? fact or fiction? FACT! - Honda-Tech
Old 03-05-2011, 02:35 PM   #1
iheartjayDem's Avatar
Default denatured alcohol to pass CA smog? fact or fiction? FACT!
whats up ht, okay so i have a 91' civic hatch thats bar'd for a 91' B18A1. i currently have a 98' jdm B18B motor in there & i reused my allllll of my obd0 components on the new longblock.
The B18B has bad rings, it smokes on coldstarts and heavy acceleration. I also didnt rewire my fan switch so the radiator fan wasnt on. This is how i cheated the smog:
91' civic hatch bar'd for 91' B18A1
jdm B18B obd0 configured
timing set @ 16 degrees
stock 1.5L airbox w/ k&n filter
new random unknown brand ca compliant cat i got from a muffler shop
hedman header ( didnt even ask for the carb sticker )
i drove my car around for about an hour before hand & ran it suuuper empty, put 2 gallons of 87 octane & poured in 1 gallon of denatured alcohol while it was running. It didnt affect the idle at all, didnt smoke, the car didnt even seem to notice, but you could definitely feel a power decrease. I drove it 15 min to the smog shop in third gear & let it idle outside.
15 MPH:
max / meas
HC: 127 / 46
CO: .79 / .12
NO: 825 / 801
i checked the temp of the car after the 15 MPh test and it was overheating, the needle was halfway between NOT and max temp. i asked him to bring out the huge air circulator fans and throw it infront, it did alot better.
25 MPH
max / meas
HC: 101 / 23
CO: .68 / .08
NO: 764 / 70
IT WORKED! i passed and immediatly after leaving the smog place i went to the gas station and filled it up to try and dilute the alcohol as much as i could. Hope this helps someone.
iheartjayDem is offline   Reply With Quote
Old 03-05-2011, 03:11 PM   #2
slowly blowing brothers
solbrothers's Avatar
Default Re: denatured alcohol to pass CA smog? fact or fiction? FACT!
How do you know uy was going to fail? You didnt necessarily cheat, you just passed
solbrothers is offline   Reply With Quote
Old 03-05-2011, 03:13 PM   #3
Old news is really old news.
EJeff8 is offline   Reply With Quote
Old 03-05-2011, 03:18 PM   #4
Op hates thieves but loves ed6's
Old 03-05-2011, 03:33 PM   #5
if you saw the way it burns oil you'd know it would fail too. Last week it was blowing out so much smoke it killed a semi-new o2 sensor in a week, i replaced it yesterday.
Old 03-05-2011, 03:33 PM   #6
lol yeap
Old 03-05-2011, 03:36 PM   #7
Ajax's Avatar
15 MPH:
max / meas
HC: 127 / 46
CO: .79 / .12
NO: 825 / 801
25 MPH
max / meas
HC: 101 / 23
CO: .68 / .08
NO: 764 / 70
You have a B18B1 that has bad rings and overheats and you are worried about it passing smog?
Ajax is offline   Reply With Quote
Old 03-05-2011, 03:37 PM   #8
GDD Member
slomofo's Avatar
This thread is misleading information because the smog test has different fields. NOx is not positively affected by alcohol, only hydrocarbons and CO. Get the mixture of alcohol wrong and you could fail NOx if your HC drops too low and you start running too lean.
Alcohol works for some, but not all. If a car like a Dodge with a 318 or 360 is failing for what they typically fail for which is NOx and you suggest to them that they run alcohol, their NOx numbers will get worse and they'll risk damage to their catalytic converters. The risks of everyone running alcohol are too great because not everyone is an emissions (smog) expert and using it inappropriately could result in damage of catalysts, oxygen sensors, and even engines; this is why I never suggest it to anyone.
slomofo is offline   Reply With Quote
Old 03-05-2011, 03:38 PM   #9
GDD Member
slomofo's Avatar
You'd be surprised how many smoky cars pass and how many seemingly clean cars fail.
Old 03-05-2011, 03:38 PM   #10
at the jetties fishin'
stackz's Avatar
And yet you still want to run this piece of ****?
stackz is offline   Reply With Quote
Old 03-05-2011, 03:51 PM   #11
im borrowing this engine to get my tags because thats what its bar'd for. once i get my tags, i can reswap it with the itr swap waiting in my garage & im good for 2 years. I shouldve tried to smog it without the alcohol, but i didnt because im impatient. i found a lot of mixed opionions so i decided to try it for myself & it worked. why not add another good testimonial for someone that could be skeptical on trying it themselves?
Old 03-05-2011, 05:12 PM   #12
Resident Gearhead
BryanM.'s Avatar
Wouldn't it be grand if more people beat the system and continued to pollute the air using tricks like this? Great info
BryanM. is offline   Reply With Quote
Old 03-05-2011, 06:32 PM   #13
Quote:
this
Old 03-05-2011, 06:37 PM   #14
racebum's Avatar
so you're doing all this swap labor just for tags?
i can't believe the trouble some of you go to in order to keep old cars going
racebum is offline   Reply With Quote
Old 03-05-2011, 07:24 PM   #15
yess i am, this situation doesnt pertain to only older cars. any one that swapped a bar'd car with something else has to pull that engine out, swap, then reswap. so i guess im the type of person that loves their car enough to do something consuming as **** like this lol
Old 03-06-2011, 10:09 AM   #16
Botched thread poll
BIGBLOCKEK's Avatar
or you COULD have just properly swapped the b18c5 with all necessary smog equipment and have it bar'd for that swap.
BIGBLOCKEK is offline   Reply With Quote
Old 03-06-2011, 10:26 AM   #17
They let me pick
mrdeadman's Avatar
OP had a civic though...
mrdeadman is offline   Reply With Quote
Old 03-06-2011, 01:51 PM   #18
buuuut i didnt feel like sourcing out a clean usdm b18c5, so i got a clean b18c itr which was 1000 times easier to find
Old 03-06-2011, 02:20 PM   #19
TEGGSRB18C1's Avatar
Fvcking California. Are the girls there that hot? Is the weather that nice?
TEGGSRB18C1 is offline   Reply With Quote
Old 03-06-2011, 02:52 PM   #20
Quote:
yes and yes
Old 03-06-2011, 04:09 PM   #21
Quote:
Originally Posted by solbrothers View Post
yes and yes
*starts packing*
Old 03-06-2011, 04:29 PM   #22
SHAME ON YOU REBECCA!
kidcool1977's Avatar
*starts packing*
I've been to cali. as SOL said it is a different world then York pa (no offense),personally I'd rather go to Florida girls there are MUCH HOTTER!
kidcool1977 is online now   Reply With Quote
Old 03-06-2011, 05:47 PM   #23
MonkeyMagic's Avatar
first thought, then...
Quote:
but that would make sense? amirite?
MonkeyMagic is offline   Reply With Quote
Old 02-02-2013, 02:14 PM   #24
Quote:
I agree if you hit up south beach
Rudy N Alvarez is offline   Reply With Quote
Old 02-02-2013, 02:18 PM   #25
been there done that
doood's Avatar
Quote:
get the **** out
doood is offline   Reply With Quote
Failed Smog Check, high Nox Uljima Hybrid / Engine Swaps 4 08-24-2016 05:43 PM
prelude: a litle high HC Smog failed trying2tune Honda Prelude 11 06-11-2015 08:15 PM
smog question regarding CA 94VXLSHatchie Honda Civic / Del Sol (1992 - 2000) 8 09-27-2006 09:56 AM
failed smog, look!!! toooslow Tech / Misc 0 09-26-2005 06:34 PM
Failed smog with my B16 (numbers included) 91civicEX Honda CRX / EF Civic (1988 - 1991) 19 05-19-2005 06:54 PM
Tags
adding, alcohol, catalitic, clean, converter, crx, denature, denatured, hc, honda, idle, pass, smog, test, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
