Data recovery help- external hard drive showing up as unallocated - Honda-Tech
Old 03-16-2011, 07:08 AM   #1
loki2323's Avatar
Default Data recovery help- external hard drive showing up as unallocated
I have a 2tb WD Essentials drive that had problems with a loose usb connection. I think the drive got messed up some how with it connecting and disconnecting. So I purchased an new enclosure to solve the issue and now the drive shows up in disk management as "unallocated".
Last night I tried a program called active partition recovery and with that I was able to actually see all folders I need and all the sub folders. Problem is that I don't think it fixed anything.
So....does anyone have any suggestions on how I can recover the data on this drive? I'm assuming that once I pull it off I can format the drive and that should get the drive up and running again?
I'm going to try test drive and getdataback ntfs tonight and see what I can come up with.
loki2323 is offline   Reply With Quote
Old 03-17-2011, 06:55 AM   #2
loki2323's Avatar
Default Re: Data recovery help- external hard drive showing up as unallocated
Solved
Well if anyone runs into a similar issue, I used testdisk and I was able to get the drive to show up again.
Now in the process of backing up 1.5 tb....which windows estimates taking 12 hours
Old 05-19-2011, 01:34 PM   #3
phengnhou's Avatar
Hey I'm having the same problem. How did you go about getting all the data back? I download testdisk, but was unsure what i need to do.
phengnhou is offline   Reply With Quote
WD 1TB external hdd unallocated dtran002 General Discussion and Debate 6 05-04-2012 07:51 PM
connecting my laptop to ps3 crdcz03 General Discussion and Debate 3 07-02-2010 11:56 AM
Deleted Ubuntu from Aspire One Netbook, how do I get back to Windows XP? Luis. General Discussion and Debate 4 06-18-2010 08:24 AM
How do I reformat? - Dell laptop did not come with disk(s) b18C1_liLkyLe General Discussion and Debate 14 02-13-2008 10:17 AM
Data Recovery? Fowler. General Discussion and Debate 18 07-07-2004 10:58 AM
Tags
data, disk, drive, drives, external, hard, ntfs, recover, show, showing, shows, unallocated, utility, windows, xp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
