Car that hasn't been driven or turned on in months - Honda-Tech
Old 02-25-2009, 11:37 AM   #1
NOT An Obvious Troll's Avatar
Default Car that hasn't been driven or turned on in months
I have had my 93 DB1 sitting since August of last yr in our parking lot without it being turned on or used. I had my license suspended. I stopped turning it on regularly in around November of last yr because the battery died, it wouldn't hold a charge. I finally got the money to get a new battery, and turned the car on. It turned on fine. It does shake when idle though. Should I get a compression check? Check for vacuum leaks? Is it just cuz its a old car? lol. Anyway I haven't driven it out on the road yet. I know I have to flush the liquids and all that.
Should I be expecting any other major problems?
NOT An Obvious Troll is offline   Reply With Quote
Old 02-25-2009, 11:39 AM   #2
My Name is Nobody
MSchu's Avatar
Default Re: Car that hasn't been driven or turned on in months
There really should'nt be that much wrong in that time frame in moderate climate... I am sure it's just blowing out the cob webs and working through the bad gas
MSchu is offline   Reply With Quote
Old 02-25-2009, 11:41 AM   #3
Change out the oil & filter and put some fresh gas in it, maybe a cleaner additive.
I would say even pour in a half can of seafoam into the engine, run the car for 5-10 mins till it warms up then do an oil change.
Stockton is offline   Reply With Quote
Old 02-25-2009, 11:42 AM   #4
Diller's Avatar
The battery made the ecu reset.
Diller is offline   Reply With Quote
Old 02-25-2009, 11:55 AM   #5
at the jetties fishin'
stackz's Avatar
meh, just take it down the road and toss some fresh premium fuel in there to help with the octane rating of your more than likely half dead gas then drive it around a little.
should be just fine.
stackz is offline   Reply With Quote
Old 02-25-2009, 11:56 AM   #6
Thanks guys
Old 02-25-2009, 12:40 PM   #7
killsnake562's Avatar
How about brake fluid? I haven't driven my car for about a year.
killsnake562 is offline   Reply With Quote
RSX won't turn on, lights click DC5_lov3r Acura RSX DC5 & Honda Civic EP3 5 01-22-2016 04:38 PM
95 civic ex no fuel prime wyte_myke Honda Civic / Del Sol (1992 - 2000) 39 07-18-2014 06:21 PM
Diagnostic Trouble Code P1359 dw31 Honda Civic / Del Sol (1992 - 2000) 1 06-04-2013 09:40 AM
should I continue with this girl, she is kinda young though. mrlover General Discussion and Debate 126 08-02-2005 09:36 AM
Car is having starting problems. Starter?? BriansDC4 Acura Integra 12 11-14-2002 06:18 PM
Tags
awhile, battery, car, care, check, dead, driven, hasnt, month, months, normal, smokes, turned, year, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
