Can I put thinner tires in replacement of stock? - Page 2 - Honda-Tech
Closed Thread
Old 11-07-2009, 04:55 PM   #26
GDD Member
slomofo's Avatar
Default Re: Can I put thinner tires in replacement of stock?
Quote:
Originally Posted by idrivesideways View Post
personally, i wouldn't only because i doubt it would look cosmetically pleasing with a larger fender gap.
5.125mm more fender gap, that's it. Do you realize how small of a gap that is?
Look at the fingernail on your pinky, half the width of your nail is around the amount of gap that this smaller tire will create. The full width of your fingernail is the amount lower the car will sit.
slomofo is offline
Old 11-07-2009, 04:56 PM   #27
lke2drvgsr's Avatar
Quote:
Originally Posted by GSRWSU View Post
Unless he deleted his post you are actually the second poster..
Most epic post of 2009.
lke2drvgsr is offline
Old 11-07-2009, 04:59 PM   #28
tazeat's Avatar
Look it up in the tire specs for OD...
Personally I'd sell to run the right size, it will artificially make your odometer increase faster and thus your mileage and mpg as well...
tazeat is offline
Old 11-07-2009, 05:00 PM   #29
racebum's Avatar
205 55 16 average is 24.88"
205 60 16 average is 25.69"
moving a tire nearly 1 full inch in size is noticeable
racebum is offline
Old 11-07-2009, 05:02 PM   #30
NOT An Obvious Troll's Avatar
Quote:
LOL win
NOT An Obvious Troll is offline
Old 11-07-2009, 05:04 PM   #31
GDD Member
slomofo's Avatar
Tires are done in milimeters.
205mm is the width.
Middle number is the height. In 205/60/16, the height is 60% of 205mm which comes out to 123mm in overall height.
205/55/16, overall height is 112.75mm, which is an increase of 10.25mm in overall height.
10.25mm is about the width of a normal person's pinky nail.
10.25mm = 0.40 inches.
Note: I was being stupid and kept dividing the 10.25 by two which is how I came up with 5.125mm.
slomofo is offline
Old 11-07-2009, 05:09 PM   #32
racebum's Avatar
correct, that's roughly the difference between 205 40 16 and 205 45 16 on something we all know like a G3 integra. VERY noticeable change cosmetically. it's also worth somewhere in the neighborhood of 3mph on the speedo.
i don't personally care since it's not my car, just something the OP should be aware of before he makes a choice
racebum is offline
Old 11-07-2009, 05:19 PM   #33
GDD Member
slomofo's Avatar
Very noticeable? Come on now man, it's not like going from limp to boner. The difference isn't noticeable at all unless you switch tire models like going from Goodyear Eagles to Falken Azenis in which case Azenis tires tend to have a lot more meat on them for some reason.
slomofo is offline
Old 11-07-2009, 05:30 PM   #34
Im not Banned
Day_Walker's Avatar
Anyone else think this guy is just a longterm troll?
He'll post normal **** all the time that someone as retarded as him(or how retarded he tries to act) could never be able to come up with and then every month or so he'll post the dumbest **** ever.
Day_Walker is offline
Old 11-07-2009, 05:32 PM   #35
EPIC TUNING
E-Rok's Avatar
yea ive been thinking that. unless he really is this dumb
E-Rok is offline
Old 11-07-2009, 06:31 PM   #36
GSRWSU's Avatar
so i got the tires and i really didn't notice any difference, i checked my speedometer with my Garmen GPS speedo and it was like a 1mph off, so it's all good.
GSRWSU is offline
Old 11-07-2009, 06:35 PM   #37
tazeat's Avatar
205mm is the width.
Or you could go take a look at the actual specs for OD on the tire which vary quite a bit from the "205/55R16" on the sidewall.
For what it's worth a Kumho ASX 205/40R16 on a 96-00 Civic speedo is about 7-8% faster than actual, I can take a picture in my car right now with a GPS and the speedo since that's what I'm running until I get new tires next week... that's significant. And far more than a tire calculator would lead you to believe which says <2% or something. Also the 215/45R16 Azenis RT615s were about dead on with the speedo and GPS .
tazeat is offline
Old 11-07-2009, 06:53 PM   #38
GDD Member
slomofo's Avatar
Sorry, I've been out of the racing game for a while now, I was referring to the old Azenis Sports, not the RT615s. I think the old Azenis sports were probably the widest flippin tires I've ever seen in my life.
slomofo is offline
Old 11-07-2009, 08:00 PM   #39
I Deliver
EJAYATE's Avatar
No the rt-615 are just as beefy, I've had em on my last 3 cars because of this beefyness.
EJAYATE is offline
Old 11-07-2009, 08:51 PM   #40
tazeat's Avatar
Then don't worry about it, how far was it off before? I bet it was off more or else it just proves there are massive differences in between sidewall numbers and actual OD of some of these tires...
Within 1mph is great :p
tazeat is offline
Old 11-07-2009, 08:54 PM   #41
361 accord's Avatar
**** ive got the right size tires and my car speedo reads 2-3mph quicker than compared to gps
361 accord is offline
Old 11-07-2009, 09:11 PM   #42
H-T White Ops
Frozen E's Avatar
You're going from a 60 series to a 55 series.......not much of a difference at all. Check tirerack to see how much of a difference.
Frozen E is offline
Old 11-07-2009, 11:23 PM   #43
Night Owl
Quote:
Your GPS is accurate and should be trusted. That extra 2-3 mph reading is most likely from tire wear.
Leo C is offline
Old 11-08-2009, 07:33 AM   #44
Daisy... Daisy...
Dogginator's Avatar
The wheel and tire forum would have made much more sense. As long as the tire is approved for your wheel width, you will be fine.
Dogginator is offline
Closed Thread
185's on a 195 Wheel? TylerLorenz Wheel and Tire 6 10-06-2009 05:17 PM
wtt bridgestone potenza tires 205 55 16 thicky tires for lowprofile 205 40 16 Eklsv-t Northern California (Sales) 1 06-11-2008 09:50 AM
b16 headgasket for boost dragonfly2k3 Honda Civic / Del Sol (1992 - 2000) 4 12-30-2007 05:17 PM
50 series to 40series? BB1LOViN Wheel and Tire 5 11-10-2007 07:11 AM
205/45/15 tires? ^jefs0ng General Discussion and Debate 6 11-06-2003 10:59 PM
Tags
04, 205, 2055516, 20560, 55, accord, acura, honda, integra, put, r16, replacement, thinner, tire, tires, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
