Can a C/C++ Programmer please help me?!?!?!?! - Honda-Tech
Old 01-27-2006, 03:25 PM   #1
Lifter2012's Avatar
Default Can a C/C++ Programmer please help me?!?!?!?!
Hey anyone who has knowledge is programming in C or C++ I really need some help!! ASAP. i've got a couple questions about some very BASIC stuff, like first 2 weeks of learning from scratch so if anyone can help let me know, i might even pay you! lol seriously
Lifter2012 is offline   Reply With Quote
Old 01-27-2006, 03:35 PM   #2
Ceres's Avatar
I've taken couple of classes post up the problem I'm sure theres a lot of ppl here who can help you out
Ceres is offline   Reply With Quote
Old 01-27-2006, 03:38 PM   #3
TTM
TTM's Avatar
havnt done it in a while but in my prime i was not half bad
TTM is offline   Reply With Quote
Old 01-27-2006, 03:42 PM   #4
funz0rzies's Avatar
cout << "wwwwwwwwwha"
geez i hated that class...if it's basic, i might be able to help also
funz0rzies is offline   Reply With Quote
Old 01-27-2006, 03:55 PM   #5
Lifter2012's Avatar
Default Re: (funz0rzies)
i'm jus gonna list some of the problems i have to do, i'm gettin them but it takes me forever and 100 tries each lol. anyone can help with which ever one or ones they want, thatd be awesome!!!
10012: Declare a numerical variable precise and initialize it to the value 1.09388641.
10247: Write a declaration of a variable named count that can be used to hold numbers like 9 and -1 and -4.
10248: Write a declaration for a variable rate_of_pay that can hold values like 11.50 or 12.75.
10249: Write a declaration of a variable named number_of_children that can be used to hold the number of children in a family.
10250: Write a declaration for a variable hits that can hold the number of times a baseball player has hit the ball in a baseball game.
10251: Write a declaration for a variable temperature that can hold the current outdoor temperature, measured to the half degree (like 98.6 or 31.5).
10252: Write a declaration for two integer variables, age and weight.
10253: Write a declaration for two variables, price and cost, that can hold numbers with decimal places.
10254: Write a declaration for an integer variable area and a variable price that can hold numbers with decimal places.
10255: Write a declaration for variables length, width, and area that can hold values like 13.5 and 14.6.
10256: Write a declaration for a variable channel that can hold TV channel numbers (1 to 900) and a variable hours_recorded that can hold the number of hours of TV recorded (numbers like 1.0 or 3.5).
10257: Write a statement that declares an int variable age and initializes it to 15.
10258: Write a statement that declares two int variables, named num and val and initializes each to 5.
10259: Write a statement that declares and initiallizes two integer variables. Call the first one age and initialize it to 15, and call the second one weight and initialize it to 90.
10260: Declare a variable miles_run and initialize it to 3.75.
10261: Write declaration statements to declare and initialize two variables: one is an integer variable named age, initialized to 18, and the other variable, named weight, is initialized to 114.5.
10262: Write statements to declare and initialize two variables: one, named element_number can hold any of the integer values 1 through 118; the other, named atomic_weight can hold the atomic weight of the given element; atomic weights are values like 3.76.
In the declaration, initialize the variables to the values for oxygen, which is element number 8 and has an atomic weight of 15.9994.
Old 01-27-2006, 04:18 PM   #6
Lifter2012's Avatar
Default Re: (Lifter2012)
i have some of these but i wanna make sure they are right before i submit them !!
Old 01-27-2006, 04:37 PM   #7
amin n'rangwa edanea
fluxion's Avatar
just post what you have...i dont wanna look like an idiot explaining something as trivial as variable declaration/initialization to someone who already knows
fluxion is offline   Reply With Quote
Old 01-27-2006, 04:44 PM   #8
Lifter2012's Avatar
Default Re: (fluxion)
Quote:
i DONT know lol thats the problem, like i have a slight idea but when it actually comes to writing the code i get lost. for exemple:
I have: char precise;
char precise = '1.09388641';
which it tells me is wrong. Our analysis of your code:
Suggestion: To handle data of that sort requires a floating-point data type.
another ex: 10247
my answer: const int count 9,-1,-4;
but both of these are wrong and i'm lost
Old 01-27-2006, 04:46 PM   #9
Flitch's Avatar
Double precise = 1.09388641
Int count
Double rate_of_pay
Int number_of_children
Int hits
Double Temperature
Int age, weight
Flitch is offline   Reply With Quote
Old 01-27-2006, 04:48 PM   #10
Flitch's Avatar
Default Re: (Flitch)
Doubles are for anything with decimal points
Ints are for whole numbers
Chars are for characters
and Const is for anything that WILL NEVER CHANGE.
I've done a few basic ones, you can figure out the rest.
Old 01-27-2006, 04:59 PM   #11
fluxion's Avatar
another ex: 10247
int count;
it can already hold a signed integer value, he didnt ask you to initialize it so you're done. it will indeed hold values like 9, -1, -4
and char data types only hold a single 8bit character, they dont store numbers (well..they'll store a sngle digit, but it wont be treated as a number)
looks like you're just getting lost in the wording and havent really looked up what data types should be used for what. you cant just wing it, there's precise rules involved. it's easy stuff though, it'll take you 10 minutes to read enough to breeze through these...seriously, i promise.
Old 01-27-2006, 05:06 PM   #12
Flitch's Avatar
int count;
Exactly
Don't forget to add semi-colon's to the ones I've done.
Old 01-27-2006, 05:12 PM   #13
another ex: 10247
double precise;
precise=1.09388641;
int count;
dont you have a book or anything????
wait till you start doing loops and matrices....
i took C last semester..it sucked
nickG is offline   Reply With Quote
Old 01-27-2006, 05:14 PM   #14
Flitch's Avatar
Default Re: (nickG)
Quote:
Originally Posted by nickG
double precise;
precise=1.09388641;
int count;
Hahaha, I love C++. I just hated doing the big complex Private and Public ****.
Old 01-27-2006, 05:14 PM   #15
Lifter2012's Avatar
wow thanks guys, yea literally after reading what you both wrote i finished all of them in less than 5 minutes haha. my teacher didn't explain it very well i guess. theres only 2 i'm stock on, the rest i got 100%!!!
10256:
mine:
int channel;
channel = 1 to 900;
double hours_recorded;
hours_recorded = 1.0 or 3.5;
i dont know what to do with the numbers??
10262:
how do i do a code when it has values through another, like the first one i posted 1 to 900??
Old 01-27-2006, 05:18 PM   #16
10256:
mine:
int channel;
channel = 1 to 900;
10262:
you dont have to do anything with the numbers..it says it has to be able to hold values..ie an integer (whole number) or a double...
it seems like youre just declaring variable and initializing them...this is just to get you to recognize when you need to use an int or a double
int channel;
int element_number=8;
double atomic_weight=15.9994;
Old 01-27-2006, 05:19 PM   #17
Flitch's Avatar
10256:
mine:
int channel;
channel = 1 to 900;
10262:
The only way to really limit a variable is to use If statements. Which I don't think you've gotten to that point yet.
Anyways, here is an example.
int channel;
cin >> channel;
If (channel > 1)
----- If (channel < 900)
----------- (Do whatever)
----- Else
----------- Null;
Else
-----Null;
Do the same with the other variable.
The -----'s are just for tabbing purposes. Really, you just have to declare them and be able to hold the said values. Limited involes the IF statements which I just posted.
Old 01-27-2006, 05:20 PM   #18
i dont think he has to actually restrict the variables, just allow them to be able to hold values 1-900...
Old 01-27-2006, 05:23 PM   #19
Lifter2012's Avatar
Default Re: (nickG)
phuckin awesome guys!!!! i got it all now!!! seriously i thought i was going to be here all phuckin night. i really appreciate everyones help, i might be back in a week or so with some new ones for ya guys haha but seriously thanks everyone. you saved my friday night and also from failing, now i know how to do these
Old 01-27-2006, 05:27 PM   #20
Flitch's Avatar
Default Re: (nickG)
Exactly, but when he hits that point...he'll know how
SHorsh's Vouch Thread shorsh For Sale 4 10-11-2007 12:21 AM
WTB: Racing Hart C2 Center Caps.. skoo74 Want to Buy 28 08-28-2007 10:22 PM
Spoon Exhaust question jdmkid_82 Honda Civic / Del Sol (1992 - 2000) 11 05-27-2006 04:05 PM
searched... A/C help please.. 95civhb Honda Civic / Del Sol (1992 - 2000) 1 04-25-2006 08:13 PM
HELP _ AC BELT REMOVAL...... crzyfool24 Honda Civic / Del Sol (1992 - 2000) 4 09-09-2004 07:20 PM
Tags
109388641, area, cost, declaration, declare, initialize, length, named, numerical, precise, price, temperature, variable, variables, width, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
