Automatic Ford Taurus: bucking and hesitation from a stop - Honda-Tech
Old 03-03-2007, 06:49 PM   #1
garados's Avatar
Default Automatic Ford Taurus: bucking and hesitation from a stop
I have no idea about automatics, much less about a Ford Taurus. Now, I don't know what year it is or what kind of engine/transmission it has. My friend across the continent asked me for help, and I have no idea where to start
Apparently, sometimes, it bucks and hesitates when accelerating from a stop when it's at operating temperature ... at other times it just sits there and revs. Finally, to throw a curve ball, it works fine on occasion. Perhaps it's low on tranny fluid? Dirty MAP or AFM? I have no idea.
Any ideas (other than pushing it off of a cliff or setting it on fire) would be appreciated
garados is offline   Reply With Quote
Old 03-03-2007, 06:51 PM   #2
.C h r i s's Avatar
Default Re: Automatic Ford Taurus: bucking and hesitation from a stop (garados)
.C h r i s is offline   Reply With Quote
Old 03-03-2007, 06:58 PM   #3
Widow's Son
Johnny.'s Avatar
Change out the tranx fluid and go from there. Could be as simple as that...could not be. But always try simple first.
Johnny. is offline   Reply With Quote
Old 03-03-2007, 07:00 PM   #4
garados's Avatar
Default Re: (JohnnyG35)
sounds good ... do all autos have a dipstick to check the level? Is it supposed to be checked when running?
Old 03-03-2007, 07:36 PM   #5
NuRon's Avatar
Yeah it should have one. The prodecure is turn the car on, shift through all the gears, then check fluid. Not sure about the car's overall operating temperature though.
NuRon is offline   Reply With Quote
Old 03-03-2007, 08:14 PM   #6
SoCal EJ1's Avatar
Ford circled the problem.
SoCal EJ1 is offline   Reply With Quote
Old 03-03-2007, 08:41 PM   #7
superthug's Avatar
Default Re: (SoCal EJ1)
I hate the exact same problem. Great car but the transmission went.
superthug is offline   Reply With Quote
Old 03-04-2007, 01:12 PM   #8
sounds like burnt clutch packs or a clogged main filter. you can drop the pan and change the filter fairly easily on these cars....
YeuEmMaiMai is offline   Reply With Quote
Old 03-04-2007, 01:13 PM   #9
Me Gusta History
accordselux's Avatar
Default Re: Automatic Ford Taurus: bucking and hesitation from a stop (YeuEmMaiMai)
Sounds like the reason I got a new tranny on my accord, and sounds like the reason my uncle's taurus has not moved in 5 years.
accordselux is offline   Reply With Quote
Revenge or not to Revenge? SlipAngleX General Discussion and Debate 27 08-19-2016 11:13 AM
Ford taurus cup holder install help in 94 civic ex coupe (pic) driveslow Honda Civic / Del Sol (1992 - 2000) 17 10-08-2015 11:55 AM
NOOOOOOOO!! Hughie1987 Acura Integra 5 02-25-2015 11:28 AM
Ford to rename the Five Hundred the 'Taurus' accordselux General Discussion and Debate 82 02-15-2007 01:04 AM
The 'Ford Passat' ??? MEDEL514 General Discussion and Debate 10 04-20-2002 08:02 AM
Tags
04, 1992, 2004, accelerating, bucking, civic, ford, hesitates, hesitating, hesitation, honda, miata, spec, tarus, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
