94 Ford Explorer Stereo wiring diagram please - Honda-Tech
Old 02-05-2005, 06:13 PM   #1
EKB18BPR3's Avatar
Default 94 Ford Explorer Stereo wiring diagram please
i have a pioneer i wanna install into my 94 ford explorer but im having trouble with it. searched google, yahoo...all gave me no info (i swear!). if anyone here KNOWS the color for each speaker or know where I can definitely find the answers, please let me know. NONE of the 8 speaker wires match in colors (ie: white and white/black, grey and grey/black). i bought a harness from BestBuy AND Walmart and for some reason they dont work. so I have to cut the harness from the truck off and splice them. please dont post if ur gonna start a Chevy VS Ford thread. and like always, thanx for ur answers!
EKB18BPR3 is offline   Reply With Quote
Old 02-05-2005, 06:16 PM   #2
chris_c's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (98B00STED)
before you go cutting, i bought a harness kit from circuit city and it works perfect. 1991 ford explorer here.
check explorerforum.com too
chris_c is offline   Reply With Quote
Old 02-05-2005, 06:20 PM   #3
EKB18BPR3's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (chris c)
both the walmart and bestbuy harness came with two ALMOST identical harness, one for the power and stuff and one for the speaker wires. the one for speaker wires dont fit the OEM ford explorer harness because the OEM one is square-ish shape and the walmart/bestbuy harness is long rectangle shape. do u remember what ur circuit city harness looked like?
Old 02-05-2005, 06:24 PM   #4
chris_c's Avatar
man, it was two years ago. if i can find the stupid things to pull the deck out i'll take a picture for you tomorrow.
Old 02-05-2005, 06:25 PM   #5
TurboBumblBee's Avatar
i worked in the install shop at a circuit city for almost 2 years and i know that early 90 fords are tricky when it comes to getting the right harness.. if i were you i would just drive up there, shop the install guy what plugs u have behind the radio and have him get you the right harness.. alot of older fords needed a converter harness that was a little more expensive then the standard harness that is needed with other fords. i do not remember the model numbers but i believe the amplifer harness was about 40 bux.. hope that helps..
but remember, dont go cutting wires cause that will only make your job tougher to install it and later on if you ever sell the car and want to put the factory radio back in
TurboBumblBee is offline   Reply With Quote
Old 02-05-2005, 06:28 PM   #6
EKB18BPR3's Avatar
thanx chris and turbobumblebee....i may just give up the idea and put the old one back on...i just had a pioneer laying around that i took off my civic when i gutted it out. anyways thanx again to both of u
Old 02-05-2005, 06:31 PM   #7
SirRevvs's Avatar
You should be able to find a Ford wiring harness anywhere (Wal-Mart for example) and I'm not totally sure if the 94 is factory amplified so try popping the speakers with a 9 volt battery before you wire everything up. If they don't pop you need a amplifier bypass harness and the amp is in the pass side rear plastic panel.
SirRevvs is offline   Reply With Quote
Old 02-05-2005, 06:36 PM   #8
chris_c's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (SirRevvs)
Quote:
i have a jbl system [originally from ford] with the amps and subs and i am using a regular harness and running the alpine door speakers off the stock amp and my jl audio 10 off the original subs amp. idk, it's been working fine for me for 2 years.
Old 02-05-2005, 06:38 PM   #9
jdmotorsports's Avatar
if the speaker plug is grey and square its the amplified system. you have to get the right piece then pull the rear quarter trim off and bypass the amp back there.
you can use the metra 70-5511 and use the factory amp.
heres the pic
jdmotorsports is offline   Reply With Quote
Old 02-05-2005, 06:44 PM   #10
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
http://www.installdr.com
that site might have the info you need..
88DXCRX is offline   Reply With Quote
Old 02-05-2005, 06:46 PM   #11
Audio28's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (88DXCRX)
12volt.com
Audio28 is offline   Reply With Quote
F/T or F/S: 1993 Black Ford Explorer 4x4 Absentmind Mid-Atlantic (Sales) 0 11-16-2007 07:51 PM
i got the loc all wired up now... mrdeadman Audio / Security / Video 12 02-01-2006 06:32 PM
does anyone know if i can get hu wiring schematics straight from the dealership? mrdeadman Audio / Security / Video 1 01-28-2006 12:00 PM
Ford accident kill switch? Spoon General Discussion and Debate 14 12-26-2005 01:28 PM
Installing a AMP in a Ford Explorer .swanny Audio / Security / Video 7 11-06-2005 06:31 PM
Tags
1991, 94, amp, amplifyer, bypass, code, color, diagram, dont, explorer, ford, jbl, oem, speaker, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
